Try unplugging both the router and the modem for 2 minutes, then plug them back in. Wait for another 2 minutes and try to reconnect to your wireless network. This usually resolves the problem 99% of the time. While you wait check all the connections to your router and modem.
Phones when plugged into laptop will terminate any sim card functions such as making calls to prevent data loss if a transfer is taking place.
This is normal and always happens there is no way to disable it just make sure you only plug it into your Laptop when you require to transfer files to phone or use the manufacture software to perform an task which requires it to be plugged into laptop..
first did ur mobile has the fecility of internet then u can connect the mobile as a moderm for pc too. in mobile you want to connect the net means you have to go to settings and conect the connectivity and call your service provider to connect the gprs in ur mobile
The moderm could be bad or you do not have the correct driver for this moderm. removed the moderm, and uninstall the software driver and do it over. if it does not work try replacing the moderm with another kind.This might work.make sure you go to start,control panel, hardware device and look for your moderm and there should not be an exclimation mark in front of your modem, if it is, right click your mouse while high lighting your modem,and uninstalled it. Restart you pc and do the process over. Good luck
i think you are a little confused, your laptop may have a wireless card internally, but you need a wireless broadband or cable router for the wireless adapter to pick up a signal.
A fax modem cannot be wireless and cannot be broadband as you cannot fax using a broadband connection.
Assuming you have a broadband connection you will need a wireless modem/ router or roter connected to a broadband modem, not a standard 56k dialup modem as they aren't wireless or broadband.
