Question about Lexmark X4270 All-In-One InkJet Printer
Says comp. not comunicating with printer
When I try to print a window comes up with that message. I tryed restarting I turned firewall off
  • 3 more comments
  • mamagoat Jul 25, 2008
    the message on my comp says it cannot communicate with printer. help
  • Anonymous Jul 31, 2008
    lexmarkx4270 all-in-one is not responding to windows vista program
    not communicating with with printer problem.
  • SHIRLEY36078 Aug 02, 2008
    I have uninstalled and tried to restall but i continue to get the message that the printer is not communicating with the computer. Now I can't restall. I have check the cable connections and all and nothing has worked.
  • dgoble002 Aug 04, 2008
    i have the same problem and can not find out how to fix it. i can get faxes and can copy and scan but will not print. someone please help.
Try changing de usb cable.
It works!
Posted on Aug 08, 2008
  • immorttal Aug 08, 2008
    Try changing the usb cable.
    It worked to me!
    Good lucky!
When i try to print something a window pops up that says "communication not available" ive tried restarting, unpluging the power cord and the usb cord...nothing seems to work
This problem could be caused by several factors - incorrect USB port selection, your printer is not set as your default printer, firewall, etc. This article in the Lexmark website: Communication Not Available' Error Message and Print Job Stalls in Print Queue will help you determine the cause and resolve your printing issue.
May 11, 2011 | Lexmark X2600 InkJet Printer
Hi, I have a printer Lexmark X2250 All-in-one. My computer can't connect with the printer. When I try to print something I get a message: 'The printer cannot comunicate with the computer'. I...
According to your problem first check that you have installed the driver properly or reinstall the driver. Check the USB cable of the printer. Replace the cable. Turn the printer off before installing the driver. Turn it on again while the driver installation wizard will ask to connect the printer. After installation reboot the printer and system both.
May 06, 2011 | Lexmark X2250 All-In-One InkJet Printer
No comunication to computor won't print
You can try to:
- turn off the printer and turn it back on - Unplug and replug both ends of the usb cable connecting your printer and your computer - turn off the firewall - reinstall the printer driver
Dec 31, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
HPOfficejet Pro 8500 Wireless - need to open port 427 -Norton 360
hi first of all I would like to inform you that you have one of the best printers of HP now the open port error 427 that you get is generally due to blockage in network or firewall so we need to first check weather the printer is successfully connected to the network or not so press setup on printer go to network and then go to print network config page it will be on view network settings now note the ipaddress on the wireless tab of the page open a internet explorer and then type the ip address in the address bar and hit enter the printer page should open up if it does that means the printer is on network now turn off nortan firewall and turn on windows firewall now click on the add exception tab of windows firewall it vista it will be allow a programs through windows firewall now click on add port and in port name type the ip address of the printer in port number type 427 and then select udp ot tcp according to the error message you get in the installation if its udp select udp if tcp select tcp now in windows firewall click on allow programs through firewall and then in exception tab check all the entries related to hp apply and ok now restart the computer now try to install
if still you get the same error
click next if you have next highlighted and go to the next step and select the third option from the screen that will be contiue installing the printer
complete the installation
if the next is not highlighted then add an exception in nortan as well for guidelines open and in the search bar type c01633677 and open the document select nortan and see the instruction to add exception
if still problem persists let us know
Aug 23, 2009 | HP Photosmart C4580 All-in-One InkJet...
Lexmark 9350 don't recognise the computers when trying to scan
1. If you use buttons on the printer to scan, check your firewall settings. Make sure the "program control" settings allow the printer files. Google your firewall and printer model to get the file names and specific instructions.
2. Check your firewall settings anyway (program control and trust control -- ip address of printer should be trusted).
3. You said your printer worked for a few days. If you're running Spybot on all your computers that might explain why your printer drivers worked for a while and quit. Spybot is a good program, but it sometimes displays scary messages about something having tried to change the registry. The message comes up on a restart--sometimes several days after installing a good program. User selecting "no" disables newly installed (good) program.
If all else fails reinstall the driver on every machine, restart immediately and pay close attention to any firewall or spybot quesions. Search your computer, then Google anything you're asked before answering it.
Hope one of these helps solve your problem.
Mar 11, 2009 | Lexmark X9350 All-In-One InkJet Printer
Dell photo 926 printer communication problem
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Oct 05, 2008 | Dell 926 All-In-One InkJet Printer
Lexmark x4580 connected via USB will allow printing once when computer started after that comuunication problem error received every time. I have checked all firewall settings on Mcaffee and Windows (all...
1) Disable both firewalls and see if it prints.
2) If it prints, then it's a firewall roblem. Enable your Windows firewall first. If your printer works just leave the McAfee firewall disabled. You don't need both anyway but leave the ant-virus enabled.
3) If it doesn't print with your Windows firewall enabled, try it the other way. Windows firewall disabled, McAfee enabled.
4) If it doesn't print in any of these cases try re-installing the software for your printer.You will want to make sure that McAfee is totally disabled (anti-virus and firewall) and turn off off your Windows firewall. Here are the steps for re-installing software. If you don't have the cd let me know and I'll provide you with a link for it.
Removing and reinstalling the software
If the printer is not functioning properly, or if a communications error message appears when you try to use the
printer, you may need to remove and reinstall the printer software.
1 Click Start �� Programs or All Programs �� Lexmark 3500-4500 Series.
2 Select Uninstall.
3 Follow the instructions on the computer screen to remove the printer software.
4 Restart the computer before reinstalling the printer software.
5 Click Cancel on all New Hardware Found screens.
6 Insert the CD, and then follow the instructions on the computer screen to reinstall the software.
Note: If the install screen does not appear automatically after you restart your computer, click Start �� Run, and
then type D:\setup, where D is the letter of your CD-ROM drive.
If this fixes your problem please rate this as fixed. If it doesn't and you need more help just add a comment and I'll be glad to help you out' I'll be waiting to see how it turns out. Thanks.
Apr 10, 2008 | Office Equipment & Supplies
Lexmark Printer Install - No Communication Error
1st -make sure that the USB cable is connected on the correct port of your printer - you might be plugging it on the ports of the telephone - you got 3 ports there - 2 for the telephone ports and 1 for the USB
2nd- check your service if print spooler and lx devices are started (lexbce or lxdcu) - if not.... start it
>start >run>type services.msc > enter
3rd- if still no go - uninstall your driver and download windows vista x64 printer driver on their website
Jan 13, 2008 | Lexmark X5470 All-In-One InkJet Printer
No comunication
witch errorr messages comes up???
Nov 04, 2007 | Lexmark Z617 InkJet Photo Printer
Lexmark X4270 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
