Question about Maytag M7Y15F2A Air Conditioner
Maytag air conditioner Model# M612FB-J
The digital temperature control changes on its own and will raise the temperature. I have unplugged the unit hoping that it would "reset" but that didn't work. This problem began with it happening occasionally and now it is almost everytime I try to use it.
At first it seemed if I adjusted the temp using the remote, it seemed more likely to stay at the temp it was set at. Now it doesn't seem to matter.
The lower the temp., the more likely it is to stay at that temp.
Thank you for your assistance!
  • farmalldiva Aug 04, 2008
    I have the same problem. It had shut itself off, I thought it was done for. None of the buttons would work, remote or on the panel. Couple of hours later it turned itself back on and will not stay on the setting I had it set on. It beeps and raises the temp. clear up to 88 over a period of time with out me touching it.
  • 182 Answers
SOURCE: Air conditioner with no power
bad switch or wire
Posted on Aug 13, 2008
  • 334 Answers
SOURCE: Need a new control panel for Maytag mey12f7e
Call this number, they can get you a remote, probably the easiest and cheapest route
800.935.0062
Posted on Jun 11, 2009
SOURCE: 9000 btu maytag portable AIR CONDITIONNER Model M6PO9D2B-B
Reasonalbe rule of thumb is a difference of 10 degrees Centigrade.
Charlie
Posted on Aug 18, 2009
co7196
  • 3433 Answers
SOURCE: Wall-unit Maytag Air Conditioner has power, but nothing else
It' worth a service call. If there is a need to get into the electrical or diagnos a pc boar problem. Good Luck. A tech can probably go sraight to the problem. Ned
Posted on Aug 28, 2009
  • 266 Answers
SOURCE: On my Maytag M6Q10F2A Air Conditioner there is a
yes.
Posted on Aug 08, 2010
Our remote control will not work with our Dometic Model 57915 unit. It used to when you changed the temperature up or down you got a beep from the unit. When you push the on/off button, it used to beep...
The comfort control center requires 12 VDC . If a fuse blew that feeds 12 VDC to control box at ceiling for some reason in your panel when unplugged accidentally, that would cause the remote/wall and control box at ceiling not to communicate.
Jun 05, 2011 | Dometic Rooftop RV Air Conditioner
Repair of room air conditioner /window unit
You need to check the main breakers in the breaker panel......
Sep 01, 2008 | Heating & Cooling
The Maytag a/c unit model #M6Q10F2A has been working fine until this morning. The display reads "EE" and the a/c does not work. Unplugging the unit does not help.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 29, 2010 | Maytag M6Q10F2A Air Conditioner
The digital temperature indicator is stuck at 88 and will not change from the remote or the temperature button. Not blowing cold air.
I suggest that you try turning the unit off, unplugging it, and leaving it turned off for a couple of minutes. Sometimes these appliances can be reset by turning them off, waiting, then turning them back on. It's similar to rebooting a computer when it's hung-up.
Aug 12, 2009 | Maytag Heating & Cooling
800.935.0062
Jun 11, 2009 | Maytag MEY12F7E Air Conditioner
Lost Remote
go here: http://www.partlinx.com/haier.asp
andsearch for the part. You have to start with your state, and then gofrom there. For my area, the remote is 19.99, plus shipping and tax.Also, try eBay. You can find a lot of things there!
Aug 24, 2008 | Haier hwr10xc6 Air Conditioner
Mach 3 RV a/c problem
I'm having the same problem tried a new thermostat and cleaning unit inside and out and still the same results. Seems like a control board not working.
Aug 17, 2008 | Dometic Rooftop RV Air Conditioner
Maytag on the out
Our maytag window air conditioner (12,000 BTU; model#M^Y12FB-J
changes the temperature on its own. And it always goes up in temperature as high as 88 degrees and of course then it isn't cooling at all. I checked to see if frost or ice had collected on the copper tubing but it hasn't. I unplugged it for 1 hour to see if it would reset but that didn't help. It is about 2 years old. When it first happened, it seemed that if I used the remote it would stay at the right temp., but now it doesn't matter. It's hot and humid in my house - help!
Susie
Jul 17, 2008 | Maytag M6Q10F2A Air Conditioner
Unit is switched on but no air
Nothing...Maytag SUCKS!! I have the same problem and Maytag says it could take months before they get new parts to fix the faulty control panel. My unit never shuts off. Only way to turn it off is by unplugging it out of my wall socket and it has already caused my living room electrical socket to blow out. I will never buy Maytag again.
Jun 13, 2008 | Maytag M7Y12F2A Air Conditioner
AC changes temperature by itself!
If it's not some sort of built in economizing feature, someone else isn't getting up and changing the temperature while you are asleep and the air conditioner fairy is playing tricks, then the control PCB is in need of repair and will have to be repaired through a sears authorized repair center.
I am a bit surprised that it will allow you to set the temperature to a low 70 degrees as this is pushing the limits of an air conditioner. They tend to freeze the coils at around that temperature.
Jun 07, 2008 | Kenmore 75050 Wall/Window Air Conditioner
Maytag M7Y15F2A Air Conditioner Logo
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
