Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas
Rinnai RHFE 551FA-P
Your reply addressed the 1004 FA model. Do you know if parts for the 551 are still available? If so, what is a likely source for those parts? Thanks
  • 19,396 Answers
Hi I did not find the complete service manual for your model, however here is a good extract from service manual with most important information
Posted on Jul 25, 2008
Still looking for a surge absorber for a Rinnai energysaver 551F in Australia .Part Number DSA302M
If you have a part number you should be able to go to any plumber/gas fitter and ask them to order it through Reece/Tradelink etc.
Try ringing Rinnai direct, parts and sales is on 1300 555 545, ask for the nearest stockist.
Most Rinnai spare parts are a number begining with 9 for Australia. The code you have sounds like a Rinnai Japan part number. Might cause confusion if you try and order it.
Try this link to a 551 service manual. It has a parts list and expolded diagram. Don't worry that it's a pommy site. The heaters are the same.
http://www.rinnaiuk.com/5_Downloads/5_Warm_Air_Heater_Downloads_PDFs/05_Rinnai_551FTR_Service_Manual.pdf
Aug 18, 2010 | Rinnai RHFE-556WTA Direct Vent Heater NG...
When the temp drops below 10degrees our Rinnai
rinnai has a technical bulletin out on this condition #28. It instructs the technician to adjust the gas pressure. You can get a copy of this bulletin by contacting rinnai at 800-621-9419 (US). or at rinnai.us
Feb 02, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Can you vent the Rinnai 551F vertically through ceiling?
This unit can be vented through the roof but requires a specialized flue system-do not use an existing flue connection. Call a contractor - have them check and see if the unit can be modified to a vertical flue- it will require the existing piping to be replaced--Not a job for a do-it yourselfer
Nov 01, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
How to test a used Rinnai 1004 furnace?
The fitting on the back of the unit is 1/2" MPT. Wouldn't suggest messing with it if you are not familiar with propane or natural gas. Make sure the unit is set up for LP if you are going to use a portable supply tank. These units are very reliable. Check all fittings with a diluted soap and water solution before turning on the unit. If it is not connected to it's venting system, you would have a forced induction source of ignition if you had a leak in your piping. These units should only be installed by a licensed plumber or gas fitter, one simple error could allow carbon monoxide (CO) into your house
Aug 25, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rennai 551 FA-P Never fully shuts off
Hebert,
Is there a chance there is a draft around the room temp probe? It is down low on the right side of the heater. If there is a draft the room sensor is fooled and keeps running the unit. You should be able to prove the room sensor by putting your hand over it after the stove has been running for a while. This should shut the stove down. If not there is a problem with the room sensor.
Tom Hawkins
hawkins111@gci.net
Jan 25, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Looking for Manuals
Google rinnai 1004 and 556 manuals. I just did and found them
Nov 26, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas Logo
813 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
