Question about Panasonic PT-51HX41 51" Rear Projection Television
Samsung rear projection tv st47w3p picture dims after few minutes
I have a samsung 47" rear projection tv when I turn it on everything is fine for few minutes and than picture starts to dim kind of fade out really dark. Still can see it but it is extreamlly dim. After turning it off for a while and back on it is ok just for few minutes and does the same thing again.
Could it be the power suppy or what can cause this it seems to me that it is a heat issue with some of the componands on the circuit board what can cause this? If you can help I do appriciate your support trying to see if it will be worth spending any inflated cost or go for a new tv. this set is about 3 years old.
Thanks
  • 38 Answers
Ok this is how u fix that problem it is a heat issue what u need is a can of 50 below freez u can use this on the circuit to find witch part is breaking down i dont think u will have a problem in the power supply it sounds like something in the video circuit that is causeing the problem. i hope this hp marty
Posted on Oct 13, 2008
HCL4715W 47 in. Rear Projection Television: Wheb the TV is turned on the screen is fine, howev...
Yes,this tv can be fix it have convergence problems.The convergence board the 2 STK covergence ICS are defective and some or all it resistors are dead.The shop will cost u $300-350 for parts and labors.
May 16, 2010 | Samsung HCL4715W 47" Rear Projection...
Turns off by itself
you have an overheat problem somewhere on one of the pc boards and the thermosistor is sutting it downfor safety you need a pro to service it sorry
Sep 28, 2009 | Samsung HCL4715W 47" Rear Projection...
I have a Sony 47 inch rear projection tv that is about nine years old When the set is turned on it has a good color picture but after a few minutes it tuns to a complete green sceen. Can you tell me what...
The green CRT may be intermittently bad or the focus screen block. Certain sony's are common to have bad CRT's. When the screen goes green does the set shut off?
Sep 20, 2009 | Televison & Video
Power light is on T.V. is not responding
u may have a bad convergence board stk392-040
Apr 30, 2009 | Samsung HCL4715W 47" Rear Projection...
I think it could be a faulty diode on the power supply board. If you can check this for yourself otherwise call out a competant technician. Good luck.
Sep 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
Tv turns off
Its the lamp that needs replacing. It will run for a couple of seconds and then it would dim or turn off.
May 27, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Picture Fades
The more you play set the longer it will last, it sounds like you may have poor connections, cold solder joints try soldering around flyback transformer.
Apr 03, 2008 | Zenith R56W36 56" Rear Projection...
Rear Projection TV Picture is all green with Horizontal Lines
It looks like you started out with an intermittent solder connection which may have been fairly easy to find early on. Now, unless a technican can make it come and go while tapping on the circuit board and repair the connection, it may be a very expensive shop repair.
May 29, 2007 | Samsung HC-P4741W 47" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
188 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
