Question about Hitachi 60SDX88B 60" Rear Projection Television
Hitachi 60sdx88b convergence problem IC
I had a problem with convergence a couple of years ago and the repair man changed out the IC (interconnectivity Chips?) and he left them behind. I am having convergenc problems again and I called him and he said it was most likely these IC's again and would cost about $300 to fix. I pulled the back cover off to try to find these chips but I can not see them anywhere. My only thought is that they are inside of one of the metal boxes connected to a circuit board. Can anyone tell me where exactly they are located and how to take them out to change them. I am pretty handy and my tv is not worth that much now so I would like to try to fix this on my own first.
Thanks,
Shawn
  • sokiboi23 Nov 20, 2008
    my tv will not power on at all. it was on we left the room and when we came back the tv was off (red light was on) tried to power on, cut power tried again, to no avail. removed back panel and looked around, found the deflection board has a led dp23 not illuminating when powered up. when i plug the tv in you can hear the "click" red power light comes on but no picture or sound. I went out and bought an air can duster and aired it.. pluged in and it work.. then same thing would happen again it seem like the prtect light that won't stay on,, it blinks.... PLASE HELP!!!!
When you pull off the lower half back of the t.v. the grids are in 3 sections (boards). Look at the right board the chips will be right front corner , they are attached to a heat sink ( big silver thing with cooloing fins) You must disconnect all wires ( color the connector and plug with different color markers so it is easy to re-connect when done.) There are sites that show step by step pics how to do
Posted on Aug 02, 2008
Just keeps flippn like the vertical hold not workinright but not with every channel
lizsmith319,
Have a repair guy in and have him look at your Horizontal circuitry and replace a few Transitors and Maybe (don't tell him) a IC.
If you tell him... he will change it and charge you alot. The changing of transistors 50-60 bucks
IC's 100 - 200 bucks
You see why (Don't tell Him)
Nov 02, 2010 | Hitachi 60SDX88B 60" Rear Projection...
I purchased a tv repair kit and replaced the convergence ic chips to fix my convergence problem. put everything back together and now, no picture. I tried magic focus and it works great, the colors are...
As per statement, "the magic focus works great, the colors are bright and aligned" it means the tubes are working ..you need feed a signal to see the picture...the tv video goes muted without signal
Dec 29, 2009 | Hitachi 60SDX88B 60" Rear Projection...
60" hitachi 60SDX88B screen shows some green distortions in the top and bottom of the screen. Magic focus does not fix this. Help?
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 21, 2009 | Hitachi 60SDX88B 60" Rear Projection...
The image of my 53sbx10b are double after few minute
Replace convergence ics. Hitachi has a ki for this consisting of STK-395-110 ic and some resistors.
Apr 13, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 60sdx88b
i will try to help you on that one too as soon as I can get a repair case history on that particular model.
Jan 27, 2009 | Hitachi 60SDX88B 60" Rear Projection...
Convergence problem
YOU HAVE TO REPLACE IC BECAUSE IT IS BAD THE ICS NUMBER HAS CHANGE FOR STK392-110 TO STK392-150 THEY WILL SYAN MORE HEAT
Oct 13, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Red horizonal convergence tilts instead of adjusting evenly.
For your hitachi unit one of the convergence IC is bad along with couple of low value resistance on
the convrgence board.
Good luck
Dals123
Oct 09, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Hitachi 60SDX88BA Convergence IC - How to remove from heatsink
most of those have screws down one side of the heatsink going into the PC board and other models you have to unscrew the ics through the fins on the heat sink.
Jun 20, 2008 | Hitachi 60SDX88B 60" Rear Projection...
Red deflection is way off, picture scrunched into top right corner
call 800-648-6657 order part number CZ01341. This is the convergence output ic. You will need to replace the red convergence output ic IK04.
Dec 27, 2007 | Hitachi 60SDX88B 60" Rear Projection...
Hitachi 60SDX88B 60" Rear Projection Television Logo
60 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
