Question about GE Zoneline AZ38H12DAD Split System Air Conditioner
My AC My Compressor keeps kicking off. I turn the unit on, the fan works. The Heat works but the compressor turns in about 60 sec. If I unplug the unit and turn it back on, it comes on but the compressor shuts off again after 60 sec. Can this be from dirt in the coils? They have some build up. Any other causes?
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
One might think so, YES the compressor is running till it gets hot and tripps on hi-temperature, and after it cools down awhile, the switch willcautomatically reset itself and back- & forth......Thank-you-very much!
Posted on Aug 23, 2008
Fan will come on but compressor wont kick in on wall unit ac
The start capacitor on the compressor is bad. Replace it and the compressor will run.
Jun 30, 2013 | Heating & Cooling
Model 160 c when AC goes on after about 5 minutes causes the circut breaker to go. The fan does not do that when it is turned on, only the AC. THANKS JEFF
Hi Jeff,
The compressor is either locked up or shorted....
The five minute delay is built in to keep the compressor from starting under load..
Then when it kicks on the high amp draw will kick the breaker...
In most cases the cost for parts and labor to replace a small compressor are more then the unit is worth...
The best thing to do is to replace the whole unit.
heatman101
Jul 03, 2011 | Hampton Bay Heating & Cooling
AC unit not kicking on...
You need a "Y" terminal. "Y" is pretty standard on every heat pump. It is the wire that will energize the compressor contactor at the outdoor unit, allowing the compressor and condensor fan to run.
Apr 03, 2010 | Heating & Cooling
Radiator fan keeps coming on at idle and when operating vehicle when Heater is turned on .When open the hood you see A/c unit alternator trying to kick on spins and Fan go on at same time together .When...
The fan will kick on automatically everytime the ac compressor comes on to cool down the refrigerant going through the condensor. Make sure you dont have a/c selected or have it on defroster if you dont want the compressor to run.
Feb 25, 2010 | 1998 Jeep Grand Cherokee
Home ac compressor fan won't turn all the time.
your looking at $175-$225 for just the single phase motor depending where you purchase, I just replaced mine(identical unit) due to screaming dry bearings, if you replace it your self make sure to keep new wires tight along side of unit or fan will cut them if loose and its a fan- 5mfd/25mfd compressor@440volt cap
Sep 27, 2009 | Goodman CLQ36AR49 Air Conditioner
Compressor on my RV coleman ac unit bogging down
Take a look at your start capacitor. This the capacitor that kicks the compressor over when it tries to start. If the capacitor is bad, it cannot kick the compressor back over after the first cycle because the head pressure has not evened out yet. It is located in the upper unit on the side panel in a small box. Be careful, highly charged capacitors can zap you if you are not careful. Disconnect power and touch across the terminals with a meter or a screwdriver to discharge the capacitor.
Hope this helps,
Jeff
Jun 29, 2009 | Coleman Mach 15 Air Conditioner
Compressor will not stay on
do you know if the fans are running constantly? and if so when the compressor comes on it trips out and the fan remains constant? i would like to know the running amps are they correct.
Jun 08, 2009 | Heating & Cooling
Problem with my AC unit
Hi Phillip,
Check your thermostat wires to see if you have any of them which are bare and touching. If any are touching separate them and tape em up and try unit again. You have a direst short in your cooling portion of the unit.
Feb 12, 2009 | Ruud UAMB Air Conditioner
No cold air
if unit is more than 5 yrs old dump it!!! most frigidaire models just dont last...that is why they are so cheap...get it???
Jun 09, 2008 | Frigidaire FAH085N1T Air Conditioner
Ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
May 02, 2007 | Amana PTH123B25AJ Heat Pump Air...
GE Zoneline AZ38H12DAD Split System Air Conditioner Logo
284 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
