Question about Panasonic Microwave Ovens
I have a Panasonic Inverter Microwave Model #NN-H665WF and my daughter accidently put a whisk inside a bowl inside the machine and turned it on. It left a burn mark on the inside. Is the microwave still usable?
  • Panasonic Master
  • 9,098 Answers
Yes, but the burned mark should be cleaned and if necessary sanded smooth and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 28, 2008
Panasonic microwave convection oven model NN-CD997S works normal but stop heating
Judging from the model and without looking it up I expect that unit has an inverter. If it is not the Switches and you have replaced the mag, the inverter is the power supply for the mag to work so either mag not getting power from inverter or inverter not getting signals from main PCB Timer board.
Jul 03, 2017 | Panasonic Microwave Ovens
Panisonic inverter microwave lights up but doesn't fully come on
How to fix microwave that counts down but does not heat or ...
? 4:51
Oct 2, 2012 - Uploaded by G-Unit_YouTuber
How to fix frigidaire microwave door sensor relay switch. ... with a different part number (D3V-16G-2C25) but it doesn't look like it's stocked. ... Problem now is that when we open the door, themicrowave comes on by itself! ... I am not sure, when you hooked up the volt meter, did the lights turn on and off ...
All comments on Fixing Panasonic inverter microwaves ...
i have a nn-h965wfx the light comes on the countdown initiates but nothing comes .....I have a similar full size panasonic inverter microwave NN-L931BF built in ..... After putting it all back together the thing doesn't even power up the display.
Panasonic 1200W 1.2 Cu. Ft. Countertop Microwave Oven ..., Inc.Ft. Countertop Microwave Oven with Inverter Technology NN-SN661S Stainless at ... The microwave panini meals even end up with toasted crisp bread. ...But, right now, I find the interior light functionality just fine. .... (1) In this Panasonic, the light doesn't come on when the door is open; it only comes on when ...
Jan 05, 2016 | Microwave Ovens
Change light bulb panasonic inverter nn-h965bf
We recommend you have an authorized service center location replace the light bulb. Authorized service centers can be found in the below link.
Welcome to Panasonic Online Repair
Mar 23, 2014 | Panasonic NNH965BF Microwave Oven
Popping sound coming from my panasonic NNCD997S
The following works better if done in "low light".
Put a cup of water or small bowl in the unit, close the door and turn the microwave on.
If there is anything that you can see in the cooking area, there should be sparking and it is coming from something metal, even a small piece of aluminum foil that was left behind. The thing causing the sparking needs to be removed.
If you hear the noise and it is coming from inside the area of the microwave that you cannot see then you can:
1 - Take it to a repair shop.
2 - Depending upon the cost for repair, consider buying a replacement.
If the noise is inside the machine DO NOT CONTINUE TO USE IT. Get it FIXED OR REPLACED for your own safety.
Good Luck
Apr 06, 2013 | Panasonic NN-S969 Microwave Oven
Hi, I have a Panasonic Inverter microwave NN-Sn9688. It's less than a year old and when you press the START button H98 appears and it will not start. Everything else works, clock etc and reset/stop...
Hi Judith, I am Kelly
If this has a 1 year warranty it is time to make that call.
Otherwise see this link about H97 or H98 codes:
There are a few things that can cause the problem, none of them cheap repairs. The Magnetron filament, Control board and Inverter are the top 3 other than a losse connection.
I tried running the Model number NN-SN9688 and it does not cross. See Panasonic link here:
I did not go to Panasonic Global and try other countries. I just did a USA search.
Thanks for choosing FixYa.
Sep 10, 2010 | Panasonic Microwave Ovens
My daughter put metal in oven it shut off. the oven turns buts shuts off after a few seconds. help
metal cannot absorb the microwaves, the microwaves bounce around inside the oven. Eventually they reflect back to the magnetron, which is the part that produces the microwaves. The magnetron can overheat and be damaged.
Dec 21, 2009 | Panasonic NN-T774SF Microwave Oven
Microwave cut off
the main control board is "seeingf" a high amprage draw from the inverter board . you have a problem with the inverter or the magntron . parts are more than a new unit . try to stay away from the inverter type , there just not ready for prime time . google "panasonic inverter reviews " and you will see just common your problem is good luck
Jan 16, 2009 | Panasonic NN-S753 Microwave Oven
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
Microwave Ovens Logo
159 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
