Question about Micrografx Designer 9 Full Version for PC
I'm running Designer 9 with Windows 7. I want to import a jpeg file, but when I tried it said DESIGNER WAS UNABLE TO TRANSLATE THE DRAWING: COULD NOT TRANSLATE FILE 145890.JPEG. EITHER A TRANSLATOR FOR THIS FILE TYPE IS NOT INSTALLED, OR THIS TYPE ARE NOT SUPPORTED. CHECK TRANSLATION LOG C:\PROGRAM FILES (x86)\MICROGRAFX\DESIGNER9\TRANLATE.LOG... When I was running the program with windows XP, there were no problem at all. So, what should I do??
  • 164 Answers
SOURCE: unable to open micrografx draw 6.0 in WinXP SP3
uninstall and reinstall the app
Don't Forget to rate the advice!!
http://www.aa1consulting.com
Posted on Jul 26, 2009
pctech1
  • 1940 Answers
SOURCE: I have been using Micrografx Designer 3.1 in
The present Graphics DLLs are compatible with Designer 3.1 with OLE (dated May 28, 1992). If you are running an older version of Designer on the OWS and the drawing uses Designer fonts, displaying the drawing would give a protect violation from DCP by MGXLIB.DLL because the MGXFNT.DLL are not compatible.
You can replace the older version of the MGXFNT.DLL with a new one. To do this:
  1. Copy MGXFNT.JCI from the C:\FMS\BIN directory to designer libraries directory (MGXLIBS) and change the file extension to DLL (i.e., MGXFNT.DLL).
  2. By default, the MGXLIBS directory is located under C:\WINDOWS; however, you should copy the file in the same directory that is pointed to by the Libraries parameter in the Micrografx section of the WIN.INI (e.g., Libraries=C:\WINDOWS\MGXLIBS).
Posted on Feb 22, 2011
taran_2005
  • 10515 Answers
one. To do this, copy MGXFNT.JCI from the C:\FMS\BIN
file extension to DLL (i.e., MGXFNT.DLL). By default, the MGXLIBS
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 25, 2011
muntejaya
  • 10421 Answers
SOURCE: how i can import picks.. when i try,i got only
Please re install the software then.
Regards, jay
Posted on Feb 26, 2011
SOURCE: Just installed Micrografx Picture Publisher
I had the same message trying vista. Windows 7 offers running older programs in XP or even Win 98 SE mode. That fixed the problem for me. Further I recommend running it as administrator. Hope it helps.
Walter
Posted on Apr 17, 2011
Where do i find a driver for a designer se to use with 3d software? i am running windows 7
You may need 5d or 6D to be compatible with windows 7 or 8. Check with your authorized Viking dealer for upgrade options.
Jun 02, 2014 | Husqvarna Designer I
I have been using Micrografx Designer 3.1 in Windows XP for several years now. Recently, however, I have discovered that I cannot add text to a drawing. When I attempt to do so, I get the following error...
I had the identical problem on a netbook whose OS was WinXP Lite. The solution that worked for me was to reinstall the OS, this time using the full WinXP. Thereafter no problem.
Micrografx Designer 3.1 remains an excellent drawing program that was designed for Win 3.1 but works fine under Win XP, but not Win 7.
Feb 23, 2011 | Micrografx Designer Power Pack 3.1 Full...
please save all your projectx and try re installing the programme...
if problem still persist then re install your system... yhe problem seems tobe with corrupted registry file
Feb 23, 2011 | Computers & Internet
I am getting an error stating "Designer has encountered a disk I/O error trying to access the file", while trying to open a dsf file. I am using micrografx for more than 2 years now and lately i...
Close Designer 9.
Open the folder containing the 'DSF' file.
Try to copy the file into a different folder, or onto a USB memory-stick.
Do you still get the same error-message?
If so, then the problem is that your disk-drive has a problem;
your problem is _not_ a problem with the Designer 9 software.
Your disk-drive could be "dying". Backup all your important files.
Consider replacing the disk-drive, before it COMPLETELY fails.
Jan 27, 2011 | Micrografx Designer 9 Full Version for PC
Can you convert micrografix draw files to another file format
Each Micrografx Designer 3.1 *.drw file should hold one page of drawings, and that one page should be at page 1 in the Micrgrafx layout.
Corel Designer Technical Suite X5 has a free 30-day trial period. This program will import a Micrografx Designer *.drw file and let you SAVE AS or EXPORT AS an *.svg file.
Many current drawing programs, e.g., Visio, can import this *.svg file and let you save as a *.vsd file.
But if your *.drw file contained many pages of drawings, your converted file will have many pages of drawings but often in a single large page that you cannot edit. So safer to start out with *.drw files that each contain one page, and that one page should be drawn at page 1 within Micrografx Designer.
I have used the above method to convert very old Micrografx Designer 3.1 *.drw files to Visio *.vsd files. One problem was the Greek letters that were italics in the *.drw file are not italics in the *.vsd file.
Dec 15, 2010 | Micrografx Windows Draw Graphics & Print...
Unable to load 3d embroidery on hp windows 7 . Ihave a designer 1 sewing machine
3D was intended to be used on XP and also worked for some time on Vista with the proper manipulation of updates. I don't believe that it will work at all on Windows 7.
4D does work on both Vista and Windows 7. It does need the latest update for Windows 7.
Jan 31, 2010 | Husqvarna Designer I
Transfer diamond Monogram program to floppy disk
Put the floppy disk in your computer and look at the files that are on the disk using windows explorer. If the names have common file extensions such as .hus, .vip, .vp3, .pes or the like, the files are in the wrong format for the machine to read. For the Designer 1, you must have them in .shv format. The floppy should contain 4 menu files and a couple of extras that you won't know about but they are still important for the machine to read the disk.
May 29, 2008 | Husqvarna Designer I
Importing TIF files in Adobe Designer
than change you resolution DPI
as you increase your DPI you will get batter quility but haveing quit more size than previous tif,
so try & funn,
THNX
May 16, 2008 | Adobe Photoshop 7.0 for PC
Micrografx Designer 9 Full Version for PC Logo
1,155 people viewed this question
Top Micrografx Computers & Internet Experts
Tom Chichester
Free Robux
Free Robux
Are you a Micrografx Computer and Internet Expert? Answer questions, earn points and help others
