Question about DeLonghi Heating & Cooling
I have a delonghi pinguino k900 which I purchased in 2003. for the past 2 years it only acts as a fan. what do I need to do?
  • DeLonghi Master
  • 19,396 Answers
Check last pages of your user manual there is the number to call repair service, the heater element must be replaced
Posted on Jul 25, 2008
Delonghi pinguino k900 air conditioner not working. The ac is not responsive to the buttons. Please help
Hello, these units are not as user serviceable as the old electromechanical types, unless you are fairly familiar with power I cant suggest you engage in actions that could seriously injure,even kill you if you make 1 error. I am sorry but many technicians today are not even familiar enough with these to attempt servicing them, with the cost of service these tend to be replaced more than repaired out of warranty.
Jun 29, 2013 | Heating & Cooling
Delonghi Pinguino K900, continued to blow hot air, what should be the solution. I want to enjoy the airconditioner aspect of the unit.
There a several things that can cause the problem you have described.
1. The Dehumidifier Mode is operating at the same time as the AC or is operation on it's on.
In dehumidifier Mode heat is produced.
2. Air filter needs to be removed and cleaned.
3. A blockage or crimp in the exhaust hose.
4. The exhaust has a leak or has come loose from the unit.
5. The unit is sitting in direct sunlight or is adjacent to a heat producing appliance.
6. Compressor needs to be recharged with R134a refrigerant gas.
The 6 things listed above are where you need to start troubleshooting. 5 of which are easy to check and correct.
Hope this helps you and thanks for choosing FixYa.
Jul 21, 2011 | DeLonghi Pinguino PACL90 Portable Air...
DeLonghi Pinguino PAC CT90 It is less than a year has quit coolin
Read instructions and see if it says anything about cleaning or filters. A.C units **** air in and there is a filter that probably needs cleaned.Also,while cooling, the vent to the outside should put out warm air. Also, if it is less than a year old, contact the manufacturer and they should help you out. Good luck.
Feb 13, 2010 | DeLonghi Pinguino PACL90 Portable Air...
My Delonghi K900 overheats after only an hour of use. It is so hot, I'm afraid it will start a fire. Also, it only cools the indoor air to match the temperature outside. I thought I was purchasing an air...
Hello, have you tried shortening the length of the exaust hose, portable air conditioners rapidly loose performance when the hose is long. The exaust hose needs to be as short as possible with the fewest possible bends. The overheating is usually caused by the unit struggling to push the heat away from it, this would also explain the less than satisfactory performance. Another thing worth checking is that the filter and the fins on both radiators are clean as dirt will decrease its ability to move heat. Hope this helps.
Jul 31, 2009 | DeLonghi Pinguino PAC-77E Air Conditioner
Exhaust Hose DeLonghi PAC-210U replacement
Hi
You need to go here
://www.delonghi.co.uk/accessories.php
Feb 14, 2009 | DeLonghi Pinguino PAC-02 Air Conditioner
Delonghi pac-02 a/c
I had similar problem .... on very humid days unit leaks ..... temp solution for me was to drain the unit .... inserted wire coat hanger into tube .... lots of watery gook came out.. - even tilted/tipped the unit inorder to get as much water out of it.......afterwards unit worked fine.
We are VERY SASTIFIED with the Delonghi Pinguino - bought it years ago when it first came out and it has provided years of troublefree service .... the water build up / leaking was only recently - in fact we never drained the thing until this year.
Aug 23, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
K 900, pinguino
I had the same problem with my Delonghi K900.  I have an extended warrantee for both my Delonghi air conditioners.  It was taken into the shop and discovered that the hose that allows the water to drip into the collecting tank was clogged with dirt and dust. I find it is a good idea to have them cleaned and checked once a year, especially if used often. For under a hundred dollars, I have a warrantee that will last until the year 2010.  Sears offers warrantees for any home appliance, even if it wasn't purchased there. Taking the air conditioner apart yourself can cancel any warrantee on them machine. Hope this helps. Trisha
Jul 27, 2008 | DeLonghi Pinguino PAC-77E Air Conditioner
Try this link. I do not see a "K900" but maybe it is a start.
http://www.delonghi.com/Int/USA/customer.html
Jun 15, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
Delonghi piguino k900
does anyone no where to find a user manual for this air conditioner?
Jun 08, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
Heating & Cooling Logo
230 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
