Question about Canon FAXPHONE L80 Laser
I need to stop receiving cover paper
How i can do that?
  • 57 Answers
Do you have the hand book for this machine. If you do go to the page that says sending and receiving faxes and check on how to set up you machine.
Good luck
Posted on Jul 25, 2008
It said to open from cover and remove paper I did and It dont work
If you receive an "Open front cover" error message the solution is to open the cover and remove the paper and any remnants of the paper jam. If there is no obvious paper remnants jamming the printer and you continue to receive an error message I would suggest unplugging the printer from the power source.
After 5 - 10 minutes plug in to power source.
Turn on printer.
See if this has resolved error message. If not you will need to check more carefully for paper remnants that would be causing the printer to detect a jam.
Trust this is helpful. :)
Dec 08, 2010 | Konica Minolta PagePro 1390MF All-In-One...
Canon Fax-L700
There is a cable that runs from the scanner to the processor. Looking from the front, its on the left side of the machine, on the back, it is a fairly large connector.
Unscrew the two thumb screws, then unplug it and plug it back in with the machine ON.
It will force it into a reset and may boot.
The problem is caused by a software glitch .
Check the tray settings and ensure that paper size guides are set to the appropriate paper size, then power off/power on the machine.
Sep 20, 2008 | Canon FAX-L800 Plain Paper Laser
Hello, I have a Brother Fax 560 (Plain Paper Fax). I am having difficulty receiving faxes. It is not transmitting on the receiving end. What is the problem?
Hi Despite the increase in texting, email, Facebook and Twitter, we still hang on to our fax machines. They are perfect for sending copies of original documents despite document jams, buying ink or special paper, maintaining a phone line--we love 'em. Basic problems like paper misfeeds can be troubleshooted through the use of some basic steps.
Check the Message
  • Check the messages on the display of your Brother fax machinemag-glass_10x10.gif. The messages will be pretty self-explanatory such as "Insert Doc, Again" or "Please Supply Paper." "Insert Doc. Again" means that that the documents weren't placed on the feeder correctly; just follow the instructions and try again. A message like "Please Supply Paper" will simply mean you need to replenish the paper. "Memory Overflow" is probably the most cryptic. It just means that the memory capacity was exceeded and it has stopped recording. Press "Enter" to register the documents in memory and to complete the operation.
  • Misfeeds
  • Clearing an original's misfeed by pushing down on the release lever to open the front panel. Remove the failed original and close the panel. To clear recording paper that's gotten jammed in the paperfeed, open the turn guide and remove the paper. To clear paper from the transport unit, which is in the top, open the cover, remove the drum and toner. Lift the guide and remove the paper by pulling upwards. Paper can get stuck in what is called the Fixing Unit. Open the top cover. Again, remove the drum and toner. Open the Fixing Unit cover and remove the paper by pulling it back.
  • Aug 02, 2010 | Brother IntelliFAX 560 Plain Paper Fax
    Will not pick up paper when receiving Fax or asked to Copy . Transmits fine and receives into memory but cannot get a paper copy of received transmissions.
    Remove cover for paper, and you will be able to see the two small rollers on plastic axis. Clean them. ( each side, but when you turn them manually, put it back in first position )
    May 26, 2010 | Canon FAXPHONE B640 Plain Paper Bubblejet
    I have a canon mx700 & have an error code 6A80 -need help
    That error says there might be paper scraps stopping the purge assembly on the right where the printhead parks, or something fallen into the slot where paper goes stopping the paper feed assembly. You just have to inspect closely with a flashlight before taking to the shop.
    Jan 05, 2010 | Canon MX700 Office All-In-One InkJet...
    ADF paper jam, when there is none
    If you are receiving an Error Code 103 or a Paper Jam error, but there are no pages in the ADF (Automatic Document Feeder), follow the steps below:
    1. Close the scanning application (such as PaperPort)
    2. Turn off the scanner and the computer
    3. If you have a combination ADF with a Flatbed scanner, unplug the ADF cable from the base of the scanner
    4. Plug the ADF cable back in
    5. Turn on the scanner power
    6. Turn on the computer
    7. Try scanning again
    For a Paper Jam or Error Code 103, make sure that the ADF cable in the rear is connected to the scanner base. Check the flatbed to make sure that it is clear. A page incorrectly placed on the flatbed may interfere with a page feeding through the ADF.
    If your scanner stops scanning due to a paper jam in the Automatic Document Feeder (ADF), a warning dialog box appears after a few moments.
