Question about Sharp EL-1801AII Calculator
Manual Someone gave me this adding machine but I have no idea how it works to just add and subtract for starters. I need a manual
  • mknoch67 Jul 25, 2008
    Someone gave me a SHARP EL-1801AII adding machine but I have no idea how it works to just add and subtract for starters. I need a manual. Can anyone help me?
  • Lynarnone61 Feb 04, 2009
    i have the sharp el-1801 a and cannot put paper through the feed. Lost the original manual. can someone help me
How do I subtract on Sharp EL-180 1V calculator?
Posted on Feb 27, 2010
BorrowR50from mom and R50fromdad=R100 PayR97forT-shirt = R3. Give Mom R1, gave dad R1 back and I kept R1. Still owns Mom R49 and Dad R49. But R49 + R49 = R98 plus my R1 = R99. Where is the other R1???
why would you add your R1 but subtract their R1 ?
You state R50 minus R1 comes to R49 for both and then you add your R1 ?
So if you gave your R1 to Mum and Dad you would subtract 0.50 from what you owe them .
Being 48.5 plus 48.5 and this equals R47
So the R1 is in your pocket as with a credit account it works opposite to a debit account.
In a credit account payments in are subtracted (basic accounting )
Withdrawals are added to account balance.
It is opposite to a savings account
Mar 14, 2017 | The Computers & Internet
My TI-5130 will not add and subtract
It probably uses adding machine logic. Try the following example.
3+
4-
5+
You should get 3, -1, and 4 on the screen, the running total. The tape should show the +3, -4, +5, and finally 4, the numbers that you entered and the total. Think of each entry as adding/subtracting integers on a number line rather than 3+4-5;)
Let me know if you have any questions.
Paul
Feb 04, 2016 | Office Equipment & Supplies
What are the setting for simple addition and subtraction. I also need it to print it for me
The manual mentions an add mode, turning the calculator into an adding machine.
If this is the case, you can do this test and see if it works to confirm that it is acting like an adding machine.
4+
3-
5+
Think of these as integers. The 4 is positive, the 3 is negative, the 5 is positive. When we add all these integers together, we get positive 6.
Good luck.
Paul
Sep 23, 2015 | Sharp EL-1801P Calculator
How can I get my sharp calculator to add and subtract correctly?
Could it be that it has adding machine logic and not calculator logic?
Let's do an experiment. 3+ 3+ 5-. Is the answer 1?
If so, it is working like an adding machine. Every number you enter is considered positive or negative and it keeps a running total.
Good luck.
Paul
Feb 25, 2015 | Sharp "el-2630piii desktop calculator,...
Luke wants to find the difference 175 - 134. He has subtracted the hundreds and tens so far. What is the sum of the two numbers he has subtracted? How much does he still need to subtract?
SUM means adding not subtracting. so if you were wanting to add the total (the sum) of the amounts of the hundreds and the tens would be 170 plus 130 which would be 300 but the remainder from subtracting 130 from 170 would be 40. That would leave the single units 5 minus 4 of which the remainder is 1. So, the remainder from subtracting 134 from 175 is the reminder of subtracting the one hundred from the one hundred which is zero added to the remainder of subtracting the tens (70 minus 30) which is the remainder of 40 plus the remainder of subtracting the units of 5 minus 4 which is 1. So you need to add the 0 and the 40 and 1 which is the remaining sum of 41.
Sep 19, 2014 | Office Equipment & Supplies
I have a VPT24-1PZ 24 hour programmable timer.My question relates to after you progam the astronomic clock there is an off set option to add or subtract time from the sunup/sundown time.By pushing the up...
The timer lets you adjust the preset astronomic time for your area.
This is because actual local times vary.
If the preset time for dusk is 8:00pm and you add 12 minutes, then the timer will turn off-or-on at 8:12.
And then you can change the preset time for dawn by adding or subtracting.
If this is not what exactly you are asking, then set your timer and see what happens, and then add a comment with your findings.
Open following link to download on-line manual
http://waterheatertimer.org/Leviton-timers.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 02, 2011 | Leviton Hardware & Accessories
My calculator will add, but after my total and then I want to subtract, it subtracts by the number I added.
If your calculator is more of an adding machine it works a little bit differently than a calculator. For an example: 10 + 5 - 2 on your machine do the addition of 10 + 5, then to subtract the 2 press 2 then the minus sign to get the total of 13. I hope this is helpful.
Feb 06, 2011 | Canon Office Equipment & Supplies
I can't seem to do simple subtraction with my Victor 1208-2. When I subtract say 5-4, I get a negative 9. Is there a setting or do I need to press something different to get simple subtraction to work?
When you want to complete a problem on an adding machine, such as "7 - 3," you would not key in "7," then the subtraction sign, then "3" and then an equal sign. If you do, then you will get an answer of "-4," and you know that is not the correct answer. Again, you have to think like an accountant when you are working with your adding machine. To figure this subtraction problem on an adding machine, you would need to key in "7," the addition sign, "3" and then the subtraction sign; you would get the answer of 4. You are actually working the problem as "7 + (-3)." This would be true on most modern day machines. In order to subtract, you have to add the negative number.
Sep 25, 2009 | Victor 1208-2 Calculator
Tring to subtract
With an adding machine, which is what this is, you enter the number followed by the + or -. If you wanted to add 10+20, you would enter 10 then + then 20 then +. This would show your answer. If you are using the printer and you wish to see the final answer on the paper, hit the * key and your answer will print.
If you are subtracting, let's say 100-40, you would enter 100 then + then 40 then - then *. Adding machines expect you to enter long strings of numbers to total. You may have both positive and negative numbers. So, you always enter the number first followed by either positive + or negative -.
You might have 100 + 25 - 37 - 1 + 50. For that enter:
100+25+37-1-50+ then *
Different than a calculator but the same for all "adding machines". This machine should really be called an adding machine since that is the kind of input it is looking for.
Jan 13, 2009 | Canon P23-DHV Calculator
Adding and subtracting lengths of measurements
You can use the units menu (2nd > 3) to place a unit after some number you want to qualify as being an unit, or you can just type them in like 5_ft + 6_in. Note that you need to add on each part if you are doing mixed measurements; there is no _ft_in combination. So just add each manually - in your case you would do (5_ft + 6_in) - (2_ft + 8_in)
Oct 14, 2008 | Texas Instruments TI-89 Calculator
Sharp EL-1801AII Calculator Logo
680 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
