Spin cycle with agitation motion occurring simultaneously
I am confused.........the water is removed during spin cycle but clothers remain damp due to spin speed. The drum does spin during the last spin cycle but why would the agitator operate simultaneously during a spin setting?
    Brigadier General:
  • 6,966 Answers
Hi again,
Appreciate the "Ask Me".
I believe the dampness is due to slow spin speed as you also have concluded. And I suspect that partial winding of the motor is the culprit. Hence, replacement is in order.
As to your concern why the agitator also operate during the spin setting, it could possibly be stuck or locked agitator dogs. Agitator dogs function is better explained here by another FixYa member, jsrock516.
Cheers.
Posted on Jul 25, 2008
I have a Whirlpool Ultimate Care II, top loading washer. Upon intial start up the machine agitates. During the spin cycle, the cold water remains ON, throughout the cycle. This is leaving the clothes wet...
The timer is at fault.
During the spin cycle the timer should send intermittent power to the water valve. This activates cold to help rinse soap residue from the laundry.
If cold is continuous it means the timer is not breaking correctly.
Feb 14, 2010 | Whirlpool Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Whirlpool washer stops after agitation cycle
Maybe check the belt is it cracked worn or fibers showing if so replace it
Jul 26, 2009 | Whirlpool Washing Machines
Kicking out water during wash cycle - spin instead of agitation
Try these
  1. Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  2. The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  3. Check the drain control lever
  4. Test the drain control coils
  5. Check the cam bar
pls rate my suggestion..
Jul 19, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag SAV 3652 AWW Washer: During spin cycle, burning smell occurred while making unusual noise. (For months, major squeaking during agitation).
Bad water pump. Replace water pump.tip machine back,Look under machine, remove belt, turn pump by hand, if not spinning freely replace pump.
Mar 23, 2009 | Maytag PAV2300 Top Load Washer
Kenmors 110 keep spining
The tranny should either spin or agitate not both
Nov 02, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Mod 110 keep spinning
the holes are sapose to be there it filters the lint out.it sounds like you have a bad transmission.
Agitator not turning during cycle
Well, it sounds like you've done your homework. My first suspect would have been the agitator dogs too, but you said they were fine. Another likely suspect would have been the motor coupler, but you said the washer spins during the spin cycle. If the coupler was bad the unit would fill, but wouldn't agitate or spin. Plus, it would make an awful noise. I would have also suspected a clutch assembly, but you said the wash tub can spin. Normally, when the clutch goes bad, the drum won't spin, or spins slow. Another suspect could have been a bad lid switch, but the washer would have filled and stopped, without agitating or spinning. The only remaining suspect that I'm aware of is the gear case (transmission). Checking under the washer can give you some clues. Normally, when a gear case starts to go bad, they leak an amber colored oil. You may find puddles or drips under the washer. If you see no signs of oil the gear case could still be defective, however. But, before you go through all the trouble, double check the agitator one more time. Completely remove it from the tub and check the under side to ensure the grooves that grip the top of the gear case shaft have not been worn smooth. I hope this may have been some help to you.
Jul 09, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
252 people viewed this question
Top Washing Machines Experts
