Question about LG LRFD25850 French Door Refrigerator
Fun noise I hear fun noise. If I open any door the noise is winding down. I tried to unplug for while but it didn?t help. What can I do? Can you help me? Thank you, Vlad
  • LG Master
  • 5,568 Answers
It may be a fan in the process of dying; either the circulating fan or the one below the cabinet that pushes air past the coils.
Posted on Sep 24, 2008
Dryer heats, and runs empty. Once even a small clothing item is added, when the start button is hit, there is a buzzing noise and it will not start. It then will also not run empty for a time. What could...
hum might check ur moister sensor? and also u may have bad motor windings try this If you hear a humming sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Mar 30, 2015 | Dryers
Wind noise 2011 volvo s60
possibly a partially open window or partially open sunshine roof.
Mar 12, 2015 | 2011 Volvo S60
How do I correct wind noise on drivers side door / window 1999 Camry?
There may be a torn, missing, or loose door gasket. If you inspect the seal and find torn or missing segments, repair or replace. If the seal is intact, the the most likely cause is a gap in the door seal near the top rear of the door. This happens over time because the door frame can actually get bent slightly outward. It is so little as to not be visible, but you can hear the wind noise. The way to get the noise to stop is to open the door and roll the window all the way down. Then, holding the door firmly, grasp the upper rear corner and pull it inward (toward to the car). A couple of sharp tugs will usually do the trick. I know it sounds silly, but it works. BE SURE TO HAVE THE WINDOW DOWN OR YOU COULD SHATTER THE GLASS!
The door frame is quite thin compared to other car body parts and will bow/bend if you pull on it. Start out carefully and if you don't get the results you want, try again with more force.
Nov 21, 2014 | 1999 Toyota Camry
87 chevy caprice A/C vent not opening
Depends on what is clicking. The engine vac opens blend doors under the dash. It could be one of the vac pots or a blend door is sticking. Normally the hissing noise means you have a leak, but a leak usually does not fix itself.
May 18, 2013 | Chevrolet Cars & Trucks
Washer door will not open. Power button will not
You can manually unlock the door on this washer. First you should unplug the washer from the wall outlet and then remove the lower access panel. With the lower access panel removed, and the washer unplugged, reach up to the door lock and feel for a round release ring and pull it down. The door should unlock now.
Thank you !!
Jun 30, 2010 | General Electric WCVH6800J Front Load...
2004 VW Beetle Convertible. Drivers door window could not go down yesterday because of ice. The window still works but it does not perform it's drop down and going up as it should when door is opened and...
can you hear the motor trying to work the window? A fairly common problem is the window regulator breaks. this is the cable operated lifting mechanism that raises the window, when it breaks you can hear the motor winding away, accompanied by a faint clunking noise as the motor tries to operate the mechanism. They are quite difficult to replace.
if you cannot hear the motor working (also assuming all your other windows do work) then either to motor is faulty or there is no power to the motor. the wiring inside the rubber boot that goes from the car to the door (by the door hinges) is prone to breaking due to the constant flexing back and fourth as the door is opened and closed. switches can also fail, you may be able to swap the drivers/passengers switches around if they are identical for testing.
Feb 23, 2010 | 2004 Volkswagen Beetle
Hearing wind and road noise from right front of car and sunroof.
check the seals the rubber around window has anyone put anything on top of your car open the sunroof check the inside as it closes / to move the sunroof up or down after resting there are bolts on ech side at front theat you can un bolt push up and tighten up/ thanks for using fix ya please rate my response thank you very much
Jan 30, 2009 | 2006 Jaguar XJ8
Stuck CD/DVD tray on HP Pavilion laptop
hi ther
how r u ??
u just do it manuly but not by the button
in teh tine hole poke it with a paper clip try it untile u get resistance and push
if u need any further assistance email me
u take care and have fun
salammmmmm {bye in arabic }
p.s rate me thanks
Nov 22, 2008 | HP Pavilion DV5234US Notebook Laptop
LG LRFD25850 French Door Refrigerator Logo
83 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
