Question about Sony Playstation 3 (PS3) Console
Playstation 3 problem
My Ps3 started to not show any video for some reason after I moved it from my SD to my HDTV. When I moved it back to the SD tv it still wouldnt show any video. I used every cable (HDMI, Composite, component) and still nothing. It turns on and accepts disks and everything, but when I try to turn it off it beeps three times, so you have to hold the power for an extra ten seconds until it returns to standby. And I have done the reset where you hold the power when its on standby for two beeps and the screen flickers but still no picture.
This pretty much explains what is going on
http://youtube.com/watch?v=BK91fzdjg3E
  • Blockhead23 Jul 25, 2008
    Thanks but I have already tried that
Try holding the power down for 10 seconds while the red standby light is on. It will beep a couple of times. It should reset your video display settings.
Posted on Jul 25, 2008
I moved my ps3 from my hdtv to non hd tv and used the 3 colored audio video wires to connect to the tv but the screen stays black
Hello, you will want to reset your video output.First with the power off, push and hold down the power button till you hear the second beep,then release.Your picture should show in approx 7 seconds.
Feb 14, 2011 | Sony Playstation 3 (PS3) Console
I am trying to move my ps3 from an HDTV to a non HDTV and it won't work on the non HDTV with correct cables used
Ok what you need to do is turn your PS3 on. Then press and hold the power button for 5 seconds. This will revert the video back to standard definition and hopefully cure your problem.
Aug 09, 2010 | Sony Playstation 3 (PS3) Console
Tv and ps3 plugged in and on. av channel shows an empty screen
Follow these steps to resolve your problem:
1. Turn off the PS3 so it only shows a red light. You can hold the power button on the front until it goes into standby. To be sure, flick the power switch on the back of the Play Station 3 off and then back on.
2. Make sure your Play Station 3 is connected to your regular TV (not HDTV) with the standard video cables.
3. Press and hold the power button until the screen "flickers" and then immediately release. This should reset the video settings.
4. Wait a few seconds, and the Play Station 3 (PS3) logo should appear.
If this does not resolve the problem, follow these steps:
3. Press and hold the power button on the front until the Play Station 3 beeps and then turns off again. This should reset the video for you and you can turn it back on after this.
Jun 10, 2010 | Sony Playstation 3 (PS3) Console
Ps3 wont display on the tv!!
Jun 10, 2010 | Sony PlayStation 3 40GB System
My playstation 3 is set on the display 1080, i need to change it back to normal sd, but it doesnt display anything on my sd tv. how do i get it back to normal.
Please try the following steps to solve your PS3 problem :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Hope this helps and thank you for using FixYa
Jun 04, 2010 | Sony Playstation 3 (PS3) Console
Yellow light on console unable to start console.
First the Reason for Yellow Light
If the hard-drive fails on the PS3 you may get a solid yellow led, The yellow light will show if the console is overheating as well, but the console shuts down so you don't it for long.
1)Turn off your playstation 3. If you think your ps3 has been caught by the heat, then wait at least 20 minutes and put it back on again
2) Check if there's any loose cable.
3) Try to put out your playstation's hard-drive, and put it back in. You might want to repeat this 2-3 times for better results.
If this did not work, then it is suggested to send your PS3 for repairs to Sony Customer Support
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
Ps3 broken
When you attach your Play Station 3 to an HD TV through an HDMI port, the Play Station 3 will ask you if you wish to switch to HD Mode.
However, if you decide to move it to another TV that is not HD compatible, you will get no picture because the Play Station 3 is “stuck” in HD (HDMI) mode.
That’s it! You can play your Play Station 3 again!
Nov 06, 2009 | Sony Playstation 3 (PS3) Console
When i turn on my ps3 the xmb menu wont show....
am sure about the computer part but for the xmb i can help reset ur ps3 by turning it on then turn it off by holding the buttonthen it back on by holding the power button it should beep pause and beep 2x this will reset ur display option back to normal then ur cables make a difference if ur using a SD TV use regular cables if HDTV use hd cables only on hdtv if use on SDtv it won't display or ur ps3 is set to an hd setting like 1080p it won't display on a sdtv so reset ur ps3 by holdin power button hope this help u
Jul 16, 2009 | Sony Playstation 3 (PS3) Console
Wont show picher just black
in order to switch back from hd to sd you have to hook up the ps3 after you do that press the power button on the console and hold it down you will hear the first beep followed by another about 3-5 secs later this will reset the system back to sd
May 18, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
53 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
