No usb cable in carton no instuction booklet in carton no advice as to ink cartridge number and only color cartridge in carton
  • 37 Answers
Most printers don't come with a USB cable. You'll have to purchase one from someplace like Best Buy or Office Max. Just tell them th model number of you're printer and they'll get you the correct USB cable.
You can look up the user manual for your printer on the manufacturer's website (like Canonusa.com, or hp.com), by entering the model number of the printer in the Search box.
Posted on Jul 25, 2008
How to identify genuine and fake toner supplies?
When buying ink cartridges, first of all to carefully observe the vacuum bag. Authentic ink cartridges and bags close to the box dense, no air bag. Fake and shoddy ink cartridges vacuum pumping is not complete. Open the vacuum plastic bags, genuine ink cartridges should be clean and dirt-free. Carefully observe the top of the ink cartridges sealed plastic stickers, real ink cartridges sealed film flat paste, fake ink cartridges loose, it is easy to hand down. Second, look at the sealing tape. Genuine ink cartridges and fake ink cartridges are not the same, fake ink cartridges is a transparent adhesive on the word, strong sticky, it is easy to tear the surface of the packaging cartons. Genuine ink cartridges are strong texture, sticky and sticky can not be separated from the carton to tear the way. I always buy ink and toner cartridge online, and I found v4ink is the best compatible toner supplies with good quality and low price.
Oct 31, 2017 | Genuine Office Equipment & Supplies
Canon Pixma 420 won't print after cartridge is replaced
make sure you are using good quality ,correct number cartridge and insert properly?
switch off printer and change data usb cable, then switch on the printer, it will work, again same ,,must be check ink carriage cable is damage?
Apr 20, 2017 | Canon PIXMA MP780 All-In-One InkJet...
My printer is a HP- 6210, Message: "remove and
Hello Cliff, welcome to FixYa.
Hard Reset the printer by doing the following:
  • Remove all the ink cartridges.
  • While the printer in ON, unplugged the power cable from the power source.
  • Disconnect the USB cable at the back of the printer (if your printer is connected through a USB cable)
  • Restart your computer.
  • Connect back the USB cable.
  • Plug the power cable to its power source.
  • Turn ON the printer if it does not turn ON automatically.
  • Install the ink cartridges.
  • If the printer prompts for an print head alignment, please do so.
If the problem persists, replace the ink cartridge. The cartridge might be defective since you already have tried to clean the contacts.
Keep me posted.
Jas
Sep 28, 2011 | HP Photosmart 2610 All-In-One InkJet...
Error 6000
This is the error code printer Canon IP1200, IP1300, etc. light blink Indicator:
3x orange 1x Green = mechanical error
if you dont have any knowlegde about printers, better bring your printer to Canon service center.
4x orange 1x green = printer absorber full
reset your printer using software ressetter or try using manual reset. different printers have different manual reset.
5x orange 1x green = black cartridge/color cartridge error
can be chip error or connector is dirty.
7x orange 1x green = black cartridge/color cartridge error
8x orange 1x green = printer absorber full
12x - 17x orange 1x green = cartridge detection error
How to Reset waste ink counter Manually 1. Unplug power and USB cable. 2. Open door and hold power button. 3. Connect power. 4. Close door, then release power button.
How to Reset waste ink counter using Resetter
1. Download software for Canon iP1200 printer. DOWNLOAD 2. Unzip downloaded file to any location using, 7ZIp, WinRAR, Winzip, etc 3. Run GeneralTool.exe 4. select connected USB port number from USB port 5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION 6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. the selected waste ink counter will be reset.
Thank you for posting. Hope this helps.
Jul 06, 2011 | Canon PIXMA iP1200 Photo Printer
I purchased a used hp psc950 printer. It did not have the manual with it. It is working, but a message was flashing in the window saying that I have the wrong color ink. I don't know the number to the ink...
you can use a USB printer cable to connect with PC.
If your black cartridge No. 45 then the color No. 78 OK
In your case the color cartridge may be defective,
Change it and try.
Apr 29, 2011 | HP PSC 950 All-In-One InkJet Printer
How do I install the printer cartrige? I do not have the booklet...
  1. Turn on your printer.
  2. Open the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press the tabs on the cartridge lids, then lift the lids.
  1. Remove the old ink cartridges.
  1. Store the cartridges in an air-tight container or dispose of them properly.
  2. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
NOTE: You can use your printer with one cartridge (color or black) at a time. To extend the life of your color cartridge and improve printing speed, install both a color cartridge and a black cartridge at the same time.
  1. Insert the new ink cartridges. Make sure the color ink cartridge is secure in the left ink cartridge carrier and the black ink cartridge is secure in the right ink cartridge carrier.
  1. Snap each lid closed.
  1. Close the front cover. The front cover must be closed to start a print job.
  1. Open the Dell Printer Solution Center by clicking Start® Programs or All Programs® Dell Printers® Dell Photo Printer 720® Dell Printer Solution Center.
  2. Click the Maintenance tab.
  3. Click Install a new print cartridge.
  4. Click Next.
  5. Select the type of cartridge you installed.
NOTE: Specify whether the cartridge is a new cartridge or an old cartridge (one that has been used before). If an old cartridge is incorrectly identified as New Cartridge in the Dell Printer Solution Center, ink levels may be incorrect.
  1. Click Next.
Dec 17, 2010 | Dell Inkjet 720 Printer
IT WON'T PRINT DO i NEED A USB CABLE IF SO WERE DO i PLUG IT INTO ON PRINTER? THANK YOU ALSO DO i NEED A BLACK INK CARTRIDGE?
Hello Grannie,
You will need a printer USB cable to connect the printer to your computer. These cables a standard for all printers and look something like thispatzky.jpg.
You should find a square like opening on the back of the printer to connect the cable.
As for the ink cartridges, I believe lexmark only requires either a color cartridge or a black cartridge to be installed. Use one of the two and the printer should work.
Thanks,
Pat
Nov 07, 2010 | Lexmark Z2300 InkJet Printer
Couldn't install ink cartridge
well if its to big or small you should get a bigger or smaaler carton or you can check the hand book with the printer it came with(i think) or go to the link below
help on changing ink cartons for printers
Jul 31, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Where does the USB cord go in printer and PC? I keep getting an error for both ink cartidges, when I just put new ones in and out several times printer gives cartidge error 50 c and PC gives instuctions on...
I assume you don't have a user manual for the A960. You can download a copy at
http://support.dell.com/support/edocs/systems/a960/en/index.htm
The getting started pages have a picture of the back of your printer. The USB device end (smaller) plugs into the lower left socket (looking at the back of the printer) and the standard USB end of the cable plugs into any of the PC USB sockets.
For your ink cartridge problem, follow the steps in the manual for maintaining the ink cartridges. You may not have removed all of the packaging when your replaced the cartridges.
Let me know if this doesn't work.
Apr 28, 2009 | Dell A960 All-In-One InkJet Printer
MY PRINTER OMLY PRINT IN RED,
The black ink cartridge is empty or the cartridge mount or the cartridge itself is dirty and gummed over. Since you only have red then your color cartridge is probably almost empty.
Apr 04, 2009 | Lexmark X5495 All-in-One &USB...
Computers & Internet Logo
David Payne
David Payne
