Question about Apple iPod MA446LL/A MP3 Player
Ipod won't charge, won't show up in itunes.
The other night, my ipod started turning on randomly. I tried to turn it off and put it on hold, but it still would randomly turn on every minute or so. Then the next morning, I woke up, and the battery was dead. I tried to charge it but it did not charge in my computer's USB port and did not show up in itunes. could my battery be dead, or is some other problem the cause of this?
The same thing happened to me. I suggest getting a wall charger? And if your iPod won't show up on iTunes but you want to add songs and stuff, just keep trying.
Posted on Jul 31, 2008
My ipod will not turn on
Find out what to do if your iPod won't turn on.
Several things could prevent iPod from turning on. Check each cause in this order to find out what's wrong.
Products Affected
iPod
Resolution
Make sure the Hold switch is off
1. Check to see if the Hold switch is on. It's located on the top or the bottom of iPod. When it's in the on position, you'll see an orange patch.
2. To turn the hold switch off, slide it until you no longer see the orange patch.
3. Press any button to turn on iPod.
iPod hold switch on iPod hold switch on
Make sure the battery is charged
iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
iPod battery empty icon
To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod Power Adapter and plug the power adapter into an electrical outlet. Note: iPod models without a Click Wheel cannot be charged via USB. iPod shuffle requires a high-power USB port to charge. iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information.
Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost.
Let the iPod battery drain
In rare cases, iPod might get into a state in which it needs to be drained completely before it can be reset. If iPod didn't turn on after you reset it, follow these steps:
1. Disconnect iPod from all power sources and leave it disconnected for about 24 hours.
2. Reconnect iPod to the Apple iPod Power Adapter or computer and reset it.
Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod.
Additional Information
If you have tried the solutions above and iPod still won't turn on, check the following:
* Make sure iPod is the only device in your FireWire or USB chain. Disconnect everything but the mouse, keyboard, and your iPod, then see if it will turn on.
* Make sure you are using the FireWire or USB cable that came with your iPod, and that the cable is in good condition.
* Try connecting iPod to the built-in port of a different computer to see if that works. Note: If using a portable computer, make sure it is plugged in to a power source and that the lid or display is open. If the lid is closed the computer may go into either standby, sleep, or hibernation mode and iPod will not charge properly.
If you still can't turn iPod on after performing these steps, it may need to be repaired. You can arrange for repair at the iPod Service Website.
iPod may not power on, may be stuck on the battery logo, or may have stopped responding while playing music (in which case the Click Wheel doesn't respond).
Products Affected
iPod classic (120GB), iPod nano, iPod classic, iPod classic 160GB (Late 2009), iPod (5th generation), iPod (5th generation Late 2006)
Resolution
If you experience any of the above issues, try the following steps:
1. Toggle the Hold switch. To do this, slide the switch to Hold (an orange bar appears) and then slide it back (orange bar is hidden).
2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
* If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
* If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer does not sleep, standby, or hibernate during the 20-minute charging period.
4. After the iPod has charged for at least 20 minutes and while it is still connected to the power source, toggle the Hold switch again as in step 1.
5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
* If the Apple logo does not appear or the iPod is not seen in iTunes, try putting the iPod into disk mode and restoring.
6. Try putting the iPod into disk mode.
* While in disk mode, connect the iPod to iTunes and try to restore.
* If the iPod is still not recognized by iTunes, the iPod should be serviced.
See http://www.apple.com/support/ipod/ and click the Service tab for more information about your service options.
Hope it helped...
May 21, 2011 | Sony NWZ-E436F MP3 Player
Tip
What To Do If Your iPhone Or iTouch Won't Turn On
Try to reboot the iPod, just in case it has crashed
  1. Hold the top button and the home button for about ten seconds.
  2. A bug can stop the screen from displaying, sometimes you can reverse the problem by doing the reboot. If you still see nothing on the screen, try to plug the iPhone in to the computer and try the reboot method again.
If you are still unsuccessful in turning on the iPod, but the iPod shows up in iTunes, try restoring from iTunes to fix any bugs causing the issue
  1. Plug the iPod in to your PC, go into iTunes and click the iPod's icon on the left side of the screen.
  2. In the iPod Summary Screen, click on the restore button and agree to the prompt asking if you really want to restore the iPhone's software.
If you are still unsuccessful in turning on the iPod, but the iPod doesn't show up in iTunes, try putting the iPod into recovery mode
  1. You can put the iPod into recovery mode if it has a charged battery.
  2. Start by holding down the home button before connecting it to iTunes, then continue to hold the button until iTunes recognizes that the iPod's in recovery mode.
  3. Recovery mode allows you to perform a restore when you're when an iPod fails to turn on or display anything on the screen.
on Jul 16, 2010 | Audio Players & Recorders
My iphone is not turning on. It is jail broken the problem is whenever the iphone goes off i have to jailbreak it each time. Now also i have dome the samething but its not working. Its not turning on.
Jun 30, 2010 | Apple iPhone Smartphone
Why wont my ipod touch turn on i turned it off and it wont come o
Hold the power button and home button for 10 seconds to ensure the device is off. Let go.
Hold the home button down, plug in the ipod to the computer, after the screen changes to the itunes plug screen, let go of the home button.
The ipod will now be in recovery mode, and you can attempt to perform a restore within itunes.
If the restore fails, and the ipod screen stays black, this means the battery is dead and must be replaced.
Oct 22, 2009 | Apple iPod touch
My i-touch is chirping and only icon shows up on screen
take it to an apple store? or you can try pluging it in to ur computer.
Sep 04, 2009 | Apple iPod touch
My itouch is only 3 weeks old. I just charged it last night. Now when I try to turn it on nothing happens. No power or anything.
you may have to restore it....but you'll lose all your data. here's how...
  1. Verify you have iTunes 7.5 or later. Apple recommends using the latest version of iTunes.
  2. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  3. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  4. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" or you see the screen pictured below, let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
  5. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  6. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message:
Aug 19, 2009 | Apple iPod touch
My ipod nano is stuck on language selection and is frozen can you help me?
If your iPod is frozen or won't turn on, the steps to reset it vary by model.
    • If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, try putting the iPod into disk mode and restoring.
    • While in disk mode, connect the iPod to iTunes and try to restore.
    • If the iPod is still not recognized by iTunes, the iPod should be serviced.
    Hope i helped you.
Thanks.
Aug 06, 2009 | Apple Ipod Nano Second Gen. Green (4 GB)...
My white ipod wont turn on or charge
maybe when u insert the usb in the pc u just get it with out ejecting the usb because if not it has virus maybe ur pc is not protected i encouter that problem it did not on and play...
Jun 13, 2008 | Apple iPod nano
80 gig ipod
You need a new battery (iresq.com)
Mar 31, 2008 | Apple iPod MA446LL/A MP3 Player
Apple iPod MA446LL/A MP3 Player Logo
71 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
