Question about Whirlpool GU2400XTP Built-in Dishwasher
Water Stayed in dishwasher
Could you please advise why there is too much water in my dishwasher. The water did not drain. I do not know what to do in this case because .
Please advise ASAP
    Scholar:
  • 93 Answers
Check your drain hose,it might be blocked with debris.Does your drain hose attached to your Disposal, you could also fill your disposal with warm water and flush it as well.
Post another comment if does not work, I shall suggest other things to check.
Posted on Jul 27, 2008
So frustrated - LG dishwasher washes 5 minutes then shows OE code - have cleaned drains, sump pump, out let pipes. Still doing it. ONly 9 months old..... My old dishwasher worked for 10 years.......
Hi there Diane OE on your display relates to the water draining system (water is not pumped away). the diashwasher is not seeing the water drain away. Dishwashers start by draining before they take on fresh water. Start your dishwasher and listen for a pumping noise from the waste pump if you dont hear any noise it may be the pump is blocked or faulty. please advise if this helps kind regards gary.
Nov 08, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
The dishwasher works fine, but does not expel the water. please advise.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Feb 23, 2011 | Whirlpool Dishwashers
Maytag DWU6602AAE. My Maytag dishwasher (14 years
SOUNDS LIKE A TIMER PROBLEM. YOU MAY WANT TO PRICE A REPLACEMENT TIMER. AND PRICE OUT NEW DISHWASHERS. GOOD LUCK!
Feb 25, 2010 | Dishwashers
Water wont drain
Hi there....water not draining out is usually related to (a) a blocked drain pump...(b) blocked outlet hose.....(c) blocked drain outlet (under sink)...the tarmac smell is comming from the heat insulation at the rear of the dishwasher casing....you need to check that dishwasher is not overheating....
regards Sir Galahad
Aug 12, 2009 | Dishwashers
Dish Washer retains the water without draining....
the drain pump is fairly easy to replace. it locks into place beside the sump and motor. push tab in and rotate pump to pull out. you will lose water so have a towel handy. inspect drain hose for restrictions or kinks.
Jun 25, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
Dishwasher states there is a water leak when visually there isn't
Assuming that you have checked under the dishwasher for a leak (through a faulty sump gasket):
Since there is not actual leak, check the following:
-Confirm that the height of Drain Hose connection (sink-Drain Hose) rises greater than 20′ _minimum_ as it travels to the drain connection.
-If that does not solve the problen, it is probably a worn/broken Impeller of the Washing Pump.
Unless you are mechanicly incliend, a service call is probably the way to do. If you need further steps, please reply. Otherwise, after you ahve used the advise, please accept this solution.
Mar 28, 2009 | Dishwashers
Dishwasher Problems - Water will not drain out
heatman101
Oct 28, 2008 | Frigidaire 24 in. FDB750RCC Stainless...
Whirlpool GU2400XTP Built-in Dishwasher Logo
124 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
