Question about HP Pavilion F1703 17" LCD Monitor
Hp monitor I read your post on fixya. I have the same problem. Do you allready have a fix or did you throw the monitor away ? Greets, Bart
    New Friend:
  • 4 Answers
The usual problem with this model is three caps on the power board.
Posted on Mar 21, 2013
2 Suggested Answers
Fix-4U
  • 293 Answers
SOURCE: Cracked Monitor
Hi...there,
Well sure, if you don't mind pay double the prices... My advised, give yourself a new monitor, since the holidays is coming... saved you the headached and $$$...
Posted on Oct 07, 2008
Hp 2010i monitor shaky, can't find degauss option
I don't think degaussing your monitor is going to help with this issue. Degaussing mainly addresses color correction around the monitor edges due to a magnetic field and applies to CRT monitors not LCD monitors which yours is. If by your term "shaky" you mean the image is unstable, then the problem is either in the main board which controls the X Y sync or with the power supply board. If you are knowledgeable with electronics you could probably repair this at home for $40 or less. If not then I would shop for another monitor to replace yours. Don't throw your old monitor away, instead post it for sale on craigslist. There are a lot of do it yourself type people who will buy this either for parts or to repair and resell. I don't know what it will bring as far as cash, might be $40 might be $5 but anything is better than zero.
May 09, 2013 | Computers & Internet
Hi we have a compaq 7550 screen that when turned on has a red sheen over the whole screen. Any solutions or is it ready to throw away. thanks
You may try messing with the settings on the monitor. The menu buttons are usually on the front. Try to find something that deals with the color tones of the monitor. If messing with these settings doesn't fix your problem, then unfortunately, it is probably time to throw it out.
Aug 27, 2011 | HP Compaq FS 7550 17" CRT Monitor
HP LP1965 monitor appears dead. Green light comes on at bottom of screen but screen does not indicate any activity. Checked with replacement monitor and PC signal is good and responds to all...
More likely to have power supply failure due to bad DC filter caps.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 11, 2011 | HP LP1965 (Black, Silver) Monitor
Turn on and then it clicks off right away.
Jan 05, 2011 | HP Pavilion F1903 19" Flat Panel LCD...
The power button flashes between blue and yellow. The monitor screen stays black. I have the exact same monitor and switched it on to my other computer, and the computers are both working fine.
perrycdoq, Did you do flashlight test? Is your monitor also "blank"? Did you visit this old net blog? http:///www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Do some reading there then come back and tell me if you think same thing might be wrong with your unit. Will you do the troubleshooting or contract out the work to qualified electronics technician to fix units "switch-mode-power-supply / inverter ballast circuit? 12fixlouie
Oct 03, 2010 | HP w1907 LCD Monitor
Cracked Monitor
Hi...there,
Oct 07, 2008 | HP LP2065 Monitor
HP MX 75 CRT monitor just quit working. No light on the on button.
...strictly as, at at best. a long shot: according to a post I just read somewhere online about this HP MX 75, pressing AND HOLDING the + button on the monitor front and at the same time turning the monitor on and off repeatedly, may fix problems with this monitor.
Mar 18, 2008 | HP Pavilion MX75 17" CRT Monitor
Melted plastic under black ink cartridge
10 months well then it is under warranty still. HP replace machines under warranty, no easy fix, never known of melting.
Dec 25, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP Pavilion F1703 17" LCD Monitor Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
