Question about Garmin StreetPilot C330 GPS Receiver
WILL NOT TURN OFF
My c330 is stuck in the ON mode, I have unplugged it as well as trying to press the power button. I will not do anything. HELP
    Scholar:
  • 162 Answers
Pry off the face by lifting from the garmin name at the top of your unit. If unit is on, press the RESET button.
Posted on Jul 25, 2008
I have an old garmin c330 that works fine but no sound. How do I fix this problem?
I checked the manual for my C330 and under the Resetting topic it says:
1. Unplug cables and remove external power
2. Place your thumbnail in the groove under the Garmin logo on the faceplate and gently remove
3. Press the Reset button for about 3 seconds
4. Connect the C330 to a power source. It should turn on and operate normally.
Aug 12, 2017 | Garmin GPS
Sony Bravia stuck on Bravia screen
"Bravia Screen". Not sure what you mean. Is it in maintenance mode?
Option 1.. With the tv plugged in and the power OFF (this is called standby mode) take your remote (make sure it has fresh batteries) follow this sequence on the remote. You have to press the buttons within a second of each other in this order:
DISPLAY - 5 - VOLUME + TV POWER.
When the screen comes on hit JUMP right away and it puts you into a little screen for maintenance. Simply turn off the television to exit maintenance mode.
2. If your remote is bad, ie, new batteries don't fix it, might suggest a new one.
3. If you can't get a new remote, power on the television using the power button and then hit the menu button. Use the up and down keys to see if you are stuck in some weird screen or something.
4. If you are connecting something to the television (like a dvd, a playstation, computer, etc) try unplugging everything and test each port individually, using the side buttons as described in part 3 to change the input mode to the port you are using.
Hope this helps
Mar 10, 2013 | Televison & Video
Tried unpluging and nothing tried al buttons nothing the computer was at a shop to BE FIXED AT SHOP OK CAME HOME STUCK IN POWER SAVE MODE BUTTON ORANGE ON MONITOR HIT GOES GREEN SAYS PAWER SAVE MODE HIT...
Press and hold the power button for 5 seconds this will turn the system completely off wait 5 seconds then turn it back on as soon as it boots up go into power options in the control panel and click the option from power saver mode to do nothing as there is a fault with some computers that it gets stuck in power saver mode
Jun 27, 2011 | Computers & Internet
My averatec lap top os stuck in sleep mode
Hi. I suggest you try pressing the power button to wake it up or you could also try power draining it and turting it on. To powerdrain your computer you must remove first the battery and unplug the ac adapter then press and hold the power button for 20 seconds, after that you must place back the battery and plugin the ac adapter then turn on your computer. Hope This Helps
Jun 02, 2010 | Toshiba Satellite M100 Notebook
My garmin c330 will only work with a usb port connection and when i unplug it it goes dead again,, do i need to replace a battery inside somewhere?
This is very possible, if when you press the power button on the unit and it is not connected to anything and nothing happens
Jan 04, 2010 | Garmin StreetPilot C330 GPS Receiver
My phone wont do anything!!!!
To getout from stuck or in DFU mode try this.......To Normal Mode Just Keep Press Home+Power For 5 sec Then
Release The Home Button And Keep Press Power Button for 50 Sec U Phone Will Powering On
Regards..
If your iphone is still in stuck after trying the above instruction you must jailbreak it and unlock.then enjoy using your iphone.If you want some help heres my YM:exel_bernardo@yahoo.com
Jul 22, 2009 | Apple iPhone 3G
Frozen screen
Resetting Your c330
If your unit locks up, press the Power button to turn off the unit, then press again to turn the unit back on. If this does not help, reset your C330.
1. Place your thumb nail in the groove located under the Garmin logo on the face plate.
2. Gently pull off the face plate.
3. Press the Reset button.
4. Turn the unit back on; it will operate normally
Apr 04, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin C330 white screen
Have you tried a Master Reset? If not, it may help, but it WILL ERASE ALL OF YOUR FAVORITES, and may remove anything you have updated. To do a Master Reset, turn the unit off. Press the On button and the bottom right of the screen at the same time. Release the On button, but keep pressing the screen until the unit asks if you are sure you want to reset. Press yes. This may help.
Oct 28, 2007 | Garmin StreetPilot C330 GPS Receiver
DVD player stuck in standby mode
Bad caps in the power supply is causing this. C17 (10v,470uf), C17,c14 (10v,1000uf) and C18 (10v,470uf). Replace with same capacitance values but 25 volt rating 85 C. Just fixed mine half hour ago works great.
May 27, 2007 | Onkyo DV-CP500 Multi-disc DVD Player
Garmin StreetPilot C330 GPS Receiver Logo
20 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
