My printer says there is a paper jam and will not print. I have checked everything and tried to reset it put it still says there is a jam even though there isn't.
  • Matt D May 11, 2010
    May I get a brand?
Called HP. They are sending me a new replacement printer.
Posted on Jul 28, 2008
My samsung scx-4623f always "paper jam in exit area" every time i print even though i always put out the jammed paper in the exit area.
While Samsung SCX-4623f printer always "paper jam in exit area" you get paper checks or trigger sensor paper cup
cong ty bao ve support
good luck
Jul 07, 2014 | Samsung SCX4623F Laser All-in-One Printer
My printer says it has a paper jam, even though the paper jam has been cleared. It won't print. Any ideas?
Hi, Try pulling out the plug for 1 hour and then try again. Pulling the plug may reset the printer.
Good luck.
Jun 27, 2011 | HP DeskJet 3740 InkJet Printer
Red "Paper" light stays on; printer will not print.
Paper light flashing could mean several things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. You can also check in between the drum and toner by removing the toner from the drum. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 11, 2010 | Brother HL-2040 Laser Printer
Error paper jam
You should go to the website of whoever manufactures your printer. They always have drivers for their printers that you should be able to download and install in just a few minutes.
If you're absolutely, 100% sure that there is no paper jam, I would recommend just unplugging and restarting the printer.
Also, it may read a paper jam if you insert too much paper at one time. If you have a lot of paper installed in the printer, try taking out all but 10 sheets, and retry printing. My printer has a tray that accepts 150 sheets, but it "jams" if you put even close to that many in.
You should make sure that you aren't putting the paper too far in as well. Try pulling it back a few millimeters, as it may read a jam if the paper is pushed into the printing area.
Jun 22, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Canon ip4300 Error code 1300
u have to reset ur printer try to hold ur finger on power button for more than 15 sec then turn it on again
Jun 09, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Printer paused-unable to read
HI there,
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
Oct 04, 2008 | Brother HL-2070N Laser Printer
22 people viewed this question
k24674
jasbo
jasbo
