Panasonic PT-47WX53 47" Rear Projection HDTV Logo
Posted on Feb 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Panasonic pt-47wx53, no power, 3 blinks - Panasonic PT-47WX53 47" Rear Projection HDTV
Sonny Berry
Level 3:
  • Panasonic Master 8,617 Answers
  • Posted on Feb 18, 2011
Sonny Berry
Panasonic Master
Level 3:
Answers
8617
Questions
Helped
1723222
Points
23750
3 blinks is indicating that the convergence has a problem The PT53WX53G convergence repair kit from www.tvrepairworld.com is the correct kit for your model. The kit contains the ICs, Resistors and the CD with repair instructions.
5 Related Answers
Anonymous
  • Posted on Jan 04, 2008
SOURCE: Panasonic PT-47wx53, No power, 3 Blinks
Panasonic PT53WX42F with same problem. 3 blinks after power on for a few seconds, no picture or sound. Solution: replaced two convergence ICs (STK392-XXX) located on the large green printed circuit board. ICs are very large and screwed into two large heat sinks and soldered to board. Cost is approximately $6 each. Easy to replace if careful. May be able to access solder joints on bottom of board by removing screen on bottom of cabinet or simply remove 4 screws that anchor plastic holder to cabinet and tilt up. I did not disconnect any inter-board connections. Remove heat sink screws. Desolder using suction bulb or solder sucker. Works great. Finish off with solderwick braid if necessary to clear holes. 40 watt iron is enough do not apply too much heat to damage board lands. Remove IC. Clean heat sink by scraping away white heat sync compound. Apply generous amount of heat sync compound to new IC and coat evenly. Align and insert new IC holes, resolder with thin resin core solder being careful not bridge lands. Refasten to heat sink. Clean board and inspect for good joints and no bridging. Refasten plastic board holder. Carefully clean projection lenses while back is off tv. Power up and it should be fixed. Parts are obtainable on-line. Solder tools and board cleaner are available at Radio Shack or on-line also. I spent $20 on parts and supplies. This is not hard just a bit tedious. You can do it.
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Dec 06, 2009
SOURCE: PT-47WX53 47 in. Rear Projection HDTV Television
replace the DG board which is the small board which plugs into the A Board ( on the left side looking in rear of the set) The DG is the board which lays flat on top of the A board. You can get the A board and the DG board combined at www.tvrepairworld.com They may sell it seperately if you inquire.
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Dec 10, 2009
SOURCE: Panasonic PT-47WX53, Would replacing the
If the pins were bridged with solder it could blow the main fuse. I would check the fuse since a panasonic will always light the led if the fuse inst blown, another possibility would be the wires not seated properly especially the bridge connectors bewteen the boards.
Anonymous
  • 14553 Answers
  • Posted on Dec 14, 2009
SOURCE: Panasonic PT-47WX53 read projection tv does not
if it is something like the PT47WX53G have you checked C509?
In most of these sets it is a 200v rated cap that commonly fails;if it is open the set will come on and not have a picture and or may be missing sound.
Some of these sets when this happens---after 5 or 6 minutes you will see a faint band of noise from top to bottom towards the right side of the screen.
If the cap had actually shorted the set would shut down instantly with a 5 blink code---if you find your set has it (located a few inches forward of Q551---the horizontal output transistor. It is brown in color---look at it closely for any cracks in the brown exterior of the cap. Sometimes if it opens fast there will be no crack and you have to remove and test it with a cap checker.
If you have the schematic it will tell you if your set has the part. It should be a .047 at 200 volts.
let me know what you find and if I can help you I will. I have seen about two dozen of these sets with this problem---if the cap has a fracture or crack it is gone--if it looks ok it still may be open.
SD TECH
Anonymous
  • 14553 Answers
  • Posted on Jan 05, 2010
SOURCE: Panasonic pt-47wx53 C509
As you look from the back of the set (with the cover off) it is on the far right large board, C509 is the location number--it will be printed on top of the board under the cap.
It is about 2 o'clock near a large plug--on right side of right board--the one with the large gray transformer with a large red wire--part is forward of that transformer and red looking in color--two leads---it will have the C509 printed on top of the board under it.
This is a common failure part is this set--some will have a physical crack in the red part and others will look perfect-----value with a cap checker is .47 UF----200v is the working voltage --as long as you replace it with a cap of at least 200 volts of the same value--it will be fine--
There are two ways to get at it--pull the large board it is on OUT--I do not recommend this----or pull the whole light box out---very easy and safe---if you locate the cap and want to know how to pull the light box out let me know--
If this has helped you rate this solution as I do this here for free.
SD TECH
Testimonial: "Great job, thanks so much. I will replace the cap later on this week. Last repair before uograding."
Panasonic PT-47WX53 HD Projection TV will not turn on
the power light should blink a series of blinks which indicates which circuit has the issue. Respond to this same post with the number of blinks and I will assist with the issue.
Turn tv on,tv shut off then power light blinks 3 times,pause and continue to blink 3 times
Check the site www.TvRepairKits.com - your convergence may have shorted out causing the tv to power off.
1helpful
Panasonic PT-47wx53 just shut off
Your convergence ICs have failed. Thats what causes the led to blink three times. The PT53WX53 convergence repair kit from www.tvrepairworld.com will usually repair that issue. The kit also contains the CD with detailed repair instructions.
1helpful
2002 Panasonic PT-47WX52F - Power button now just blinks 3 times
thats the convergence circuits needing repair. You can repair it yourself for around 50.00 with the convergence repair kit for your model from www.tvrepairworld.com the kits contain the parts and the CD with instructions.
2helpful
My tv wont tun on, the on button blinks red
PT-47wx53? This means the set is in shutdown---unplug the set and plug it back in and turn it on----when the power light blinks try to count the sequence---
for example___3 blinks, a pause and 3 blinks---it should repeat this several times---count carefully and let me know the number of blinks
3 blinks is the most common and the easiest to diagnose for repair.
let me know what you find, I am here to help people.
If this has helped you rate this solution as I do this here for FREE.
SD TECH
4helpful
2answers
Panasonic cinemavision pt-53wx54j
if the led is blinking one time its the 140 volt circuit. If its blinking a series of 3 blinks its the convergence circuit
Panasonic pt53wx42f
WHEN POWER IS FIRST TURNED ON I HAVE A SOLID RED LIGHT BUT NO PICTURE. THEN YOU HEAR THE TV CLICK OFF. THEN RED LIGHT STARTS TO BLINK IN SET OF (3) TIMES.
Panasonic PT-47WX53
Your convergence ICs have failed thats what 3 blinks means. You will need both convergence ICs number STK392-110 you can get replacement ICs at this link and they provide free instalation instructions with pictures plus free on line tech support when you do the repair. here is the link.
http://servicemanuals.vstore.ca/
Panasonic PT-47WX53 47 in
ck mosfet and hori output also look for burnted capacitors [2] of them 1200pf 2k volts.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
