Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Vacuum condenser message flashing
I had a problem with my subzero 650 not cooling. It went up to 48 degrees and stayed there even after we vacuumed the condenser 3 times. The repairman suggested it was the warm weather. After 2 weeks the temp has finally gone back down to 36 - 39 degrees, but the condenser message is still flashing. The book says it will reset after the unit is turned off and then back on, have done this several times. Do I need to leave the unit off for a certain amount of time, or do I still have a hidden problem?
  • Anonymous Nov 29, 2008
    My freezer is working fine. My refrigerator is dead. I raise and lower the thermostat and nothing happens. My food is beginning to get warm. HELP
Having a problem with my SubZero 650 not cooling. It has gone up to 49 degrees and the vaccum condenser light is flashing. I have turned the unit on and off to see if that resets it.
Posted on Nov 27, 2008
Your evaporator needs replacing. covered under 12 yr. warranty parts only.
Posted on Aug 22, 2008
I am having the same problem...what was the outcome to your problem?
Posted on Dec 29, 2008
How do I turn off and reset side-by-side Subzero fridge, to vacuum condenser?
Usually vacuum condenser light is on, not because of condenser coils dirty, but low on refrigerant unit, so compressor is running longer then usually. You can shut your subzero off at breaker box, if light will keep coming on in day or two, you will need to call service to replace evaporator. Most likely evaporator in Fresh food section has leak(at list its most common place). Check this video I made, even if Your Sub Zero sideXside it still will look the same about changing evaporator. Hope that was helpful.
Feb 20, 2015 | Sub-Zero Refrigerators
My Subzero 650 does not stay on 34 degrees consistently. It is not now and I have turned the unit off for 15 minutes but to no avail. It has done this before but after a 36-48 hours it is back to 34...
aHi,
You need to check the following to make sure your fridge is working properly:
Vent blockage - Air flows between the freezer and refrigerator sections to provide proper cooling via air vents.
Condenser coil - When the condenser coil is dirty it causes the sealed system to overheat and therefore the refrigerator will not cool properly.
Defrost Cycle - When the refrigerator goes into defrost, the cooling mode stops and a defrost heater energizes to remove accumulated frost from the evaporator (cooling) coil, which causes the freezer temperature to rise slightly.
Proper Air Circulation - Refrigerators require a specific amount of clearance around the cabinet to allow for air circulation. If the refrigerator does not have the minimum clearance required, the refrigerator cannot cool properly.
Hope this helps.
Shane
Apr 23, 2011 | Sub-Zero Refrigerators
My 12 year old subzero fridge (650) is not getting cold. this morning i discovered ice behind the fresh food drawer, removed it, it was running fine, temp 35. now tonight the temp is 51. freezer is fine....
Is it flashing vacuum condenser? Ice behind the crisper drawer shouldn't effect the temp. What is it set at? You can go to www.subzerospecialists.com and click on Tech Help for additional info.
Feb 23, 2011 | Sub-Zero 650 / O Bottom Freezer...
VACUUM CONDENSER MESSAGE KEEPS COMING ON subzero 650. I vaccumed it several times! The temp gauge is showing 48, yet the tem is set on 38
you need to turn off main power to frig...wait 5 mins..plug back in...if does it again replace sensor by condnser coil you cleaned..please ,on the side you cleaned flash a bright light thur it if you see no light, its plugged...then take compressed air an blow thur it...will be a little dust...vaccum up...hope it will help...michael,doctor airr appl.repair..843-384-8474...call if need more assistance..good luck...
Mar 26, 2010 | Sub-Zero 650 / O Bottom Freezer...
Subzero does not cool sufficiently, even with cool
yes you have 2 compressor. ona for fridge one for the freezer..
Nov 29, 2009 | Sub-Zero 650/SRH Stainless Steel
My Subzero Condenser fan runs constantly - but coils are clean
If it is similar to mine at home (Model 550) the condensor fan is designed to run continuously, even when both the freezer and refrigerator are shut off. There is no control or switch in the fan circuit, so it just runs whenever the fridge is plugged in to the wall. It uses about 56 watts.
Oct 19, 2009 | Sub-Zero 611 / O Bottom Freezer...
Vacuum condenser warning flashes despite my having vacuumed.
unit is running 6 cycles without a defost time...you may have a leak in the evapator have a subzero tech check it if 12yr or younger parts are under WTY
Sep 14, 2009 | Sub-Zero 650 / O Bottom Freezer...
Subzero--Vacuum Condenser Signal Won't Turn Off
The vacuum condenser indicator keeps flashing on and off. I did vacuum the unit, the the indicator lights keeps flashing on and off. How can I reset it and keep it off?
Thanks,
Rob
Aug 22, 2009 | Sub-Zero 650 / O Bottom Freezer...
My subzero 650 fridge part is too warm , stuck at 53 degrees
Hi There I Have a Digital Video Creator DM-4200 Video Capturewhen i was moving my cds got cracked along all others how can i get software back for a back up..
Feb 04, 2009 | Sub-Zero 650/SRH Stainless Steel
SubZero 650 - fridge 36 to 50 deg, vac condensor light flashing
Hi!! you have a seal system problem.A leak in the evaporator..
Dec 26, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
1,123 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal De GO PATS
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
