Question about GE Spacemaker JVM1640SJ Microwave Oven
Installation of GE Microwave Oven
We now have a GE Spacemaker Microwave Oven that is about 17 years old. We need a new one now. We were told that if we buy another GE Microwave, the installation would be very easy because the holes for the installation would be the same. Is this true. We are elderly and this would make a huge difference to us.
Thank you,
Rozanne
  • michaelaiese Feb 03, 2009
    i am trying to unistall a microwave, whirlpool over the range thing. I cant see how it is attached to the wall. I removed 2 bolt from the cabinet above thinking that would get me started but I cant figure out how the bracket is connected to the wall and how to get to the other screws.
We have changed out a GE for another same brand, newer model. You will need two people to make the change-one of the two must be strong enough to support the unit after you remove the 3 bolts that hold it into the cabinet above. You will see these screws in the bottom shelf of the cabinet above your unit. A driver drill w/ the socket attachment to fit these "screws" would make it go faster. You'll need a step stool or a step ladder to get above the unit. There is a power cord that plugs into an outlet-make sure you have unplugged this before starting.While one is supporting the unit, the other is unscrewing the three bolts, When screws are out, the person on the ladder should come down and help w/ the unit removal. The unit is tipped forward to release it from the wall, as it is hooked into a bracket affixed to the wall. When you tip it forward, both of you should be prepared to lift it off the bracket. It helps to have the way cleared and a table or countertop ready on which to set it. BTW, My microwave installer did not use the flange provided to seal the vent around the cutout in the lower shelf of the upper cabinet. Removing ours, I can see why, there is no way to get the unit lined up w/ the flange and the duct and still tip it into the provided cut out. We bought metal sticky duct tape to seal it, and used the opportunity to reseal the above cut outs as well. I think some cabinets are constructed around the microwave installation, and if so, you could use the existing flange set up. When you are ready to put in the new one, do it in reverse, but schedule some clean up time in between, the grease finds a way of eluding all systems and you'll want to 409 it before putting in your new one. If this is too mu8ch for you, ask an installer or a neighbor to help-it doesn't require an electrician. You might want to ok into what GE is doing these days so your aren't dissappointed w/ the new unit after such a successful run with your first purchase.
Posted on Feb 03, 2009
  • GE Master
  • 9,098 Answers
If you contact GE customer service with your model number, they can tell you if they have a comparable "drop in" replacement model.
GE Customer Service is here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 28, 2008
I have a ge model JVM1850. It is 6yrs old. Today it suddenly did not heat a frozen small item thru. Does this sound repairable or do I need to consider replacement? It is above oven.
well!!!!!! its 6 years old,,,,my bet is the manatron has failed,,,and thats a pricy part to buy and have fitted,,,
you may find in the long run its cheeper to just buy a new microwave,,at least it would be a new one and not 6 years old! and not a patch up job
Jun 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Need installation instructions and owners manual
You can download GE owner's manuals and installation instructions here.
Apr 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven just quit. Have checked fuse and plug. Have had no earlier problems. Do these ovens just ''wear out''? It is 8 years old. It is a GE Spacemaker. (November 2002) GE Spacemaker Serial...
yes they wear out. usally the first part to quit is the unit inside that creates the microwaves called the "magnetron" over time they will wear out, and so will the circuitry that runs the entire microwave, some will last 8 years like yours, some only a year or 2. 8 years is pretty good for the life of a microwave. but yea, its time to get yourself a new one. good luck to you
Jan 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker xl 1400 microwave stopped heating & there is an odor like melting plastic Can it be repaired. Is it worth it to repair. Unit is 8 years old.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fgkjf
Dec 07, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave display is flashing. Keypad is unresponsive. Boiled water for a long time under the unit. Person attempted to operate microwave. Loud boom and then this. There is a smell of...
Microwave is 16 years old. Replaced it. Service call was going to be half the cost of a new one with no assurance that problem could be fixed once it was diagnosed.
Jan 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker xl microwave oven jvm1630
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
You'll need to remove the oven from the wall.
This is safer with two people and the installation instructions will be of great help.
Dec 09, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven does not heat anything
It's probably a defective magnetron.
This should have a one-year full parts and labor warranty, then another several years on the magnetron, typically 9 years.
A typical service call for this might run about $175 for the visit and repair labor, assuming the magnetron is still covered under warranty. Compare that to the cost of buying and installing a comparable oven.
Your owner's manual will tell you how long the magnetron warranty is.
You can save that home visit charge and get a diagnosis for about $25 or so by removing it from the wall and taking it to the nearest GE-authorized servicer.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Nov 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Can I reuse mounting plate for new microwave?
i always reccomend to my custs that they stay with the same brand for same mounting bracket, dontreally know a way to verify other hten removing hte old micr first and then before purchasing ask to open box to check
Mar 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
333 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
