Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
Printhead we have been told that our printhead needs to be replaced, it sound like you might have experience with this problem, or a manual, thanks, ted@habitatsinc.com
  • tjdegrood Aug 24, 2008
    I am experiencing vertical streaks. I have performed the "eliminate light stripes" maintenance procedure
    multiple times. I have turned the printer off for over a day and then restarted the process. I have sent postscript files to the printer to try clear the blocked jets. But, when I print a test page the same three magenta printhead jets always remain blank. I contacted my local Xerox Sales Partner and described the condition. Over the phone he diagnosed the problem as a bad printhead. He quoted ~$700 for the printhead plus the service call. All-in-all the cost approaches $1000. At this price, a new printer appears to be a better value. Any suggestions?
    President:
  • 2,072 Answers
What problem or fault code are you experiencing?
I also am assuming you don't have a maintenance agreement on the machine?
I can tell you in detail how to replace that print head. It really isn't that difficult. Just a bit time consuming. I would guess an hour and a half .
But lets start with whats going on with the printer .Maybe it can be fixed much easier and far less expensively. That print head is $450 wholesale. SOooooooooo lets see if we can get it fixed for you without a print head ok.
Posted on Jul 27, 2008
Why do my pictures have tiny black lines running vertically thru them when I print pictures?
Hi
If you have recently changed one or more of the cartridges you may need to align the print head, the following steps explain the process:
To align printer from the printer display
1. From the Home screen, touch the Settings icon, and then touch Tools.
2. On the Tools menu, touch the down arrow to scroll through the options, and then touch Align Printer.
3. Follow the instruction on the screen.
To align printer from the printer software
On Windows:
a. From the Start menu on your computer, click All Programs, click HP.
b. Click the HP Photosmart 5520 series folder, click HP Photosmart 5520 series.
c. Under Print, double-click Maintain Your Printer.
d. Under the Device Services tab, double-click Align Printheads.
These instructions were copied from the manual at the following link
http://h10032.www1.hp.com/ctg/Manual/c03353113
If this doesn't fix the problem, you may like to check the HP support page for the 5520 at the following link ---> support hp com
Trust this helps, best regards Alan
Feb 11, 2015 | HP Office Equipment & Supplies
I have a Lexmark S600 series all in one printer. I use the 100 XL ink. The background of every line on the page is being saturated with magenta ink. I replaced the cartridge, which was pretty full, just to...
Sounds like printhead problem... Call them and ask for replacement. But if your warranty is out of date, than you have to buy new one by yourself, take a look on amazon: Amazon com lexmark s600 printhead I hope this was helpful. have a nice day
Jun 27, 2011 | Lexmark Interact S605 All-in-One Color...
My printer ESP5 shows an Error code 3807. I do
Maybe the printhead is not working properly. call Kodak and they will going to replace tht printhead. Thanks
Sep 01, 2009 | Kodak Office Equipment & Supplies
Black text not printing!
You need a new printhead, QY6-0063-000. The instructions are packed with the new printhead.
Feb 07, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Brother MFC 210C Machine error 41
Error 41 refers to the printheads which is a common problem with Brother machines. The printheads will need to be replaced. On some machines, Brother has extended the warranty to cover printheads because of the excessive failure rate. Contact Brother to see if you qualify and they may send you new printheads along with easy instructions to replace them. Also please rate this solution with a fixya rating. Thanks!
Dec 27, 2008 | Brother MFC 210C All-In-One InkJet Printer
Printhead needs replacing
The printhead is completely user replaceable and need no complicated instructions.
1. Remove the ink ribbon.
2. Looking from above, find a small shiny lever to the right of the printhead.
3. Lift the lever with your hand and remove the printhead by pulling it upwards (make sure the printer is cold).
4. Reverse the procedure to install the new printhead.
Be blessed.
Oct 31, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
HP Officejet d145 print head problem
Did you replace the PRINTHEAD, or did you replace the INK CARTRIDGE? They are not the same on the D145.
Good chance that you may have replaced the ink cartridge, not the magenta PRINTHEAD which sits under the ink cartridge.
PS - in my experience, non-HP ink cartridges clog up HP printers with separate printhead mechanisms... any possibility here?
Jul 26, 2008 | HP OfficeJet d145 InkJet Printer
Phaser 8550 error 19,004.40
The printhead was installed in another machine and the codes do not match. You need to manually sync them. Here is the procedure:
Manually synchronize the Printhead and Electronics Module codes.
NOTE: The Printhead and Electronics Module codes should synchronize automatically when a new printhead is installed. If a 19,004.40 error occurs, it is possible that the replacement printhead was previously installed in a different printer. After manually synchronizing the Printhead and Electronics Module codes, be sure to test the new printhead for print quality defects.
To manually synchronize the codes;
1). Power OFF the printer.
2). Disconnect the printer from external devices (A/C power can remain connected).
3). Locate the "Factory Only" port on the electronics module (located between the PS and PE lights (Figure 1).
4). Use a Hard Disk Drive (HDD) jumper (Figure 2) to short the top two pins.
NOTE - If a HDD jumper is not available, use another conductive item, such as a screwdriver, to short the pins. Use caution to avoid contacting the surrounding frame, as this may permanently damage the Electronics Module.
5). With pins shorted, power ON the printer.
6). When printer reaches the mechanical initialization stage of the power on sequence, power the machine back OFF.
7). Remove the HDD jumper.
8). Code should now be synchronized. Power ON machine and verify the 19,004.40 error does not re-occur.
NOTE - If error persists after this procedure, attempt the procedure again, and be sure to allow the printer to complete its BIST and POST test before powering OFF in step 6.
Jun 29, 2008 | Xerox Phaser 8500/DN Printer
Lexmark Colour C752 108 service printhead error
You are correct, Below is that section from the manual. Before you follow this, i've found in the past that the cable connector is not seated properly on the rip board, so check this first.
If you require any of the instructions on replacing the printhead or board let me know.
Yellow Printhead Lost Hsync
Check for the correct installation of the all the cables to the RIP
Board assembly and to the Printhead assembly; J2, J3, and J4 on
the RIP Board. Go to “RIP Board” on page 5-11. If the cables are
connected correctly to the RIP Board and to the Printhead
assembly, replace the following FRU:
“RIP Board” on page 4-11
If this does not fix the problem replace:
Yellow Printhead Assembly - Go to “Printheads” on page 4-33.
Note: Whenever a printhead assembly is replaced, it is necessary
to perform the “Printhead Adjustments” on page 4-1.
Jun 03, 2008 | Lexmark C762 Laser Printer
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
44 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
