Question about Dell 924 All-in-One InkJet Printer
The printer itself
I try and print but it just goes back and fort slamming into the sides really hard. What do I do?
  • 446 Answers
Chances are the printer head is trying to find its home posiiton or some sort, you can check for a miniature sensor and see if it is dirty try to clean this by soft cloth while the machine is power off, turn it on again and see if it does any good
Posted on Jul 25, 2008
My Cannon IP2600 slams the cartridges really hard against the right side when I close the lid and it goes in printing position. It does the same thing without a cartridge in it. Any suggestions?
The coded strip passing through the carriage sensor may be incorrectly installed (if so, reverse the left / right ends). Clean the sensor slot. If problem persists replace the coded strip.
Jan 31, 2014 | Office Equipment & Supplies
When i turn my printer on, the ink cartridge carrier zooms back and forth really fast, slamming into each side. The printer shows a paper jam, but there is no paper in it. Also, when the cartridge...
OK, it sounds like a defective printer that needs to be reset.
Unplug the power to it and replug the power back in to see if it stops doing this.
Read over the following paper jam link from hp.com. It might help you get the paper jam indicator to not light up:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu00697&tmp_track_link=ot_faqs/top_issues/en_us/buu00697/loc:6&lc=en&dlc=en&cc=us&product=90764
Oct 28, 2010 | HP PSC 1210 All-In-One InkJet Printer
Carriage swings from one side to other
Remove the cartridges from the printer. Close the cover. Unplug the printer from the power source. Wait for about 10-15 seconds before plugging it back in. Once the printer's ready, re-insert the cartridges. Close the cover. It should try to print an alignment page. Let it print the page all the way through without cancelling it. If carrier is not slamming to the sides anymore, problem's resolved. But, when after re-inserting the cartridges and the printer tries to print the alignment and still slamming the carrier to the sides, that sounds more like a mechanical problem and needs to be replaced. If your printer is still within warranty, you can call Lexmark. They might send you a replacement. Good luck!
Apr 06, 2010 | Lexmark X5495 All-in-One &USB...
The cartridge bay goes crazy and slams both sides of the printer. Thus, this will not let me print. I was printing fine, and then I heard a slam, and a notification popped up sayin there was a problem with...
Clean encoder strip, thin plastic strip runs width of machine pararell to silver scan rail. Ensure it is running threw carriage smoothly otherwise the light that read it is dodgy, this will be unecomical to fix unless dirty strip
Nov 07, 2009 | Lexmark Z715 InkJet Printer
The part that prints goes to right and tries to go further to the right and doesn't print.
Look for a plastic strip where the ink station moves back and forth. It has tiny vertical lines on it which count as the carriage moves. If the strip gets dirty, the carriage may lose count and slam against the far stop. Power off the printer and gently clean the strip with a damp rag. Rub both sides with the rag dampened with water. Then make sure it's dry and see if that doesn't help.
Apr 30, 2009 | HP DeskJet 932c InkJet Printer
Start button
The switch underneath the print button has gone bad.A skilled technician can replace the switch or the little circuit board itself.Many copier shops offer carry in service at a reduced rate.Good LucK
Mar 26, 2009 | Office Equipment & Supplies
Cartridge slams
That piece of plastic that is out of the machine helps the print head to know where its at on the paper think of it as a guide of a sort you may be able to place it back in.I wouldn't turn the printer back on until the part is put back in you may damage it beyond repair.
Aug 11, 2008 | Dell Inkjet 720 Printer
Okidata 320 Turbo print head carriage slamming
There is a Optical sensor under the print head drive assy. You might have dust blocking this sensor.
Feb 07, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Cartridge slamming
I have a Dell 924 and the SAME thing is happening to me! it is probably because something called the cartridge band has disconnected. it is actually a thin small clear band that connects to either side of the inside of the printer to guide the cartridge. Unfortunatly, if you don't still have a warrenty with Dell to get it fixed or replaced, you might have to buy a new one or fix it yourself. :(
Feb 01, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
21 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
