Question about Panasonic PT-45LC12 45" Rear Projection HDTV-Ready Television
Green flashing power light and ticking noise but wont turn on
I just replaced the lamp and the tv worked for a day...went to turn on again and the fans come on but no picture or sound. I can hear a ticking noise every so often but no picture. I hear the balist goes out a lot could this be the problem? Please help!
  • 88Jimmy08 Jul 25, 2008
    The lamp looks to be in very good shape (no damage at all) broken glass; but when i put a meter to it (on the tail ends) it registers no continuity. When it stopped working, it makes a clicking noise and then worked a few more times then went back to only the clicking noise and hasnt come back on since. Is the ballast easy to fix? or could it be a thermistor/device?
  • 280 Answers
Did you touch the Lamp? If you did it may have blown. the color wheel may be the problem or yes the balist
Posted on Jul 25, 2008
  • coyotedave Jul 25, 2008
    It is a good idea to check the balist.. There is a balist kit you can get for a lot less then a new one. Also there are some fuseistors you may want to check.The set is trying to start and that is the noise you hear. Since it stoped ticking you may want to check for a open fuseistor. Its hard to say exactly when I cant see the set but it sounds like you are in the right direction
    Try thermister
    L3 TAM
    250V 5A
    Tf 115c (centigrade)
I have a 50 inch DLP samsung and it wont power on after making a lot of noise (I replaced the lamp) worked fine for a few days now the red light and the right side green light is blinking. any sugge
The answers above are correct. It's either the lamp or the color wheel. Testing the lamp is pretty straight forward. Use an Ohm meter to see if the it's filament has continuity. It's unlikely that a good color wheel would fail immediately after changing the lamp. Look to see if some wiring is out of place and rubbing the wheel causing the noise you described. A jammed but otherwise good color wheel would cause the TV to shut down and display an error code.
Sep 12, 2014 | Samsung HL-S5087W DLP TV
WD57732 purchased 12/06 and has worked fine. Turned off at 11 pm last night. No indication of trouble. Tried to turn on this morning and nothing. Did TV Reset, green light flashed for a minute like it...
Now,tv on?.Tv "LAMP" LED light indication flashes or stay on?How long the Lamp been inside this tv,been inside like 1 1/2 or 2 years and tv been on each day like 4 or 5 hours a day in used.The lamp life are over.Should replace another lamp.
Dec 10, 2010 | Mitsubishi WD-57732 Projection Television
I have Sony Wega and the picture just cut out and went to black. The sound wont come on and the TV wont even turn on. The light at the bottom of the TV flashes lamp light. We took the lamp light out and...
if u take out the lamp the green light will flash ,its not detecting a lamp at all.a bad lamp is being detected before you took it out.u will have to replace the lamp before u get a picture again
Sep 30, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Changed lamp and TV won't turn on, power light flashes 3 times
Red light blinking 3 times shows problem with lamp cover.
Lamp cover is not fixed securely in your tv after lamp replacement. Lamp cover is first thing that was removed to replace lamp, check lamp cover and make sure its back in place properly.
Jul 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a Mitsubishi WD-62725 that I purchased in February 2005. The manufacture date is November 2004. I was watching a DVD the other day and all of a sudden the picture just went black. I never received a...
It sounds Lamp got broken inside, please take out lamp from TV and check its glass tube. If found broken, replace it.
Lamp replacement procedure is written in user manual page-95, click HERE to download user manual copy if required.
Lamp is available in Part Store.
Nov 05, 2009 | Mitsubishi WD-62725 62" Rear Projection...
No Picture - Lamp Indicator Blinking
This may be the main power supply, or the lamp supply. This is providing that the new lamp is okay.
The service tech will swap out the modules to service the set.
Jerry G.
May 15, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Lamp problem or else?
You need to get the ballast repair kit #LSUC0002 and replace the parts to your ballast.
I have the exact same TV, did the above this past weekend, and the TV works like new.
You need to know how to solder though. It's not that hard.
Mar 14, 2008 | Panasonic PT-60LC13 Television
Panasonic PT-45LC12 45" Rear Projection HDTV-Ready Television Logo
321 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