    To clear a paper jam:
    1. Open the Automatic Document Feeder cover.
    2. Remove the jammed paper and close the cover.
    If you are receiving a paper jam error, or if the scanner is running continuously, check to make sure the paper sensor arm is not stuck down.
    2. Look for the small black plastic arm
    3. When you press on this arm, it should move freely up and down
    4. If the arm is stuck down, please contact Technical Support for troubleshooting options
    5. Close the ADF cover.
    May 26, 2009 | HP Scanjet 8350 Flatbed Scanner
    Paper stops
    Check that the rear paper sensor feeler arm is not broken. It is the little black plastic tab that sticks up in the middle of the paper path when your looking at the back of the printer with the cover open. If you can't see it, it's probably broken.
    Aug 06, 2008 | Lexmark E234 Laser Printer
    Canon LaserClass 7000 - Receiving problem
    Make sure the rear guide is pushed up tight against the paper.
    Remove all legal size paper and make a copy.
    Dec 13, 2007 | Canon LaserClass 7000 Plain Paper Fax
    Help with HP d135 all in one printer,scanner, fax
    HP Error Codes
    These error codes apply to many HP & Panafax machines
    001 recording paper jam
    002 recording paper jam
    010 no recording paper
    014 print cartridge is not attached
    015 out of ink
    017 wrong paper size
    030 document misfeed
    031 document jammed or exceeds maximum length (2 meters)
    039 during dialing, STOP was pressed
    041 out of toner
    045 no toner cartridge
    060 a cover or door is open
    061 a cover or door is open
    063 jam access cover is open
    316 clean the ink station overflow tray and encoder strip on inkjet models
    400 during initial handshake, RX station did not respond; comm error
    403 no polling capability at remote side
    404 during initial handshake a comm error occurred
    405 during initial handshake a comm error occurred
    406 password mismatch
    407 no confirmation from the RX station for the previous page sent
    408 remote side confirmation of previous page is illegible
    409 remote side confirmation of previous page is illegible
    411 polling password does not match
    412 no data from the transmitting side
    414 polling password does not match
    415 polling transmission error
    416 received data has too many errors
    417 received data has too many errors
    418 received data has too many errors
    419 received data has too many errors
    420 machine enters RX mode but receives no command from TX side (not a fax calling)
    422 interface is not compatible
    427 interface is not compatible
    430 comm error occurred while receiving
    434 comm error occurred while receiving
    436 received data has too many errors
    456 memory overflow on confidential document or relay request
    490 received data has too many errors
    492 comm error occurred while receiving
    493 comm error occurred while receiving
    494 comm error occurred while receiving
    495 telephone line disconnected
    540 comm error occurred while transmitting
    541 comm error occurred while transmitting
    542 comm error occurred while transmitting
    543 comm error occurred while transmitting
    544 comm error occurred while transmitting
    550 telephone line disconnected
    552 comm error occurred while receiving
    553 comm error occurred while receiving
    554 comm error occurred while receiving
    555 comm error occurred while receiving
    580 sub-address TX to a unit without sub-address function
    581 sub-address TX to a unit without sub-address function
    601 ADF misfeed
    623 no document was on the ADF
    630 redial unsuccessful (busy line or no response)
    634 redial unsuccessful (busy line or no response)
    631 during dailing, STOP was pressed
    638 power failure occurred during the communication
    640 telephone off hook after comm is completed
    870 memory overflow while storing TX documents
    879 memory overflow while storing RX documents
    975 DRAM parity error (document info in memory is lost, very common, also clean encoder strip)
    HP 200/300 and similar models GPM (printer assembly) failure: When the inkjet carriage is homed on the right side of the unit, the spring pointing toward the rear of the unit passes under 2 "actuators" that appear to be identical (mounted vertically, L-shaped). Under heavy usage, the lower end of these actuators is worn away. To remove the actuators for inspection, carefully rotate the paper pickup feed wheels while pulling upward on the L-shaped actuator (compare the 2 actuators, or compare them with actuators from a comparable machine that is in working order).
    Many HP and Panasonic inkjet models are comparable and parts can be ordered from Matsushita.
    If there is an encoder strip (scale) in inkjet models, clean it to correct a wide variety of problems (HP 900, OfficeJet, Panafax UF321). The encoder strip resembles a narrow piece of cellophane tape, and can be found behind and above the silver bar on which the printhead rides. Easily broken ... use caution when cleaning with a cotton swab dampened with water or rubbing alcohol. When dirty from overspray, the strip can cause all types of problems.
    In the Maintenance Mode of HP and Panasonic machines there is a wealth of information. For example, print out the function parameter list to get the lifetime TX/RX/PRINT counts (usually option 3 instead of option 6 in the following example for the HP 200).
