Question about Oster 465 Work Top Blender
MODEL 438 SERIES A CHROME BEEHIVE OSTERIZER
HELLO! I AM JUST TRYING TO FIND OUT WHAT YEAR MY MODEL438 SERIES A CHROME BEEHIVE OSTERIZER WAS BUILT.CAN YOU HELP ME?THANK Y6OU,WARREN
Oster makes a high-itch whining sound
Sounds like the bearing for the blade on the bottom of the pitcher may be in need of replacement.
Aug 13, 2017 | Oster 4094 Designer Classic Beehive Work...
MY OSTERIZER NEEDS A NEW RUBBER RING.
What model do you have? Without a model number I can't be sure but most Osterizers take this one.
Aug 16, 2011 | Oster Blenders
Where to buy glass jar for my osterizer pulse matic blender 10 speed
Try "The Gourmet Depot" website or search "small appliance parts" and find a site that carries the Oster blender part. You will need the model # of the blender.
May 20, 2010 | Oster 006832000000 10Speed Blender
My blender died last night. I flipped the switch and the blade did not move. It was trying....but eventually stopped trying. Now nothing happens when I flip the switch. I have been using it daily for over...
:( my condolences to the blender family.Unplug it its life support and accept your loss. Gently wrap the cord around it and lay its body softly in the trash can. At least you know it tried to the very end. As you walk the isles of walmart, I feel you will find another to take its place.Good luck.
Jul 08, 2009 | Oster 4124 Beehive Work Top Blender
Osterizer blender problem
Is the black plastic part, seal, and glass portion snugly fitted together? If so, it's likely that the black plastic part isn't making contact with the pin. On mine I have to turn it about a quarter turn to lock it to the motor/ drive pin.
If I have a hard object such as ice cubes too firmed placed in the blender against the blade and the glass, I shake the container to loosen the materials and reseat it onto the drive pin as mentioned above.
May 09, 2009 | Oster 4134 / 4126 Classic Beehive Work Top...
Square drive pin for Osterizer blenders?
I simply slid a small screwdriver in through one of the holes under the base to prevent the fan from spinning and unscrewed the pin counterclockwise using some small channel lock pliers. No disassembly necessary.
Jan 26, 2009 | Oster 4134 / 4126 Classic Beehive Work Top...
Osterizer
Thanks to some good leads, I determined the cause of the problem and ordered a part. Hopefully, that will resolve the problem.
Apr 23, 2008 | Oster 4134 / 4126 Classic Beehive Work Top...
Help with a Dismantled Osterizer Classic Blender
With the unit upside-down and the bottom off the wires on the right side of the switch go like this:
yellow on top
black on middle
red on the bottom
No wire connects to the 4th connection point (top left side).
R.
Aug 17, 2007 | Oster 4134 / 4126 Classic Beehive Work Top...
Oster 465 Work Top Blender Logo
200 people viewed this question
Top Oster Blenders Experts
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Dave
Dave
Are you an Oster Blender Expert? Answer questions, earn points and help others
