Question about Sewing Machines
Button hole problem
I can't seem to get the machine to make a button hole. I'm using the sliding button hole foot, and it sews one side down then when I switch my stitch selector from 1, to 4__2, the needle goes up and  down in the same spot, then i tried from there to change the stitch selector to 3 and the line continues up the first line I've just sewed. I think that the 4__2 stitch is supposed to make a horizontal line, but I'm not sure if I'm supposed to move the fabric, it seems as though it won't let me so I didn't want to force it, am I missing something, or is my machine broken?
  • laraberenji Jul 29, 2008
    Thank you for your advice, I tried to watch the mechanism my self and I think because I moved it so many time, it loosened whatever was making it stick. So I'm happy to report that the machine's button hole selection works now. Thanks again.
  • ahum132 Nov 03, 2008
    i have the same problem. I haven't used it in months but the last time I did, it made buttonholes without a problem. I tried doing all the steps over again multile times, turning the stitch type multiple times thinking maybe it was off a little etc...but it just stitches in the same moving at all. I have only had it less than a year and I have only used it a hand full of times.
  • 202 Answers
What ever you do DON'T FORCE IT. I see these problems when a buttonhole mechanism hasn't been used for a long time or the machine has been dropped. There is a cam follower (like a finger) that changes positions when you turn the knob. This could be out of place and a tech will have to go in and fix it.
OR old oil has hardend from non-use or grime has acumulated in the mechanism and jamming it up. I sometimes have luck cleaning it with Tri-Flow oil (hardware stores) but again this may be a tech job also.
Posted on Jul 27, 2008
Elna SU buttonhole- I can't remember the order to set the dials for the automatic button hole function. Anyone know? Thanks
sure, put on the buttonhole foot after putting a button into it and using the screw knob to set the length you want.
Turn stitch length knob and stitch width knobs to zero, (always set them to zero first to avoid wear on the stitch selection mechanisim) then turn the left stitch selector knob to the blue button hole symbol. Now turn middle knob stitch width, to the blue buttonhole symbol. Now turn right knob stitch length to blue 1, sew down the first side of your buttonhole until foot slide in the buttonhole foot reaches end stop. raise needle and turn stitch length to blue 2, and sew three bar tacks across buttonhole. Again, raise needle and then turn stitch length to blue 3 and sew back down otherside of buttonhole until you reach the end stop. Needle up, turn length know to blue 4 and sew three bartacks to end. there is a last blue symbol dot on stitch length knob, this will sew a stitch in place to tie off the ends. Raise pressure foot, remove your work and draw top threads to underside with a needle, and tie off or use a dot of fray stop. Done! if you don't have a manual you could email me and I'll send you a copy of mine, tallygirl98 at yahoo dot com.
Oct 11, 2013 | Elna 2007 Mechanical Sewing Machine
Cannot reset buttonhole size
Assuming its a singer domestic machine
1.For a 1 step buttonhole, you will need to place and lock the actual button at the buttonhole foot holder(back end of the foot), the size will remain the same each time you sew a button hole.
2.For a 4 step buttonhole, the size is determine by sliding the foot against the line/marker which you can see on the foot itself each time you start to sew the button hole.
Aug 21, 2013 | Sewing Machines
How do you use the sliding button hole attatchment
attach the sliding foot by clipping off the current one, placing the sliding food onto the needle plate, lining up the clip with the attchment point and lowering the pressure foot down onto it so it clicks in.
Now, does your machine have a little lever device to the left and just behind the pressure foot, have a look for it. If yes, then pull it down, this is the buttonholing trigger and it connects with the sliding foot to trigger the reverse and stitching of the second side.
Program the machine for button holing, this might be pushing in a numbered code, on my 6500 there are five buttonholes and they each have a code that I enter.
Place your fabric test sample under the pressure foot and put the button into the back of the pressure foot, there is a little ratchet device that closes up holding the button firmly to get the right dimensions.
I always do at least 2 test buttonholes using same fabric, usually 2 layers with interfacing between.
Start the buttonholing sequence by pressing on your machines foot control, it should sew backwards away from you down the first side of the buttonhole, and the trigger should connect with a bit on the slide foot triggering the machine to stop, sew the bar tack, and then reverse and sew the otherside and final bar tack.
That's how it goes on my 6500, I hope this applies to your MC10000 too, it should be very similar. Your machine probably has at least 3 or 4 different types of buttonholes it can do. If you don't have a manual for it, it probably is worth sources one as these machines have lots of features to use.
Jun 12, 2011 | Janome Memory Craft 10000
One step buttonhole help!!
On my machines, the one step button hole requires a pull down sensor that the button hole foot triggers when it has done one side. You put the button in the holder part of the button hole foot, set up with sensor and start to sew, being careful not to touch the trigger, then the machine will sew the required length, change stitch and then do other side. Maybe there's a demo on you tube ? I hope this helps
Sep 04, 2010 | Janome Sewist 525S Mechanical Sewing...
The machine keeps giving me an error message with a diagram showing the foot should be down. It is, but it won't sew anything. I can thread a bobbin, so I know there is power to the machine. Also, when...
that presser foot with that black thing that is just flopping around... well when the presser foot is down that thing should be locked into the side hole. when you have the presser foot up, put it into the side hole, fiddle with it, move it around til you find that hole, then drop the presser foot it should be locked on it now. That T presser foot needs that.
Aug 23, 2010 | Euro-Pro Sewing Machines
Hello, I just got a remington super deluxe zigzag 141 machine. I can't get it out of button hole mode? I also am looking for a manual. It seems to work well, just wants to sew like it is doing a button...
push down on the lever ro the right of the button hole selector until it says manual. that's for straight stitching. i have the same machine.
Oct 12, 2009 | Sewing Machines
My button holes aren't consistent -backing up doesn't work proper
It sounds as though you are using the Memory button hole setting which sews the BH forward on one side(leg of the button hole ) and backward on the other side. You have button holes on Numbers 11-16. I think #16 is the one you are trying to use but the others are easier. Put the button in the special foot, pull the BH lever down( It is located on the left side of the machine towards the rear of the machine ).Select #11 and the machine should sew both legs in the same direction. This machine has always made great button holes.
Apr 01, 2009 | Janome Memory Craft 9000 Computerized...
Attaching fit button-hole foot?
Just pull down on the original metal foot. It will snap off and then you can snap on the button hole foot. Good luck!
Nov 17, 2008 | Necchi 3537 Mechanical Sewing Machine
I have emerald 183 and i can't figure out how to use the buttonhole feature. it keeps sewing just one side. also where exactly do i put the button?
Make sure you have pull down the arm that will engage the button hole mechaizm. Put a button in the back of you button hole foot, attach foot, reach up on the left side just below the light and pull the lever down, choose the button hole , lower tension to 3 and sew out the button hole. The button hole foot should push on the arm when it gets to the end and complete the rest of the button hole. If the columns do not match then it has to be serviced by a husqvarna dealer.
Sew Technologist
Apr 21, 2008 | Euro-Pro 8260 Mechanical Sewing Machine
Buttonhole problem
When doing the button hole....after installing the button hole foot and lowering the foot....and adding the button so the automatic button hole size is lower the button hole lever it will touch the back of the button hole foot. this holds the button hole foot in the proper position...if this lever is not all the way down...the machine blips at you...check to see that it is down all the way...I hope this helps you..It truly does all that it advertises and is a great machine...BBill01
P.S. you can adjust width and length of the stich also...see instruction manual. pg 28-30
Jan 06, 2007 | Juki HZL-E80 Computerized Sewing Machine
Sewing Machines Logo
304 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
