posted by Bidulle on Jul 25, 2008
nothing happend when I insert the card I have been using for over a year now
Thanks
Comment by Bidulle, posted on Jul 28, 2008
Rats I tried via my printer and it says no photos on memory card and when I connect my digital camera via the usb it does find the pictures and I can download them.
I tried with another card it does not work but does on the printer!! The flashing blue light does not work either the system says I have to insert a cd with instructions which I don't have since it was all installed in the shop. Great thanks for helping
Best Solution
posted on Jul 25, 2008
If you have made sure that all cables are correctly connected. Then I would try shutting down the computer and wait abou 5-10 seconds and then restart.
If that doesnt correct it, I would check to make sure that it is installed correctly in the Device Manager.
To do this, click Start > Run > type devmgmt.msc and press Enter. This will open Device Manager. Once there look for items with a yellow ! beside them. These are items that are not installed correctly.
If you see any yellow ! I would suggest trying Windows Update to check for drivers. To do this, open Internet Explorer then click Tools > Windows Update. Once it lloads you will have the option of Express or Custom. Choose Custom. Your machine will be scanned for updates. You will need to scan through the Critical, Software, Hardware updates on the left and make sure that all of them are selected and then choose Review/Install updates at the top of the screen. This will start the download and installation process of the updates. You will probably be prompted to restart after the updates finish.
Thanks
Thanks
Comment by zukirider, posted on Jul 28, 2008
Just a question,
Have you tried this equipment on another machine? It could just be a faulty item.
Thanks
Thanks
Rating Locked! (?) Bidulle has rated this solution as Thanks for Trying
Suggest a new solution for this problem
Post a New problem for HP HP Pavilion dv6000z 15.4" Notebook
Email this problem
Email this problem
Can you Help with these PC Laptops problems?
HP HP Pavilion dv6000z 15.4" Notebook Laptop...
horizontal lines on the monitor
Five horizontal lines on... Answer This...
hp dv 6373
hp dv 6373
ciao, scrivo dall'italia, ho un... Answer This...
HP Service Center in Delhi
RT Outsourcing Services Ltd... Answer This...
change bitsetting/booktype on...
I want to change bitsetting,... Answer This...
Recording a Digital Diary
i do not know the correct... Answer This...
Repair Service
Find PC Laptop Repairman Near You:
