Question about Hitachi 50UX57B 50" Rear Projection Television
Hitachi 60" rear projection, convergence
While watching our 11-year old TV, the convergence jumped out of setting. The red goes off-center and cannot be reset. Sometimes it works OK, but more not. I noticed that if you bump the cabinet, the picture jumps too, didn't before. Cold solder joint, or other?
  • Scorpio Jul 31, 2008
    Yes I had the exact same problem. But also I have an inverted bowing the horizontal edges. I checked the board while it's on and found all of the green lights are on exempt for the one closet to the main power supply.
    For your convergence problem I've found that if your press the service mode button on the front of board and use the number buttons on the remote, you can adjust the position of the red and blue (green is stationary). I hope this helps you. Can someone help me with the bowing effect?
I have the 70" model. The convergence chips are failing. They aren't hard to replace if you have some soldering experience. Once you replace the chips, it's always good to follow the the "Service Mode" Convergence allignment and save.
Posted on Oct 15, 2008
The link you provided for the manual is not an active link.
Posted on Aug 25, 2008
Check out this document to adjust your Hitachi projection t.v. I did my 11 year old t.v. today.
Posted on Aug 13, 2008
On one side of the screen the red projection doesn't line up with the others. It is about 1" off at teh edge of the screen and lessens to where they align about 11"-12" towards the center of the screen. ...
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis any alignment,have colors shadows or picture look like 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved tv convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 08, 2010 | Hitachi 60SDX88B 60" Rear Projection...
I have a Hitachi 60sbx78b rear projection tv when I moved the set about 60 feet to a new room.when i turned it back on I now need 3d glasses to watch it the colors are all out of aline and the green line...
Check your owner's manual and see if there are instructions for setting the convergence. This lines up the different color guns so that you don't need your 3D glasses. If setting the convergence doesn't work, you may need new IC chips. Good luck!
Mar 01, 2010 | Hitachi 60SBX78B 60" Rear Projection...
My 6 year old 65xwx20b tv convergence problem
Good Day,
This is a common problem with this TV, but there is an upgrade to correct the CONVERVGENCE circuit problem.
If you want to repair this concern yourself: Contact: B&D ENTERPRISES,
1-800-458-6053, and ask for KIT10 for your Hitachi TV.
If you want some else to do the repair for you call an Authorized Service Center.
Needs convergence IC's
Good Luck,BIG IRISH.
Nov 23, 2009 | Hitachi Director's Series 65XWX20B 65"...
My tv jumps with red lines while watching. JVC
It sounds like the begining of as convergence problem or cold solder on convergence board - have a tech have alook
Sep 14, 2009 | JVC AV-48WP30 48" Rear Projection...
Hitachi 43FDX Rear Projection TV
If the picture was good prior to the 3D images, I would fix it. The convergence ICs either have poor connections or are defective. The IC is an STK392-110. There may be 2 inside the set. If you have this repaired, expect a labor cost in the $200 range. Request that the ICs be replaced rather than the board changed. This will maintain all of the internal settings and require only part replacement not a complete re-convergence adjustment.
Keep us posted.
May 01, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Did you fix your Rear Projection TV, I have the same problem...
Oct 04, 2008 | Hitachi 51G500 51" Rear Projection...
Hitachi rear projection 60" tv, power failure
Yes,it's worth it ! Check for bad C702 capacitor next to HV
transformer covered partially by glue and E994 open pico fuse
in power supply .part # for cap 1-161-754-00 102K / 3KV.......T.
Dec 04, 2007 | Hitachi FDX Series 43FDX10B 43" Rear...
Screen distortion
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
Nov 16, 2007 | Hitachi 60UX58B 60" Rear Projection...
Akai pth5488 54 inch rear projection television
KIT10 $29.50
Jul 31, 2007 | Hitachi 43GX01B 43" Rear Projection...
You need to most likely replace the convergence output IC's probably STK392-110's and check associated resistors around it. HD is not mandated for 2009, only digital braodcast it is at that point all analog television broadcast must stop.
Jan 21, 2007 | Hitachi 46UX50B 46" Rear Projection...
Hitachi 50UX57B 50" Rear Projection Television Logo
114 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
