Question about Pioneer CDJ-800 Turntable
Trouble shooting the DJP unit.
Thanks for your advice but I have one quick question. How would I go about checking the DSP unit?
  • Jason Kew Jul 27, 2008
    Don't be sorry. You have been a great help. I wish there were more service techs like you in this world....
  • 515 Answers
Well, any multimeter that can read voltages will work. We normally just replace it, as it is easier, quicker, and cheaper than us spending an hour testing the voltage of each pin on the IC. You will need a service manual for the unit, in order to get the voltage rating for each pin of that particular IC (IC101). We'll just replace it, as part of the maintenance procedure. We'll also replace IC103 and IC108, which are both OPAMPS, and also cause play/read issues.
It's kind of like giving your car a tune up... you replace all the belts, spark plugs, cables, etc, whether or not it needs it. It's just a good idea to replace all the items that may go bad shortly. Another part we'll replace is the Stepping Motor and Loading Motor. As I said, all part of the 'tune up' for these units.
In your particular case, you'll have to look at IC101, IC103, and IC108 - all likely suspects, in addition to the other components I specified.
Sorry, there is no easier method.
- Davis
DJ Pro Audio
www.djproaudio.com
www.repairnyc.com
www.1200s.com
Posted on Jul 26, 2008
My Onkyo TX-SV-919THX receiver shows DSP error on display, I want to replace DSP board, from where can I get DSP board?
Hello Raju, We cannot sell any parts directly to a customer. The unit would have to go in for service or you can look into our trade in program if the unit is out of warranty. For more information on trade in you can contact product support at 800-229-1687 x3. Thanks, FJD
Mar 19, 2016 | Onkyo Audio Players & Recorders
Its blowing out debris instead of sucking it up
Trouble Shoot Vacuum‎
Adwww.wow.com/Trouble+Shoot+Vacuum
Search for Trouble Shoot Vacuum Look Up Quick Results Now
Jul 20, 2015 | Carpet Pro Cpu1t Heavy Duty Household...
Yamaha DSP-A2070 not working, and not power up in standby mode. All the fuses is OK. Please help ?
start reading on page 14 of your service manual.
let me know if you need further assistance!
Aug 20, 2012 | Yamaha Audio Players & Recorders
Bosch WFK 6030 manual
Please check this link, it will help you with the working operations and trouble shooting:
washing machine advice
Oct 29, 2011 | Bosch WFK 2401
My Brandt wahing machine does not start, what trouble shooting solution do u suggest? thanks
The only quick trouble shooting I can give you. Try unplugging the washer for fifteen minutes. If that doesn't do it then it is timer or motor.
Apr 18, 2011 | Brandt Washing Machines
Freezer cooling doesn't come on, just the fan comes on. please advice. thanks
http://www.master-bilt.com/pdfs/io_manuals/gt_50_60_80_io-2-21-07.pdf
Go to this web site and get the manual for your freezer. check out the trouble shooting section and the wiring diagram for your unit. If you are still having troubles, get back to me.
Jan 22, 2010 | Master Bilt 25.5 cu. ft. Freezer GT80
Blowing 30amp ignition fuse.
first check the wires connected to the battery for missed alignment. then change the fuse to 30 above amp.
May 28, 2009 | 1995 Nissan 200SX
I have a Yamaha Natural Sound Stereo Receiver RX-750 (purchased maybe around 1992-1993?). The input selector switch doesn't seem to be working properly. No matter which input I select, the sound is fuzzy...
Hi cfipp
You could fix this problem with a quick squirt of CRC 2-26 into the function selector switch connected to the knob you are wriggling. This will sort out the problem. If you need further advice, feel free to ask me. I will help you.
regards robotek
Mar 07, 2009 | Yamaha DSP-A1000 5-Channel Amplifier
Center, surround speakers not working. "Can't Use" message for DSP.
Sounds like the old stuck button thing after a move??? What i mean it go over all the push buttons and maybe you will find one that is not pushing in and returning??? If alls ok then you should check the obvious like bent shafts or balance controls ect. ay have jogged something inside and you will need to see a pro to assit you unless you know how to trouble shoot solid state electronics?? These units have no real serviceable parts inside. Check with your owners manual for the sevicer nearest you. If they are not listed call the service # or try 1-800-289-AIWA . good luck
Jun 06, 2006 | Aiwa AV-D50 Receiver
Pioneer CDJ-800 Turntable Logo
51 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
