Question about Mitsubishi VS-50805 50" Rear Projection Television
VS-50805 Replacement Lamp Bulb
Have audio but no video .. We suspect the bulb, but cannot seem to find the precise replacement bulb Part #. Can you suggest, please? Thanks!
  • Anonymous Oct 05, 2008
    I have the same problem. It worked fine yesterday, today there's audio but no video. Screen doesn't light up. Where can I find a replacement part?
  • Anonymous Oct 21, 2008
    Started losing picture also with this TV. Rolled it off into the other room 2 yrs ago and got an LCD TV. Picture wheel on LCD went out, rolled VS-50805 back in and watched it for a week......back out again. Ok, haven't found a bulb yet and LCD supposed to cost $1200 to fix? I'm off to buy an LED DLP for price and longevity - crossing the fingers. And still won't get service contract on a TV ....$100,sure....$400 ? No way.
Did you find a bulb? My green bulb is dying and I need to find a replacement and I am being told the factory does not sell the part anymore. Any guidance would be appreciated.
Posted on Aug 15, 2008
Replacement lamp bp96 00826a
It could be a power surge or it could be an old bulb that needed changing. I would suspect that the bulb has reached the end of its life cycle and would check online to find a new one and replace it.
May 16, 2013 | Televison & Video
RCA M50WH72S Replaced bulb and ballast. TV comes on with good video for about 5 seconds, then off with good audio, front power light blinks 5 times. After a few minutes the video comes back on and repeats...
Check capacitors cp624, cp647 1000uf@35v each. They are in the power supply. Can be seen with bulge on the top. Seems to be a common problem with this model RCA.
Jun 07, 2011 | RCA HDLP50W151 50" Rear Projection HDTV
Sharper Image Desk Lamp S1412. I need a manual. Lamp has quit working. Doesn't appear to be the bulb.
I have the same lamp with similar problem. I suspect the problem is with the ballast or starter, not bulb or switch. Ballast likely in the base. I'm searching for a replacement ballast.
Jul 03, 2010 | Kitchen Appliances - Others
I have a hitachi 55vs69 projection television. Lately, it has been shutting down every 15 minutes or so. The screen turns dark but you can still hear video until about a couple minutes later the led light...
First step is to unplug the 120 vac power for a few minutes to clear any corrupted data that may be present in the controller circuits.
If a "power" reset doesn't help and the lamp or bulb is installed correctly, you most likely have a failed replacement bulb. The symptoms are all standard indications of a failed bulb.
Reduced lamp life can be caused by:
  1. Lightning and other 120 vac power bumps.
  2. Collisions with vacuum cleaners or other incidental impacts while the TV bulb is operating.
  3. Starting the TV without a complete cool down. Bulb will consume a small amount of mercury with each start. Excessive consumption occurs when bulb is "Hot" and turned on.
  4. Wrong bulb installed as replacement.(Philips original replaced with Osram or El Cheapo)
  5. Poor quality or damaged bulb installed as replacement.
  6. Bulb damaged during replacement
  7. Bulb installed incorrectly at replacement.
Almost all Hitachi 55vs69 "No Picture" failures are related to the bulb.
Many of our service events are with customers that purchased El Cheapo bulbs from "shopping cart" websites or picked up a bulb from a small "local" TV shop. Many small shops stock of 3 or 4 bulbs and try to substitute or cross reference to fit more than 200 models of TVs from 7 different manufacturers. If a premature bulb failure occurs, they have the opportunity to sell you some expensive service.
Go here to see all of the different Hitachi TV bulbs that are available in Canada.
Find Your Lamp
Use the correct bulb for your model and if you are uncomfortable with the replacement procedure, get local service.
Jun 08, 2010 | Hitachi 55VS69 55" Projection HDTV
Just replaced lamp on a sony kf-50we610 lamp light still on
Seems like a defective lamp perhaps. Can you check the old one for same test you did? It's hard to test them with a vom or multimeter and get correct results.
Feb 05, 2018 | Televison & Video
Looking for lights....
You can find replacement parts for this model from the following Sony OEM parts distributor. Here's the links to order the original Sony blue CRT, green CRT, and red CRT (the 3 "light bulbs") for this model from that major parts distributor if needed:
Sony KPR-53CX35 Replacement Part Blue CRT Bulb / Lamp
Sony KPR-53CX35 Replacement Part Green CRT Bulb / Lamp
Sony KPR-53CX35 Replacement Part Red CRT Bulb / Lamp
Apr 01, 2009 | Televison & Video
Fix picuture
try to clean all reflection glass at the back of the projector
Dec 12, 2008 | Mitsubishi VS-50805 50" Rear Projection...
Unexpected lamp shutdown
Nov 09, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
WD-62327 Lamp
This is about buying replacement bulbs for the WD62327 TVs.I dont know about the other models but I purchased a PHILLIPS replacement bulb and it worked for about a week and then those dumb flashing lights and no TV. I did some research and others were saying that you had to replace some condensers. Shop would do it for 600 dollars..Well i sent the bulb back and bought an OSRAM replaement bulb. The TV is now working perfect.
Sep 17, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi VS-50805 50" Rear Projection Television Logo
220 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
