Question about Samsung ML 1210 Laser Printer
I need parts for the
Samsung ML 1210 Laser Printer.Roll Assy pickup
Paper will not pickup
Please Help Ron
  • 1 more comment
  • genbur Sep 15, 2008
    I have a Samsung Printer, on another computer with XP and now it started having difficulty with taking the paper. Sometimes it takes the first one but not the rest, at other times it does not take any.
    Thanks.
    T.Sciortino
  • Anonymous Oct 15, 2008
    my ML-1210 printer will not pick up paper.
  • necfireage Dec 26, 2008
    My printer does not work because of not getting the power.So now what to do?
I have had the same problem with paper not picking up for some time and just discovered a much easier solution than taking the printer apart to replace the roller!!
In the past I had cleaned the pickup roller with alcohol but found that to only work for a few days. The roller has two high spots on it so you have to turn the printer off several times while it is rotating to various positions to make sure you clean both of the high spots which pick up the paper.
The permanent solution is to lightly coat these worn sections of the roller with rubber cement (aka paper cement, it dries rubbery and sticky and usually comes with a brush in the cap of the jar). Rubber cement is old fashioned stuff you used to find in office stores but not so much anymore, I had to go to a craft store to find some. I tried the newer paper glues that come in a stick but these dry to a slippery surface and don't work, you need the old fashioned rubbery stuff.
Problem solved. Much easier than taking the whole printer apart too.
Posted on Nov 13, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Samsung Master
  • 1,362 Answers
How do I get paper to feed thru my Samsung ML-1210 Laser Printer?
Dear
This model is old and may have aging defect for the friction pad and pick up roller.
You may kindly replace the above part for assurance of paper pickup. the paper is stacked vertically on the top from the back side pocket..
However the the pickup roller may be cleaned using a dampened cloth for temporary.
Thanks.
Feb 21, 2015 | Samsung Office Equipment & Supplies
Paper will not feed thru my Samsung ML-1210 Printer. How do I fix?
Check to see if you have dropped something in the feed... maybe a pencil, paper clip, some pizza...
Show the photo of paper pickup assy of samsung ml 3471nd
Hi, what is the problem you face? Always has paper jammed?
Dec 17, 2013 | Samsung ML-3471ND Network Mono Laser...
My Samsung laser printer ML-2510 keep wont stop running (two lights are blinking same time) until I manually turn off the switch.
After removing the pickup rubber (and not removing the rubber band from it's plastic drum) I cut a thick piece of card stock paper the width of the rubber band and slid it under the rubber. I thought it would make it contact the paper with more force and it worked great.
Dec 04, 2011 | Samsung ML-2510 Laser Printer
Samsung ml 1210 paper feed does not work
Ew. On a printer like this, if the paper feed doesn't draw paper in via the rubber rollers, then the printer is likely not good.
I checked the manual, and its copyright is 2001. Over time the rollers dry out and will not draw paper in as originally required when new.
I wouldn't invest too much into this printer, as, the parts are probably not available at this point in time for it.
Jan 19, 2011 | Samsung ML 1210 Laser Printer
Printer cant roll paper into it
you have replace the paper pickup roller
May 19, 2010 | Samsung ML 1610 Laser Printer
Gavran
Please visit http://www.samsung.com/us/support/search/supportSearchResult.do?group=printersmultifunction&group_cd=&type=printersmultifunction&type_cd=06010000&subtype=monochromelaserprinters&subtype_cd=06010400&model_nm=ML-1210&dType=D&vType=&mType=&model_cd=&menu=%2Fsupport%2Fsearch%2FsupportSearchResult.do&prd_ia_cd=06010400&acc_ia_fl=N&disp_nm=ML-1210&isEqualsY=
If you need to search Samsung.com for the printer drivers, type in "ML-1210" under the model number.
Hope this helps!
Oct 18, 2008 | Samsung ML 1210 Laser Printer
Driver Samsung Laser Printer ML-1210
Need driver for Samsung Laser Printer ML-1210
Mar 11, 2008 | Office Equipment & Supplies
Problem on printing on a thermal paper (Fax Roll Paper)
i have not drivers of samsung ML1610-XSG laser printer
Jan 02, 2008 | Samsung ML 1610 Laser Printer
Driver of samsung ML-1210 printer
hi Dear
Please send me the driver of Samsung ML 1210
Thanks
With best regards Shakeeb
Oct 16, 2007 | Samsung ML 1210 Laser Printer
Samsung ML 1210 Laser Printer Logo
369 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
