Question about Amana PTC153B50AJ Electric Heat Air Conditioner
Amana #PTC153b50AJ ser 0410686783 Customer heard a pop in unit and it went off. Breaker was tripped. Reset breaker and unit runs in a/c mode but does not heat in heat mode. This is not a heat pump but electric heat strips. Unit says there is a manual reset for the heat but we have not located the reset. We turned power off to the unit to reset fault etc and still no heat. The flashing light just blinks once every 4-5 sec. Could use some help in diagnosis Thanks DK
  • Amana Master
  • 2,127 Answers
I'm seeing a master switch on the control board, try a reset there. But, sounds like a bad element. You need to test continuity through your heater components. When testing a component unhook wires first, as they will still have continuity even if bad with wires attached.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Posted on Jun 04, 2017
  • 49 Answers
SOURCE: Amana PTAC
Sounds like if this is a heat pump, maybe it tripped out on high pressure. Maybe just unplugging the system may reset the control boards. This maybe due to a dirty filter or dirty evaporator coil.
Posted on Nov 18, 2007
ACTECH
  • 80 Answers
SOURCE: unit blows cold air instead of warm (burrrr)
FAULTS ARE STORED WITHIN THE CIRCUIT BOARDS MEMORIE TRY UNPLUGGING IT FOR 2 MINUTES AND PLUGGING IT BACK IN
Posted on Dec 01, 2007
  • 10865 Answers
SOURCE: 30amp breaker labeled heat strip trips and no hot water
That 300 amp breaker must be controlling both your hot water tank and some heat strip somewhere in your house which is designed to either prevent a pipe from freezing or melt ice on the eves of your roof.
please mark this answer as a fixya
Posted on Mar 05, 2009
  • 2976 Answers
SOURCE: Air Conditioner in wall not window like hotel unit, leaks inside
Open the cover. In the bottom drip pan, there is a hole that is clogged. Just unplug it and it will drain.
Posted on Jul 07, 2009
  • 44 Answers
SOURCE: COMPRESSOR Amana / RCE24C2A Ser #036142440
mfg date are coded into the ser.# useualy fist 4 digits are yr and month of MFG. 0306 would be 2003 june ect. if in doubt call amanna dealer and ask them. Steve
Posted on Jul 12, 2009
Amana model lga60aw Dryer tripping circuit breaker
Is the dryer gas or electric? Does it plug into a 110Volt outlet or a 220Volt outlet? Does it trip the circuit breaker immediately or will it run for a while and then trip the breaker? If it is tripping immediately then there is a short inside the unit. If it takes a while to trip the breaker it can be that the outlet you are using is not a dedicated line and has other circuits connected to it. If that's the case you are overloading the breaker and causing it to shut down. If it is a dedicated line that you are plugged into then something inside the unit is heating up when its in use and overloading the circuit breaker. Then the unit needs service.
Jan 19, 2018 | Electrical Supplies
Pentair intellitouch electronic breaker keeps tripping
check pump see if popping or heater unplug auxs until it doesn't pop if keeps maybe bad transformer
May 04, 2012 | Pentair Intellitouch Power Center Includes...
Trips circuit breaker
If the unit is new then the unit may be over-sized for the electrical circuit. If the unit is not new then the compressor may be failing
Apr 19, 2010 | Amana PTH153B35AJ Air Conditioner
Breaker tripped, wouldn't reset. After about 20 minutes it reset.
YES YOU ARE IN DANGER. DO NOT turn this breaker on again. Please get a registered electrician. There is a risk of fire or even explosion. BE CAREFUL. Have you got a smoke alarm?
Feb 05, 2010 | RTO Circuit Breaker Box For Electrical...
Breaker trips on condenser unit on heat pump after several hours of operation
Hi, check amps on unit, and make sure breaker matches, check unit voltage tag, it will tell you what size breaker you need, or may be breaker is loosing resistance, replace breaker, if problem continues, a/c maybe over working because of high temp, temp. affect amperages, and that would be normal, if it trips after few hrs. also check a/c for lack of freon, sometimes, they need a tap up of refrigerant, not enough freon and they would run longer, get hotter and eventual trips. breaker doing his job. good luck
Aug 03, 2009 | Amana PTH123B25AJ Heat Pump Air...
My Amana heat pump model PHD60C02F1 Keeps tripping the circuit breaker
Is this kicking the ground fault on the cord or the breaker. If it trips breaker could be bad breaker. If it trips quickly it is a short in the unit. Russ
Aug 01, 2009 | Amana PTH123B25AJ Heat Pump Air...
A/C unit turned off- didnt realize we had a mat covering the unit
If the breaker had tripped, you'd detect some looseness in the trip switch, even though it may not appear to be tripped. Once you have identified the correct breaker, trip it to OFF and then back to ON. Also check at the unit; it will either have a service disconnect, a fused disconnect or a circuit breaker at the wall. Compressor units have a thermal relay that causes them to shut down on high temperature. Let the unit cool down thoroughly. If this is the issue, and you are standing close enough, you may hear it reset when it cools. Usually, cool down occurs in 30 minutes or less. Try it again, but don't leave it unattended until it has made it through several cycles and you are confident that the unit is back to nornal. If any further issues develop from this incident, shut the unit down, trip the circuit breaker for the unit to off and call a serviceperson.
I hope this gets you going again!
Best regards, W/D
Jul 11, 2009 | Amana Heating & Cooling
I have a ruud achiever uaka outdoor central air system, the first time i ran it this summer it tripped the breaker. It stayed on for a good hour as it cooled the house to the desired temp. then it turned...
start components are likely bad causing comp to pull high amps tripping breaker careful resetting the breaker they can explode stand off to the side
you need service all so have preventive maintenance done on the unit
Jun 19, 2009 | Ruud UAKA037 Air Conditioner
Electric Dbl Wall Oven-loud popping noise at end of self clean
Bill ,i dont suspect the control unit is the problem im going back to the loud pop you heard I would say the pop you heard was one of the elemants blowing and that the reason the the breaker tripped if you say the clock,timer and light functon are ok it more so points to an elemant in most cases when an elemant blows it breaks the circuit .but the other componants also work when you reset the breaker i think in this case bill i would call a electrician it needs testing,sorry i could not help this time bill,but do not hesatate to contact me if i can help you again.adrian
Feb 02, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Amana PTC153B50AJ Electric Heat Air Conditioner Logo
140 people viewed this question
Top Amana Heating & Cooling Experts
Donni Steen
Bill Long
Dennis Boxerman
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
