Hi there. I do not know if you still have your Univa E600 oven. I have seen your problem and have the same one. Did you find a solution in the end? I also basically just need to know where I can mark the temperatures on the face of the oven. Did you manage to find a photo or something. I have also tried to google my problem with no success whatsoever. Can you pls contact me via email: [email protected]. I will appreciate your reply. Thank you. Marietjie
SOURCE: How to set the time, and can i download a usermanual anywhere? Thanks
Touch the clock pad. Enter in the correct time of day by touching the numbers in sequence. Touch the clock pad again...should set.
I have not seen a manual on-line for your model...ut htere are many others...perhaps browsing thru a few might help you. If not...try going into a store and looking for that model...the management might copy if for you...I would. :-)
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
