Question about Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum
Motor is getting loud and smells like is burning
  • 1 more comment
  • clclark Jul 29, 2008
    This has been on ongoing problem for about a year. It's getting louder (already very loud) and starts to smell like it its burning. I've replaced the belt thinking it would help, but nothing has improved. Considering purchasing another vacuum, but may not get another Hoover if this is such a common problem.
  • andyj_pa Mar 07, 2009
    I have the same problem. Had it less than a year so not sure why motor or fan blade would go bad that soon. Any other possibilities?
  • assir14 Mar 13, 2009
    Way too loud and smells horrible, same as the others.
  • 281 Answers
Time to bury the poor thing don't let it suffer any more motors gone.unless you payed a lot for it i would put it out to pasture.because the motor runs about 45 to 50 dollars depending on which kind of vacuum you have
Posted on Apr 10, 2009
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=832949
Generic problem for all Vacuums
Posted by lchill on July 25, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I am not sure what type of vacuum, make or model # it is but if your motor is getting loud and it smells like it is burning, it could be 2 things, either you have a broken fan blade or your motor is on it’s last legs and is burning up and would be in need of a new fan and motor replacement. Please feel free t contact your local vacuum cleaner dealer in your area.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 25, 2008
3 Suggested Answers
  • 43 Answers
SOURCE: Hoover H3030-006 240 V Motor making
If you have little to no suction, that sound is happening because you most likely have a clog some were in the vacuum.
smell is probably your motor over working itself do to the clog.
also double check your belts on your brushes that they are moving with the motor. smell and sound could come from the brushes being jammed which would cause the belt to freeze and heat up and could burn the belt and or your motor.
if it is still running though your not in the red yetm so triple check that the machine is cleared off all clogs and jams in the belts and brushes.
Posted on Jul 02, 2011
tvservice306
  • 458 Answers
SOURCE: loud motor with burning smell
motor bad if in warranty pls send to service
Posted on Aug 17, 2009
I brought a shark need to know if i can get it fix motor making loud buzzing noise it should be still under warrnty
Motor is jammed or burnt out,is there a burning electrical smell?,if there is,and the belt on the motor turns freely by hand , then the motor is burnt out.
Jan 11, 2015 | Shark Navigator Bagless Upright Vacuum
Samsung vcu366 making loud noise but picks up
what does the really loud noise sound like? Is it a loud, whining sound? if so, the motor may be getting ready to go out. Also check that the belt isn't stuck-though you would smell burning rubber if that were the case.
Mar 08, 2014 | Samsung Vacuums
Vacuum motor noise and smell
If the ball was stuck and you sucked water into the motor it could cause it to smell like it's burning if it ruined the motor
Jan 10, 2014 | Shop Vac Vacuums
Burning smell
The motor is burnt out. Good news is that most central vacuums are really easy to get into so replacing the motor shouldn't be too hard. I haven't worked on that exact machine but the fault is unmistakable.
Jun 26, 2013 | Electrolux Central Vacuum
Hoover H3030-006 240 V Motor making a loud sound and burning smell
Jul 02, 2011 | Hoover H3030 FloorMate SpinScrub 500...
Dyson not working making a loud noise and smelling of burning
This is probably due to the motor going bad. Before purchasing a new vacuum, get an estimate for replacing the motor.
Feb 16, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
Burning smell from motor
Check your filter and also check that nothing got pulled into the motor...otherwise the motor is burning up and will need to be replaced... probably cheaper to replace the whole vacuum..
heatman101
Aug 27, 2010 | Numatic HVR200P Bagged Canister Vacuum
When I turn the vacuum on it sounds really loud, louder than usual, and after a few minutes it smells like burning rubber around the canister. The vacuum is still sucking.
The armature is probably missing a plate and the motor is about ready to burn up, but check the filter and screen on the bottom of the motor first. The screen can be checked by removing the filter and looking up at the motor from below. Clean if necessary by removing the motor. Unplug the unit first. If the motor sounds rough and smells like something electrical burning. It's going to need to be replaced. Check your model # and order a replacement. Pretty easy to install if you get the right motor. Get the foam gasket for under the motor if your replacing a three stage motor.
Jun 06, 2010 | Electrolux Centralux Vacuum
Makes a loud noise like a grinding noise then smokes comes out and it smells like burning rubber? When I take the (rod) brush off with the belt then run the vacuum there is no more noise? Please help me...
Your belt is worn and stretched and so it is slipping on the motor drive shaft. That is why it is noisy and smells like burning rubber. You simply need to replace the belt. You can get replacement belts here:
Replacement Vacuum Belts
Nov 30, 2009 | Vacuums
Eureka 5197 self propelled bagless upright
Did you check the brush roll when you changed the belt? The smell of rubber would inducate a belt slipping. So if the brush roll (part #61308-2)isn't turning, the belt would get hot and would be slipping. If the motor sounds real loud, then you could have a bad motor(part #60775-4).
Feb 14, 2008 | Eureka 5197AT Upright Vacuum
Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum Logo
440 people viewed this question
Top Kenmore Vacuums Experts
Roger Potts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
