Question about Sony Cyber-Shot DSC-W7 Digital Camera
Sony DSC-W7 When the camera is turned on I get this message on the screen"Turn power off and on again". That does not help. Also, the lens is extended and will not retract. Bob
  • Anonymous Aug 26, 2008
    We have the exact same problem! An error with turn camera off and it won't retract. Is there a reason why this happens? Is it due to being used often?
  • 10,594 Answers
Lens assy is defective. needs to be replaced.
Posted on Jul 25, 2008
I have a cybershot DSC W55. When the power button is switched on the lens extends and the "access" message shown on screen. Also amber light is flashing above screen. After a few seconds I get a...
I have a cybershot DSC W55. When the power button is switched on the lens extends and the "access" message shown on screen. Also amber light is flashing above screen. After a few seconds I get a message to power on and off again. I\'ve tried switching on and off a few times, removing battery pack and memory card, but nothing seems to be solving the problem.
Feb 19, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
On the screen shows turn off and then turn on again and again-it does not turns on any way
The Turn off and on again error message displays when there is an internal malfunction or a malfunction with the Lens. The error message normally displays with the issue with the Lens. Try the following steps to check if the issue can be resolved.
Try power resetting the Camera.
Turn off the Camera.
Remove the battery pack.
Press and hold the power button for 15 seconds.
Then, allow the Camera to remain without power for 60 seconds.
Re-insert the battery pack and check if the Lens retracts.
You can also try resetting the Camera back to factory default. To reset the Camera back to factory default, select the INITIALIZE option from the Setup 1 Menu of the Camera to OK. (Menu-->Setup-->Setup 1-->Initialize-->OK.)
This should resolve the issue. If the issue persists, service may be required.
Thanks for using FixYa.
Jan 17, 2011 | Sony Cyber-Shot DSC-W7 Digital Camera
Dear Sir, I have SONY DSC W-55 series camera. Whenever I turn on the camera its lens tries to adjust and always displays a message for turning off and turn on again.
This is usually caused by impact damge to the lens barrel or sand/grit ingress.Quik turn on the camera let the lens try to adjust.Then remove the power with the lens extended as far as it will go. Hold the camera up and check if the front of the lens is exactly parallel with the camera housing. If it is skew you can try gently pulling on the inner barrel which(If your lucky) will pop back into the correct cam.
Mar 11, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Sony DSC W30 digital camera, lens unit problem
Hi!
If you're sure you didn't damage the lens flat cable which connect to the motherboard, the focus of the lens unit you bought on ebay doesn't work. You can simply replace the back part (with focus) of the new lens unit with your old one. It requires soldering.
Tom
Mar 06, 2010 | Sony Cyber-shot DSC-W30 Digital Camera
Turn the power off and on again message
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
Thanks for contacting FixYa
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
SONY CYBER SHOT NOT WORKING
Hello samtx930, "turn off the power and on again" its a very commen problem and occurs when the lens block assembly start malfunctioning. Actually the slide motor not work properly and until the lens not come out completely the camera will not work, that's why the error message appears "Access" and then screen shows "turn off the power and on again". In this situation you have to replace lens block assembly.And the part No. is with description is given below: 1-788-363-11 OPTICS UNIT (ED13A) Thanks for using fixya.
Jun 14, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
My sony camera gives this message and lenz will not close.
    This message appears when the lens assembly start malffunctioning. Therefore, You have to replace the Lens Block Assy. For this plz contact any nearest Sony Service Centre nearby to u.
Thanks for using fixya!
Take care.
Mar 11, 2009 | Sony Cyber-Shot DSC-S90 Digital Camera
Dsc w7
While turning in off softely press the lense in and out a couple of times. The lense would retract. If not fully, but most of the way, push the lense a little harder in until completely retract. If you turn it on, I should work fine. The reason the lense does not retract is most likely some dust in there somewhere. If it did not help, you would have to open the lense and clean it and close the lense.
I hope it helps,
Jul 13, 2008 | Sony Cyber-Shot DSC-W7 Digital Camera
Sony Cyber-Shot DSC-W7 Digital Camera Logo
100 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
