Question about Freezers
Constantly running deep freezer
Our Gibson Model GFC15M4AW4 Chest style deep freezer runs non-stop. This is not affecting the contents of the freezer; however, it wastes electricity. Does this mean the relay needs to be replaced? Or, the temperature control? Or something entirely different??? Can this be diagnosed without calling a appliance repair person (live in rural location and they charge a fortune to make house calls). Thanks in advance for any help.
  • joeg5 Sep 07, 2008
    Jmoved to a new house and after moving small chest freezer it runs constantly. It is full of product but I`m sure our electric bill will reflect the constant running. I have unplugged for up to 8 hours sevral times and product stayed frozen but when I plugged it back in it still does not shut off.
    'Thanks
2 Suggested Answers
  • 112 Answers
SOURCE: Can't find the temperature control on my Gibson
its probable at the back down near the compressor just under the cabinet
Posted on Jul 26, 2010
Where are the cooling lines for a frigidaire chest freezer model#GLFC2027FW6?
they run around the entire perimeter... Just put something heavy on the top of it.
Aug 09, 2014 | Frigidaire 13 cu. ft. / 368 liter Chest...
Red light is on all the time, wont stop running
Some freezers have a pilot light that is constantly on whenever power is being applied. If the compressor seem to run constantly, check for a bad lid seal. Also, the thermostat may at may be defective
Jul 19, 2013 | Magic Chef 5 cu. ft. / 142 liter Chest...
My kenmore chest freezer is the garage, the temperature outside is over 30 celsius, the side of the freezer where the motor is is very hot, and some other places on the front and other side is warm to the...
The hot sides is normal, this is how they expel the heat from inside the freezer, sometimes it may help to use a fan to help cool. Also make sure there is about 12" of room around all sides of the freezer .
Aug 22, 2017 | Kenmore 14.8 cu. ft. / 419 liter Chest...
I have a woods chest style deep freeze and the lid is very cold on the outside, but the sides are room temperature and the freezer works fine. Why is the lid cold and how can I fix it
Yes, the freezer temperature means the lid gets very cold. Every time you open it some moisture condenses in the lid and the outside ambient also affects it. The insulation may be beginning to break down and the ice is forming inside. It is not a major problem however and many freezers go on for years with freezing lids!
Apr 18, 2012 | Woods Chest Freezer C1501W3
Can't find the temperature control on my Gibson "8" chest-style deep freeze.
Jul 26, 2010 | Freezers
Frigidaire Deluxe Chest Freezer is constantly
Two things to check without knowing the model number.
It is possible the drain plug was left out or not inserted correctly after defrosting and it is leaking..
Also there is sometimes an evaporator pan with a heater element on the bottom. If the heater element failed the evaporator pan would overflow.
May 02, 2009 | Frigidaire 9 cu. ft. / 255 liter Chest...
Red light on not cold enouth
The red light bis indicating that the temp is too high, if you can ,turn the thermostat to a colder setting, if this makes no difference, then you have a serious problem, you will have to call an engineer.
Plz rate this solution,
Thanks.
Dec 06, 2008 | Hotpoint 4.87 cu. ft. / 138 liter Upright...
Chest freezer won't restart
Probably bad thermostat- jump it out and see if it starts. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 21, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Feb 19, 2008 | Kenmore 22.7 cu. ft. / 643 liter Chest...
GIBSON DEEP FREEZE IS RUNNING BUT EVERYTHING IS THAWING OUT
Might try unplugging for a few hours and then plug it back in. There is a possibility that it slugged the compressor and there is a restriction in the line. Sometimes when the compressor fails to stop running in cold air the liquid gets back to the compressor. It can cause a bit of gunk to be picked up out of the oil and carried to the expansion line and plug up the line. Maybe turning it off will let the plug fall free and not replug the line. Worth a try anyway.....
Feb 07, 2008 | Freezers
Freezers Logo
298 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
