Memorystick duo My Acer Travelmate is supposed to have a card reader for memory stick duo, but it dissappear into the slot. When i use an adapter, tha PC first asked for formatting the stick and said it coul not. Now it won't recognize tha card at all.
  • 476 Answers
Normally plug and play those cards,
do you have software for the card reader device?
I plugged mine into my camera it auto recognised straight away
as for your device card reader ,try to reinstall again
if the card works in your camera
Another idea is to put card into your camera and use a usb lead for the photo movements to the pc
same applies if its a cellphone
Hope this helps
Posted on Jul 27, 2008
Won t recognize sd card
It seems that the card reader if the computer is not detecting the card. Make sure that the memory card you use is supported.
The multi-in-one card reader on the Aspire One can read and write to Secure Digital card (SD), Secure Digital High Capacity card (SDHC), MultiMediaCard (MMC), Memory Stick (MS), Memory Stick PRO (MS PRO), and xD-Picture Card (xD). Specific models of the Aspire One are also equipped with an SD Expansion slot that can read and write to Secure Digital (SD) and Secure Digital High Capacity card (SDHC) cards.
The multi-in-one card reader on the Aspire One can read and write to miniSD, microSD, Memory Stick Duo,and Memory Stick PRO Duo cards but require the use an adapter. Acer does not provide or support any memory card adapters.
You can try removing the card reader using the device manager and the reinstall it and check the operation. You may also try using the card is different computer and check. Also try using another card in the computer with the issue and check. If the issue is not resolved please revert back with the model number.
Click on the link for the information to Reinstall a Device
http://technet.microsoft.com/en-us/library/cc725782.aspx
Nov 14, 2013 | Acer Aspire Computers & Internet
Cannot download pics off camera. Computer not recognizing camera Cannot find software to re-install
If your computer does not recognize the camera when you plug it in to the computer and you do not have access to the software needed, you will need to find another way to get the pictures onto the computer straight from the memory card. If your computer has a memory card reader, use that because that's the easiest way to access pictures on a memory card. If your computer does not have a memory card reader, you can buy a USB adapter that your memory card can fit into and your computer can read through USB. They are cheap and useful. Here's a good one for 12.40 from amazon.com that reads many types of memory cards including:
MMCmobile, SD, SDHC, MMC, MMCplus, RS-MMC; MiniSD,miniSDHC; microSD, microSDHC; MMCmicro; CF Type I and II, Microdrive; MemoryStick, Memory Stick Pro, Memory Stick Duo, Memory Stick Pro Duo; MemoryStick Micro (M2)
http://www.amazon.com/Kingston-Flash-Memory-Reader-FCR-HS219/dp/B00109Y2DQ/ref=sr_1_1?s=electronics&ie=UTF8&qid=1309913206&sr=1-1
Jul 06, 2011 | Nikon COOLPIX L18 Digital Camera
I have a sandisc memory stick pro duo 4gb and it is too small to fit in the memory card slot of my laptop which is an acer aspire 7220 series. please help x
Hi there!
Simply insert the card in it's adapter, then insert it into the memory slot.
However you can buy yourself an external USB card Reader supporting your pro duo card.
Please rate this advice as it's very important for us.
Good luck friend!
Mar 13, 2010 | SanDisk 2GB Memory Stick PRO Duo Memory...
Do you need an adapter 4 a memory stick pro duo in a 5 in 1 read
No, just insert the Memory Card in the 5-in-1 Card Reader slot. The Memory Card will appear on the "My Computer" or "Computer" window. Click on that to open the contents of the Memory Card.
Good Luck!!!!!!
Nov 30, 2009 | Acer Aspire 5610-4648 Notebook
Where to insert a camera memory stick in acer travelmate 4502lci laptop
according to the acer site..
these are usually on one side or the other. the issue here is whether your camera memory stick is same size as their slots. you may need to get an adapter. careful about forcing that mem stick into a slot that's not good to go.
Expandability 1 x Type I/II PC Card Slot, 1 x SD Card Slot, 1 x Memory Stick Card Slot, Docking Station/Port Replicator, 1 x MMC Card Slot
Nov 28, 2009 | Acer TravelMate 4150LCi Notebook
I have a memory Stick PRO Duo 4GB
YEAH, YOU MAY NEED A MEMORY CARD READER to read your memory stick. because some compters have not all type of card slots. the card reader will solve your problem.
Feb 10, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
Stick Micro M2 Memory Card
Don't know the size of the micro with its adapter, but if it is the size of a duo card you should be able to put your micro with adapter into a Pro adapter and this is the memory stick that most card readers accept. Sony has been pretty much backward compatible so I feel this should work. A Pro adapter runs about $10 @ Best Buy.
Jan 12, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
Ejecting Memory Stick Pro Duo card out of notebook card reader
Hi, the memory Stick Pro Duo card is (micro), half size as you have noticed you need to buy an SD adapter card. You put your Pro Duo card into the SD card & than put it into your card reader.
Once you see the SD adapter card on the web site you'll understand. You can buy this at a local BestBuy. Most web sites sell the adapter as a combo, you'll get a micro card & adapter.
Click the link below.
http://www.google.com/products?hl=en&q=Stick+Pro+Duo+adapter+only&um=1&ie=UTF-8
Look at SanDisk 2GB Ultra II Memory Stick PRO Duo w/Adapter
& you will understand.
Have more questions? Just ask.
Good Luck & Have a Great Day!
Mar 21, 2008 | Computers & Internet
Just got an ACER Aspire AS5720Z notebook. It has a 5-in-1 card reader. I have a memory Stick Pro Duo card that is extremely small. The manual says the card reader will read it. There is NO eject button...
Memory stick
well, best buy usually doesn't sell memory sticks, its newer version is memorystick duo
the duo does come with a memorystick adapter
so, just go to any store that sells memory sticks such as bestbuy, walmart, target, etc, and you can buy one there
they should be $20-$50
Nov 23, 2007 | Sony DCR-VX2000 Mini DV Digital Camcorder
Computers & Internet Logo
110 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
