Question about HP Color LaserJet 2600n Printer
Black plastic roller sheet
The black plastic roller sheet that is attached to the door when you open the toner door has developed a crease in it and it pops every time something is printed. Can this roller be replaced by me. What can be done?
  • wkelley Jul 31, 2008
    I have the same printer. The specific problem I.ve got is that there is a yellow line going down the roller that is transferring to all printed materials. I have followed all the standar cleaning procedures and can't get rid of it. Not very professional looking on my invoices and manuals.
  • 89 Answers
The part you are talking about is the transfer belt. It can be changed by the user if they are willing to remove a couple of outside covers. It is not all that hard but you need to be careful
Posted on Aug 02, 2008
Why is my printer only printing a black sheet of paper?
Hi it is not the toner but it could be a developing unit or transfer roller.
But since on b6500 the developer unit is changed with the toner it is probably the transfer roler or HV unit.
Regards
Apr 10, 2015 | OKI B6500 Led Printer
How do i reset the trouble code c 2259
Black image unit motor failure. First open the front door remove the black image unit not the black toner!!!. Take the image unit and shake it so as to spread out all of the developer & toner inside the image unit along the whole length of the unit. The reason for this is as not have all of the developer/toner all at one end and the motor trying to turn with all that at one end or the other. Never store image units or toner vertically!!!!!
Now reinstall the image unit. and close the door. Opening and closing the front door will reset the machine . If it comes back good chance bad image unit.
May 13, 2014 | Konica Minolta KONICA BR BIZHUB C451...
What does Error Code C2564 Konica Minolta Bizhub 552 mean
Black drum ATDC replace the black developer unit, also check to make sure the black toner is getting into the black developer unit. Open close the front door to reset the code (Not the Toner door)
Apr 24, 2012 | Konica Minolta Bizhub C552 Copier
Hi, Having a problem with our Werox Phaser 7760 - there seems to be a white line on the black running the length of the sheet - have changed the toner, transfer roller and imaging unit to no effect. When...
If the white line only appears on a signle color (black) then it has to be either the image unit, laser, or developer. You can try cleaning the top of the laser using the arm located in the front door, because toner ofter spills onto the laser window causing white streaks. However, Judging by your desription the part you are referring to is the developer. You can attempt to clean it if you can reach it or replace it. The assembly is part# 802K60191 and you must also purchase the devloper charge (black) part# 604K22550. This isn't a very easy fix, so if you are not very technical you may want to bring it to a copier technician. If you wish to fix it yourself and order from ItemIncOnline.com they will send you instructions with it. If you are still confused call 1-800-367-4836 (free tech advice, specialize in this machine) Hope this helps. - Steven
Mar 17, 2011 | Xerox Phaser 7760DN Laser Printer
Laserjet 4050 - black streaking on right hand side of page
It is either the toner cartridge or the fuser.
Put paper in the manual feed tray.
Print the Configuration Pages.
When the sheet is half way fed into the printer, open the top cover.
Remove the toner and look at the sheet of paper. If you see the black streak, the toner is bad.
If the sheet looks good, the fuser is bad. Probably a bad roller, which you can see looking at the fuser.
Jan 21, 2011 | HP LaserJet 4050 Printer
Printing all black after putting in new toner cartridge
Sounds like the plastic strip inside the new toner has not been removed..or ..It could be the charge transfer roller is not seated properly. When you remove the toner look inside and when you open and close the top door the charge transfer roller moves up and down....make sure its properly seated or it will cause the problem you describe. It could have been bumped when you put the new toner in. Hope this helps
Oct 21, 2010 | IBM Infoprint 1532 Laser Printer
My Ricoh Aficio MP 161 said to add toner but still won't copy
Check your old toner bottle and make sure the plastic "cap" is still in the bottle. These machines have an occaisional problem with the caps coming off (not the black screw off cap but the semi clear cap under the black screw off cap) and staying inside the black plastic "cup" that you insert the toner into. If the cap is missing it may be stuck inside this cup. If the cap is still in your old cartridge then try opening/closing the front door and letting the machine cycle to see if the toner light goes out. May have to do this several times. Had one customer just yesrday have to do this to clear the toner light after adding toner.
Good Luck.
Jan 28, 2010 | Office Equipment & Supplies
Black smudge marks on our prints.
If you are using a generic brand of toner, this could be the problem, and if so, your developer is shot, and the drum unit will need a thorough service.
Otherwise, it is very likely that the Drum (PCU) needs replacing, or fuser is failing.
Whatever the cause, it requires a technician.
Mar 12, 2009 | Ricoh Aficio 450 Copier
1/4 black line going down back of paper when I print
The black line going down the back is from toner coming off of the cartridge
open the printer (I am assuming it is **** shell design remove the developer/toner section
open the plastic shutter that goes all teh way across the drum area and inspect you may find a piece of paper in there or there is suppose to be a wiper assembly that may be bad
while you have the machine open clean the charger wires( they pull out on a rod and clean with a pencil erasure
also inspect the fuser rollers(be careful they are hot to make sure no toner has built up on them if so let the macne cool and clean with silicone lubricant do not scrae with any sharp object
Dec 30, 2008 | Brother HL 1440 Laser Printer
Pages full of toner / toner streaking
First off, this is a comment from a random person who may or may not know ALOT about these printers and toner/printer design in general. All toners are not designed to the same specification. Toner is a combination of plastic "pigment" and iron like shavings to make it magentically attracted to the electrical charges within the unit. Different toners conform to different grades and mainly size of the particles within the blend. The manufacturer doesnt only recommend that you use their toner to make them money, yes of course it makes money, but its because when the unit is designed it is designed to use a certain grade of toner, trust me if you put the non-branded toner vs the branded toner under a microscope you would see quite a difference. Often the non-branded toner is much larger in particle size (obviousely because its cheaper to make at this spec). This causes a variety of issues from excess toner not being cleaned off of developer rollers, IDT rollers, or clogging of toner dispenser tubes in the unit and the micro filters contained at the toner dispenser assy and developer assys. Also as for the issue not changing when switching to dell branded toner - the dispenser tubes within this unit contain up to 500-1000 pages worth of toner, making no change in toner you make immediately visible. Also depending on the damage caused by the previous toner, it may not be able to be fixed until all the components in between the toner and final delivery (drum cart) are replaced. In this case more than likely the toner dispenser assy, all developer assy's, and drum cartridge need to be replaced, and than be sure to stick with factory branded toner :)
Apr 26, 2008 | Dell 5110cn Laser Printer
HP Color LaserJet 2600n Printer Logo
93 people viewed this question
Seeker5211
Seeker5211
