Question about GE Security DVMRe-16CT-600 16-CHANNEL Color Triplex Multiplexer-Recorder with 600-GB Hard Drive, Ethernet
Operating disk Hi I was given a GE Security DVMRe and they could not find the operating disk so that I could load it on a workstation to be able to review what has been recorded. Is it possible to obtain this disk?
Go to this site and download WaveReader software.
http://www.gesecurity.com/portal/site/GESecurity/menuitem.11620ebca5cc0a06574efe10140041ca/?vgnextoid=4f9fe4997e789110VgnVCM100000592d7003RCRD
Posted on Aug 05, 2008
Power supply DVMRe
The DVMRe uses a 12VDC, 4.0A supply. with center +
It's a standard barrel-type connector.
Note that if the supply isn't capable of 4 Amps or better, the unit will turn on, then go back off immediately, then try again forever
Dec 07, 2011 | GE Security DVMRe-16CT-1T 16-CHANNEL Color...
My GE Security DVMRe-16CT-1000 16-CHANNEL I power
Sorry this thing it garbage now.The hard drive have bad sectors on the boot up.This can't be repair except replaced the hard drive.Not worth to fix,if have to replaced the hard drive.
Jun 15, 2010 | GE Security DVMRe-16CT-1T 16-CHANNEL Color...
DVMRe pro power/start up problem
It sounds like a bad power supply the DVMRE requires a 5.2amp power supply alot of the older models have a lower rated power supply 9 out of 10 times this start up problem can be resolved by replacing the power pack.
Jan 25, 2010 | GE DVMRe-Pro
I have a dvmre-10ctII-160,I lost the code and need to bring back to factory settings can you help
Go to this URL: http://www.gesecurity.com/portal/site/GESecurity/template.GESShort?product_sku=DVMRe-Pro it will take you to a contact form for GE security Systems...give them all your details including you GE security Pin if you have one or give them the Serial Number....and tell them you need the code they should have it on record for that serial number....hope this helps,ben
Aug 11, 2009 | GE DVMRe-Pro
Need to get video off dvr
From the user manual page 71:
5.2 Quick Archive to CD
Archive to CD on the Disk Analysis Screen by selecting the time and date and pressing the record
button. The QuickWave Setup must be set to ON from the Archive Setup → Quick Wave Setup menu
(see section 3.15). The Archive Incident menu should appear.
1. Use the Jog to modify the time parameters and use the
Shuttle to move between the Start and Stop fields.
2. Press the Record button on the front panel when satisfied.
3. The CD Writer will open the CD tray when completed.
The video may now be viewed on any PC equipped with a CD-ROM.
You can download the complete user manual here:
http://www.gesecurity.com/portal/site/GESecurity/menuitem.f76d98ccce4cabed5efa421766030730?selectedID=1965&seriesyn=true
Dec 24, 2008 | GE Security DVMRe-16CT-600 16-CHANNEL...
Unable to connect remotely to dvr unit
I'm presuming you are using Internet Explorer. You may need to change your browser's security settings to solve this problem.
Using Internet Explorer, click on TOOLS, Internet Options, Security, Local Intranet, then move your slider all the way down to Low and click Apply.
Dec 07, 2008 | GE Interlogix Dvmre Pro 10 Channel Triplex...
Dvmre triplex
I would switch monitors and see if the problem still exists. Sounds like the monitor not the Dvmre.
Aug 07, 2008 | GE Security DVMRe-16CT-600 16-CHANNEL...
Intaller code
The factory default code to reset the system is 8111, however this will reset all program functions back to the factory settings, with the exception of the time and date. The default Operator code to use the system is enter, enter, enter, enter. This should allow you to operate the system.
May 21, 2008 | GE Security DVMRe-16CT-600 16-CHANNEL...
Help me!
I have strongly recommended that change your power supply with the same specification voltage and amp. I have installed so many GE DVR's most of DVR's restart when the power supply is not working properly or HDD have bad sectors. I also recommend use the scan disk on you HDD for proper checking of your HDD.
FROM
AI
Jan 29, 2008 | GE Security DVMRe-16CT-600 16-CHANNEL...
GE Security DVMRe-16CT-600 16-CHANNEL Color Triplex Multiplexer-Recorder with 600-GB Hard Drive, Ethernet Logo
353 people viewed this question
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Michael Galve
Michael Galve
Are you a GE Home Security Expert? Answer questions, earn points and help others
