Question about OKI Office Equipment & Supplies
I have a okipage 4w printer and am trying to connect it to my laptop with a usb to parallel cable and am having no luck i cannot use a standard parallel cable as my laptop does not have an lpt port
  • hutchingsd20 Jul 25, 2008
    yes i know that is what i have but pc says there is no connection
  • 446 Answers
You can buy a i have a okipage 4w - 5e87b53.jpgadapter in the market to use your parallel to usb, its not that expensive
Posted on Jul 25, 2008
Do you know which connecting cables work with the Epson Stylus Photo 2200 printer. I see a sczi firewire 400? and don't know what the 3rd is. I am trying to connect it to a Mac Book Pro with snow leopard...
You should be able to connect to your macbook with a standard USB A-B cable, for most printers it's almost square at one end standard flat at the other.
You can get them from ebay or any pc/printer shop, just ask for a standard USB printer cable. Here's one on ebay:- Item number:180514570583.
For mac drivers for the printer, the best place to look is the Epson website, follow links for support and downloads, entering the details of you operating system and printer model as you go. You should arrive at a page which offers free drivers for your PC.
Jul 07, 2010 | Epson Stylus 2200 InkJet Photo Printer
HP DESK TOP 840C PRINTER CONNECTION
They do make adater cables for such problems. Here is just one such example: Parallel to USB Cable
Make sure you get the correct 25 pin cable. They have this type also:
Parallel to USB Cable 2
You can search the web for more companies. Google parallel to usb printer cable.
After saying all that and checking your printer info, I see that the 840c has both a parallel and a USB cable port. See page 21 of the manual: HP 840c Manual
If you go that route, you will need a standard USB cable. The shorter the better, but no longer than a 6' cable. Make sure you follow the iinstallation instructions for the USB setup in the manual.
Thanks for using Fixya.
Apr 14, 2010 | HP DeskJet 840c InkJet Printer
Can the P2055d be connected with a parallel lead?
Most HP's if they have a port for parallel, it is a special plug on the back that looks more like a SCSI plug. If your printer has this plug you need the special cable, otherwise you will need an adapter to convert USB to parallel.
Dec 28, 2009 | HP LaserJet P2055d Printer
Need what type of printer cable to fix to the compaq laptop from Epson Stylus C86 so i can print from laptop
You can use USB or Parallel according to the user guide. Most laptops made recently wont have a parallel port and the cables are harder to find so I recommend USB.
Jul 29, 2009 | Epson Stylus C86 InkJet Printer
Connect printer to PC
Dear! It is very to solve that matter use the USB converter for that solution and you can purchase a PC USB slot for that solution.
Thank You
Jul 27, 2009 | Epson LX-300 Matrix Printer
Trying to connect from USB laptop to parallel printer
You can't have a double hook up to it,When the parallel port is used the usb port is disabled and when you use the usb port the parallel port is disable.This is done to prevent damage to the printer.You can network the laptop with the pc and print that way though
Jun 04, 2009 | Brother MFC 7420 All-In-One Laser Printer
Connect kyocera fs680 to laptop
it depends on what laptop you have. the fs680 only has a parallel connection so your laptop needs to have a parallel port or you need a usb to parallel converter.
Jan 13, 2009 | Kyocera Mita FS 680 Laser Printer
USB CABLE
the printer is designed to work with a parallel cabel connection. usb to parallel conversion cables may or may not work.
now for the second part is, about the driver (visit manufacturers website for updated drivers), usb driver behaves differently compared to parallel drivers as it expects a usb printer connected to a computer. try both drivers. remember, it may or may not work.
Dec 03, 2008 | Argox OS-203 Thermal Label Printer
Need an usb to parallel cable
You may want to try this site. They have an assortment of USB to parallel printer adapter cables which will connect your parallel port printer to your USB port.
Good luck and kind regards.
Nov 08, 2007 | Computers & Internet
Initialization failed - Unable to acquire TWAIN-compliant device
I have seen your message stating that "Initialization failed - Unable to acquire TWAIN-compliant device" error is received when trying to connect USB-Parallel type to your Laptop.
Well,  Printer  Panasonic UF4100, recommends to use only " Printer/Scanner Interface as Bi-directional Parallel (IEEE1284) " means you need to use Parallel cable to connect Printer to the Computer/Notebook.  You may receive some communication error messages if you are using a  "PORT REPLICATOR CABLE"( USB TO PARALLEL connector).  The error message that you have received is related to the communication error. Futher, if you use same USB- Parallel cable for long time the Printer Hardware functionality might go bad, since Printer memory gets confused and will not read or detect the Cable , since it is not a cable to use  mentioned by Panasonic Manufacturer.
Let me tell you, general functionality of Printer like Printing would work even if you use USB-Parallel cable. But it is not a case with Scanner and Fax functionality.
Hence, I recommend you to use only Parallel cable to connect your Printer to the Laptops.
I hope that this will resolve the issue for you.
You can email me at thumuvikram@rediffmail.com if you need further assistance.
Bye.
Oct 17, 2007 | BafoTech BAFO BF-1284 Parallel Adapter
139 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
