Question about Maytag M6Q10F2A Air Conditioner
Window air conditioner changes (raises) temps on its own
The digital temperature control changes by itself. I set it at a temp. and then it goes up higher on its own until it gets to 88 degrees and then of course it doesn't cool. This started as an occassional problem and now it is constant. I unplugged the unit to see if it would "reset" but that didn't work.
I checked to see if it had iced up inside due to the amount of humidity but that isn't the problem.
At first the remote contol seemed to work better than using the touch panel in keeping the temp stable and now there is no difference. We have had it for 2 years.
the model # is different than the one listed. The model# for our window maytag air conditioner is: M6Y12FB-J
4 Suggested Answers
SOURCE: 9000 btu maytag portable AIR CONDITIONNER Model M6PO9D2B-B
Reasonalbe rule of thumb is a difference of 10 degrees Centigrade.
Charlie
Posted on Aug 18, 2009
heatman101
  • 43501 Answers
SOURCE: Maytag window air conditioner, blowing, not cooling
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on May 31, 2010
  • 266 Answers
SOURCE: On my Maytag M6Q10F2A Air Conditioner there is a
yes.
Posted on Aug 08, 2010
General Electric oven how to reset thermostat
First of all, most oven thermometers move very slowly compared to the electronic sensors and controls on the oven. To make sure you are getting an accurate reading, the thermometer should be in the center of the oven, the oven should be preheated, then wait another 20 minutes after the preheat beep. If the temperature is less than 35 degrees higher or lower at this point, it can be adjusted via the controls. Usually on GE ovens you press and hold bake and broil at the same time until SF comes up in the display. Then press bake, then use the arrow keys to raise or lower the temperature setting. If the temperature is more than 35 degrees off, you may have a bad sensor, bad control board, or other problem.
Aug 08, 2014 | GE Profile JTP18 Electric Single Oven
1992 buick cenyury dual climate controls with settings both full hot with digital display reading 90 with vehicle warm restarting first comes out hot after running for a few mins then 90 degree digital...
look like the program is not working. if the set temp, is lower than the real temp, heather should come on.
if the set temp is higher than the ambient temp. the ACC should come on.
I will try one first, then setup the other.
Jan 21, 2014 | 1992 Buick Century
99 Buick Park Avenue, climate control turns temp up by itself.
It takes special equip to diagnose this problem, so off to the dealer with you on this one.
Oct 09, 2012 | 1999 Buick Park Avenue
Air conditioner will not stay on a selected temperature in cool mode for more than 3 seconds. For example, you can change the temperature to 70 degrees and it will blink for 3 seconds and move back to 88...
Don't you just hate electronics? The control might be sensing a bad thermostat. Especially considering that the manual says that the max temp is 86 (not 88).
Jun 03, 2011 | LG LP0711WNR Portable Air Conditioner
How to set fridge temp
    1. The first thing you must know is that your refrigerator should be set at 37-38 degrees. Anything at 40 or higher and you are risking food born illness (food poisoning) or spoiling your food. Place your magnetic thermometer in the refrigerator.
    2. Set your dial on your refrigerator to the second lowest setting. (If your refrigerator is already equipped with a digital thermostat, simply set it for 37 or 38 degrees and do not move on to the next step)
    3. After 2 hours, check your thermometer reading. If your reading is 38 degrees, there is no need to go higher and you are ready to put your groceries in. Be sure not to open and close your refrigerator during these two hours or your temperature reading will be incorrect.
    4. If your reading is higher than 38 degrees, move your dial up to the next coldest setting and repeat the steps every two hours until you reach the correct temperature for your refrigerator.
    5. Once you have reached the correct refrigeration temperature for your refrigerator, place the magnetic thermometer in the refrigerator permanently and watch for changes.
    Typically, your refrigerator temperature will need to be adjusted with the seasons, a higher setting in the summer and a lower setting in the winter.
Dec 19, 2010 | Freezers
I have to adjust my oven temperature with an oven thermometer. I have to set the oven higher to get to the temperature I want. It's sometimes as much as 100 degrees lower than the setting. To get it to 350...
Oven temp sensor failure, possible control board problem. Unit thinks its a different temp. sensor connects directly to control....suggest you to call maytag cust service....sometimes they will assist with parts
Jun 09, 2009 | Maytag MER6772 Gemini Electric Kitchen...
When I change the temp. setting it keeps heating at original temp
The keypad appears to working correctly.
When you alter the set temperature via the keypad the display will flash the temperature thats to be acheived, once it stops flashing the keypad will revert back to the current temperature of the water.
Hope that helps,
Ian.
http://hottub.synthasite.com
May 24, 2009 | Balboa Instruments Duplex Digital Panel 2...
GE JKP26GOP1BG Electric Oven won't maintain temperature
You will need to replace the temp probe Call704-891-6557 we'll tell you how to do it safely.
Mar 14, 2009 | Ovens
Kitchenaid Superba Gas Range - Oven temperature problem
The problem is: the temp seems to be 'stuck' at 260 and will not allow any higher settings.
Calling KitchenAid proved to be unuseful. The manual did not have this item in the troubleshooting pages. Resetting the power does not help.
The SOLUTION:
There is really no problem besides that the temp display setting has been somehow set to be celsius (metric system) rather than farhenheit (english system). Changing this setting somehow can be easily touched off without knowing, thus the "I didn't do anything and yesterday it was working fine..." comment from family members.
The FIX:
Reset the temp display back to farhenheit (F). This is done by opening the oven door, then hold down the 'Broil' button until you hear a beep from the control panel. The same method may be used to change from Farhenheit back to Celsius.
Prevention:
I speculate the inavertent change of the temp setting is done while cleaning the flat control panel. So the best thing to do is to always 'LOCK' the control panel when cleaning the controls. This is done by holding down the keypad "3/lock" for a few seconds until the display shows LOCK.
(The solution was already posted when I arrived at this page. I just organized it a bit by adding some details and a preventative comment. Many thanks to those who posted earlier, solving my issue as well. I hope my writing presents a clearer and quicker read to the next person)
Apr 06, 2008 | KitchenAid KGST307 Gas Kitchen Range
Maytag M6Q10F2A Air Conditioner Logo
236 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
