Car Audio & Video Logo
Posted on Feb 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 2005 Chrysler Sebring Limited Convertible. It is a second car that due to the severe NY winter weather sat for more than a month in our garage. When I went to start it, the battery was dead, so dead that not even interior lights or odometer would illuminate. After fully charging the battery, the car started on the first try, without any problems and ran great. I noticed that the clock had reset and I believe the radio presets were erased when the battery went dead. My problem is that since the battery went dead, my OEM cd changer doesn't work. When I switch the radio to CD, the indicator changes to CD Changer and the radio just says ERR. The lights under each CD button# 1-6 blink all the time. 1-3 blink, then alternate with 4-6. When I first start the car, all of the lights on the changer blink, including the lights for the CD door, then change to the alternating. Don't know if it matters, but I had the car out for several hours this week and I did notice that the number of times the entire changer would blink before switching to alternating would decrease as the day progessed and I started the car more. Do you know what would be causing this? The changer worked flawlessly prior to the battery dying. I would appreciate any help you could give. Thank you.
Anonymous
Level 3:
Master:
  • Master 713 Answers
  • Posted on Feb 17, 2011
Anonymous
Master
Level 3:
Master:
Answers
713
Questions
0
Helped
107148
Points
2162
Its your fuse in radio has went bad.
2004 Sebring limited convertible sat for 3 months and now has a wierd squeak only when I first start it.
sounds like belts are old. Try belt dressing from auto parts store and follow directions.
Runs rough when it's warm. comes and goes. has a 2.7. and then a 99 dodge carvan with a 3.3 does the same thing.
Chrysler Sebring Questions - Car running very rough ...
www.cargurus.com > Questions > Chrysler > Sebring
CarGurusMar 27, 2011 - It seems after car gets to a certain temperature it runs very rough. ... 2011 at 12:16 PM about the 1998 Chrysler Sebring 2 Dr LXi Coupe ... it.one day it washot out and it was running sluggish with rough idle.and ... I changed the altnator and battery its runs like its brand-new.now ... 2002 Chrysler Sebring LXi.
Chrysler Sebring Questions - Engine Power Loss After Car ...
CarGurusNov 3, 2011 - Engine Power Loss After Car Is Warmed Up - Major loss of power after car has ... When vehicle is cold runs ok, sometimes a little rough but not bad. Full power. Allowed vehicle to run for over 45 minutes last night at idle, died on its own, car sat approximately 20-30 minutes. ... 2002 Chrysler Sebring LX.
* Chrysler Sebring/200 Convertible Club * • View topic - Rough ...
www.sebringclub.net/board/viewtopic.php?p=69097
Dec 29, 2006 - 5 posts - ‎3 authors
However, the vehicle still suffers from rough idle under certain conditions: ... been resolved (I don't think he noticed that it happened only when warm though). .... The test will tell you its general condition without having to dig it out of the fender, ..... Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group rough ...
May 24, 2010
Low idle rpm
Mar 8, 2007
More results from www.sebringclub.net
I am loosing oil. can I used 20w50 oil for chrysler sebring limited convertible 2005
you can use 20w50 providing the ambient temperature is above 10 degrees c. However it will not stop oil loss. Only fixing the leak will do that
2005 Chrysler Sebring with error codes p0700,p0720,p0731
2006 Sebring Convertible - Transmission Codes - P0700, P0720, & P0731....
2006 Sebring Convertible, started while driving around town - transmission did not want to shift and CEL came on. Stopped, checked transmission fluid and looked for anything obvious. All fluids good, nothing obvious. About 5 miles from home, drove back roughly 15-20 mph. Only other issue that had came to mind was the alternator had been making a whining noise for some time, probably 3 months or so - had mentioned to wife that we should replace it before it completely failed. Found one reference on the internet that the alternator could cause weird electrical conditions / interference if bad - leaking voltage back through ground. Thinking the alternator likely needed replacing anyway, I replaced it and cleared codes - all issues were solved - no more alternator whining and all transmission issues resolved. Replaced alternator on Sept 9, 2019 today is Sept 12, 2021 and still going - I think its safe to say the alternator was the culprit in this instance.
1helpful
Trying to fine the Weel Lug Nut torque on a 2008 Chrysler Sebring Convertible Limited with 3.5L V-6 and Aluminum Wheels.
Thanks for asking.... most people just use the German torque spec..... "Gut-n-Tight"
100 ft-lbs
and then Re-Check torque after 50 miles!!!
Cheers
3answers
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
