F3 Mag Cur??? Our oven has broken down with this error code three times in the past two months. Is this happening with anyone else? 1 comment. share. save.
... causes are the solid state relay (NGC-3005), high limit thermostat (102075), heater wire service kit (NGC-3089), and top heater (NGC-3011). F3 Mag Current.
ur high limit trip because ur heater overshoots the program setting for the temp replace ur k4/k5 solid state relay for it controls ur temp for the heater.
In both the cases you have forgotten to mention the main issue the make and model of the Oven.
It is also a fact that your will not receive technical manuals but only the owners manual with the oven unless you have to pay for the same.
Check the IR element. check the heaters. check the high limit switch on the back of the oven. Usually the IR element will have burned wires where it enters the oven and will need replacing.
the subway ovens are supposed to be around 1000 dont change any of the settings if you think you are having programming issues speak to your field rep and ask them to reprogram your oven. they have a smart card for doing this. it will give you all the latest buttons including hashbrowns and breakfast stuff.
most common problem with toasting to dark is that you are using the wrong buttons
try cooking the next sandwich on the 1meat hotwell setting and select the sandwich size. you will notice the sandwich cooks much lighter.
if you cook using the combo subs button this could be your problem. most of the time re-training is just needed
