Question about Panasonic SL-S261C Personal CD Player
Player says no disk even if there is a disk and won't spin.
Can you tell me what part is broken so i can order it?
  • 4 more comments
  • vzmike Jul 25, 2008
    error code f15
    sl-s261c
    i am new to this ..am i supposed to repost or wait?
    disk does not spin.error code f15 for model #sl-s261c. any advice besides clean lens ?
    how do you test a lens?
    where can I take player to test lens?
  • Panasonic Master
  • 13,433 Answers
Problem with the lens most likely, I would take it in to be tested first, if you got warranty then that covers it.
Posted on Jul 25, 2008
    Sergeant:
    Champion:
  • 310 Answers
Tell ur model no pls.............
  • khader ibrahim Jul 25, 2008
    if u have warranty then cover it.........no warranty means better go to company service center............
    Genius:
  • 3,422 Answers
HI,
Please use lens cleaner to clean the lens.
  • 1 more comment
  • Priya darshan Jul 25, 2008
    see if the player tries to read the disc. Load a disc and listen.
    Does
    the player make squealing noises or is it totally quiet? Squealing
    noises may indicate that the player is trying to synchronize with the
    disc but can't due to an obstruction on the lens or in the laser path
    inside the pickup or a defect in the pickup. This can also be caused by
    an intermittent signal problem due to a faulty ribbon cable.
    Totally
    silent means that the photo sensor is not getting any usable input from
    the laser at all, meaning that the pickup is "blind" for lack of a
    better word.
    This can be caused by an obstruction of the beam by
    foreign matter on the lens or inside the pickup all the way to a
    marginal or failed laser diode and/or photosensor array. This can also
    be caused by a bad ribbon cable with one or more severed traces.
    You
    could try to clean the optics. This is the most common malfunction as
    far as i know in all disc players. It would involve taking the cover
    off and finding a way to expose the lense, and then cleaning it with a
    very gentle brush. some players have a cover for the lense that swings
    to the side during playing, this greatly reduces the chance of dust
    accumulating, but its still worth the try.
    If you actually see dust on the lense, then its just that simple. clean, close, play.
    It may also be worth your while to check on the small shafting that
    guides the carriage of the laser pickup. Dirt, grome, dust and
    solidified lubricant can cause stoppage of the carriage and the laser
    eye then fails to read the next track.
    You can also take a cotton ball and lightly dampen it with
    alcohol.Gently swirl it over the lens.Take another cotton ball (dry)Gently
    common f15 errors are caused by the cd players lid not being closed,
    you need to see if the protruding plastics inside your cd player pushes
    the closed lid detection properly. If not, it needs some manual
    disassembly.I strongly recommend you to get it repaired.There are no home remedies.
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
No disk error
Try another disk, if not this unit may be broken and repair may not be economically to your advantage. These drives where out - they are a mechanical spinning part.
Apr 12, 2014 | Polaroid 7'' Portable DVD Player
Disney d-style karaoke won't read disk or spin disk
The problem is in the laser pickup assembly, the pladder motor is not working that spins the disk, and unfortuneately the only way to correct this is to replace the entire assembly which probably won't be cost effective.
Mar 06, 2012 | Televison & Video
My CD player keeps displaying no disk and wont play the cleaner disc, is something dirty or broken?
Hello
If it does not play the cleaner disc, just inspect whether the disc inserted in spins inside it. You can check this by open the upper cover of the player, and inserting a disc into it. If inserted disc spins inside, and the player won't read it, the fault is with its laser pickup unit, and it should be replaced with same type and number.
If the disc dos not spins, the fault is with the sled motor [the motor that spins the inserted disc], has damaged, and should be replaced. OK.
Dec 25, 2011 | Sharp Audio Players & Recorders
Restored an still tells me to restore
If you did a hard reset and it still doesn't connect, not even to windows explorer, most likely you have a broken logic board or broken hard drive. Try to listen to the HDD when it is spinning - is there a repetivie sound? If so, it's a defective HDD, if the hdd spins smoothely mostlike a broken logic board, you can try to replace it yourself, there are guides websites online that teach you iPod repair skills, if you're already a little tech savy.
May 09, 2009 | Apple iPod MA446LL/A MP3 Player
Cover fordisk holder is broken
You can trick the player into thinking the cover is closed and still play DVD's.
Open the lid and notice the small button on the top right side. Pressing the button will simulate the "lid down" so the disks will play.
You can even see the cool red laser when there is no disk.
Aug 10, 2008 | Durabrand DUR-1700 Portable DVD Player
Broken dvd player
the problem is that it is a cheap unit, and cheap dvd players fail fast.
i suggest spending more for a better player...
Mar 28, 2008 | Durabrand DVD-1002 DVD Player
Disc won't load and then shows weird symbol in right corner
Check the black spindle that holds the disk it may be cracked or broken or the little spring tabs are broken. If this is the problem when the disk spins it lifts up and the head doesn't read the disk, this is what has happened to mine. I am trying to locate the part but so far have not had luck finding it.
Sep 17, 2007 | Audiovox D1708 Portable DVD Player
Panasonic SL-S261C Personal CD Player Logo
77 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
