Question about Samsung YP-Z5 MP3 Player
Unit won't work when disconnected from usb on computer
Unit will not work, dead when disconnected form USB. Works fine while connected to computer all functions and touchpad, but when disconnected it is dead, battery shows fully charged, opened and checked with voltmeter 7.3 volts. Not a very mobile unit now, unit new out of box, of EBAY sealed..
  • Anonymous Feb 17, 2009
    my ipod will turn on and everything when connected to computer. but when i disconnect it, it will not turn on or anything, all i get is a black screen.
Danm it ! dead when disconnected form USB
Posted on Oct 09, 2008
Why people use a usb
USB is a very convenient standard that is simple to use for connecting devices by wire. Most devices can be swapped in and out with the power turned on. It is a type of hot connect and disconnect. There are exceptions for this depending on the type of device.
I have printers, scanners, external drives, modems, headsets, thumb drives, and some smart phones that connect by USB. Simply connect and do the job. When finished simply disconnect the device and get on your way.
Starting in 2016 there may be some new computers coming out where it can work with multiple devices using a form of wireless system that works as simple as USB once the devices have been mated with the computer. The system will work something like Bluetooth, but more refined and can work with multiple devices.
May 25, 2014 | Computers & Internet
Dead nokia 2700 classic usb connection disconnects automatically ?
1. Please make sure your USB cable is working fine. better to connect your phone using another USB cable.
2. Change the phone's battery, or make sure its more than 80% charged and in good condition.
3. Try to connect with different USB Port on your PC.
Hope your problem will be solved.
thanks
Dec 02, 2012 | Nokia Classic 2700 Cell Phone
Dc5700 won't connect usb mouse and keyboard after disconnect
why run dead XP?, is the PC ONLINE? or off/?
The USB plug and play is failing,
you do know MS killed dead Plug and Play for XP 4 years ago right?
the top failure of any pc running XP would be USB devices.
USB devices are extensive in scope, endless types
and top of the list are mice, and keyboards.(vast types exist))
The PnP engine scans the local driver cache first.
if no mouse (example 1) is found to match your unstated mouse
then it must do what? go on line, to MS.com
and MS pulled the plug..... just like they did
on
w95
w98
ME
W2000 and vista. and XP 4+ years ago !
time to upgrade, for sure.
a counter argument would be that the virus magnet XP is infected.
as ALL ARE NOW and worse every day forward!! for eternity
Feb 07, 2018 | HP Compaq dc5700 Microtower - Free Flat...
Nikon coolpix s220 - USB device not recognized. The USB is fine since it works with other devices and the USB cord is fine since it works on a different computer. I tried a driver update but I get a...
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Sep 03, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
When printer connected to pc is showing usb device not recgnised in windows xp
two things to try
  1. try using another usb port ( preferably one on the back of the pc)
  2. switch out usb cable with another
Sep 24, 2010 | Office Equipment & Supplies
Lacie do not start
If it still is under warranty, then exercise the warranty, and get it repaired/replaced.
If it's out-of-warranty, then disassemble the case, and disconnect the disk-drive from the USB-to-disk-drive adapter.
Connect the disk-drive as a "slave" disk-drive in a desktop computer, and see if the disk-drive still works.
If it's dead, it's dead, unless you pay mega-dollars to a professional "Data Recovery Service" to rescue your files.
If it is dead, then buy another disk-drive that is compatible with that USB-to-disk-drive adapter, and reassemble the unit, and you'll have a brand-new external drive that you can use.
May 29, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
USB Audio Device Drive Load Failure
Driver probably needs update. I had this problem using my usb speakers until updating driver to newest version.
Dec 21, 2008 | Logitech V20 Computer Speakers
My Garmin Etrex wont turn on on batteries but it works fine on external usb power.
I have the same problem. The unit works until I connect it to whatever computer via USB (Mac or PC). The screen blanks out as soon as I plug in the USB cable. I have to disconnect the device and only then I am able to turn it on again. That started after Firmware update from V 2.90 to 3.00 . I am not sure this is causing problem. What about the firmware versions of your devices ? Are they all on the latest ?
However, does anybody know if there is a way to go back to firmware version 2.9 if it is not possible anymore to connect the device to any computer (evtl. through putting data on the microSD card ?).
Thanks,
Martin
Jul 04, 2008 | Garmin eTrex Legend Cx GPS Receiver
Computer doesn't recognize unit when connected
Hi All,
I had the same problem and was going crazy trying to figure this out, but I found that I had installed the GPX mw3816 on my bottom USB port and was trying to plug it into the port above it, because I had plugged another unit into the bottom port, but I switched the ports and it immediately installed. This is another reason, I am thinking of dumping windows and moving to a MAC. Peace!
Aug 13, 2007 | Samsung YP-T8 Digital Media Player
Samsung YP-Z5 MP3 Player Logo
224 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