    HP 200 ram clear
    Press # dial dial dial dial * 6 start
    Exit the maintenance mode by pressing 9 9 9 start
    [Note: to print function parameter list substitute 3 for 6 in the line above]
    [Note: to execute a self-test substitute 0 for 6]
    [Note: to set parameters 000-999, substitute 1 for 6]
    [Note: to test modem/tones, substitute 4, 5, or 7 for 6]
    [The TX/RX/COPY counter is item 061 on function parameter list]
    HP 300/310 ram clear
    Press function 7 dial dial dial dial * 6 start
    HP 700 ram clear
    Press and hold stop and menu for a few seconds
    Press 7 0 0
    Press up-arrow key 4 times until display reads 09 memory clear
    Press start
    Bad line card: replace 2 transistors, 1 diode, and 1 chip. Transistors BS170 (NTE490) @ Q1; 2N3906 @Q3. Diode 1N4148 ar CR2 (next to 2N3906). Chip 74LS14 (74HC14) at U5 (near BS170).
    HP 900 ram clear (same as Panasonic UF-321/322)
    Press menu 7 dial dial dial dial * 6 start
    Press up-arrow key until the display reads shipment set then press start
    The display will read reset counter
    Select yes or no then press start
    HP 900 disassembly tips (proceed with caution and at your own risk). To remove the operation panel cover: face the rear of the unit, place your thumbs in the outside edges of the document feed path, lift up on the thin edge of the cover while pulling the cover toward you. This should release "snaps" located at the outer edges of the document feed path. Facing the front of the machine, lift the cover up and toward you, then disconnect a cable attached to a board on the rear of the operation panel. To access the document feed mechanism, remove a white plastic retainer in the upper right hand corner of the ADF cover, disconnect the ground strap on the right side of the cover, and slide the cover slightly to the right until it is unhinged. The cover housing the scanner glass can be lifted off after removing several screws, popping two "snaps" at the rear corners, and then carefully popping two more snaps at the front corners of the cover. At this point you would be able to clean one scanner mirror and the ADF sensors & rollers. If you need to remove the line card, you'll have to remove the remaining covers, one screw located at the front of the power supply, four screws that hold the printer assembly in place, one screw at the right rear corner of the scanner assembly, pop two snaps at the front corners of the scanner assembly (remove a long white plastic retainer at the left front corner of the scanner assembly). After gently lifting the scanner assembly upward, the printer assembly can be removed to reveal the line card. During reassembly, be sure to check the positioning of the print paper detect sensor (the spring comes off the sensor and you get an out-of-paper error). Another observation we've made is that on some (but not all) HP 900's, there is a metal retaining clip on the left end of the paper pickup roller's shaft. Apparently the plastic lever (retainer or lock) on the left end of the axle doesn't always hold the mechanism in place in the event of a multi-feed that jams the machine, and at some point in production of the machines a metal clip was added to hold the plastil retainer firmly in place.
    HP 900 set number of rings to answer (default is 2)
    Press menu 7 dial dial dial dial * 1 start
    Press 4 5 start clear
    Enter the number of rings desired then press start stop stop
    HP Office Jet / LX
    For a full ram clear, press and hold * and 1 while turning the power on.
    Hold the keys down for a few seconds after the display reads self test please wait then release the keys
    For a partial ram clear, press * and 4 while turning the power on.
    For the Diagnostics Mode hold * and 7 while turning the power on. Afterwards, new menu items will be found on the display including diagnostics. Turn the unit off afterwards to dump the diagnostic menu selection.
    The original Office Jet/LX will print a scanner calibration chart/instructions.
    If the modem fails, remove it. Reinstall and test.
    Clear Paper Jam: Remove RX tray, press load/eject and paper should load part way; press load/eject a second time and the page should be ejected. If the page ejects ok, then it's not necessarily a mechanical problem, in which case you should clean the encoder strip and sensor. If the page does not load properly, it is probably a mechanical failure. Laserjet paper is slick on one side and may not load properly. Recycled cartridges spray excess ink on the encoder strip
    Nov 04, 2007 | HP OfficeJet D135 All-In-One InkJet...
    Printer keeps getting jammed no matter what
    clean all sensors and make sure you have good dry stock to run through it like a heavy 28 lb paper. also check the path of the paper and see where it stops it might be at the paper tray pickup or even the fuser. try running the machin with the covers open by jamming something into the cover sensor and see where the paper stops at.
    Aug 27, 2007 | Sharp AR-407 Copier
    Canon FAXPHONE L80 Laser Logo
    21 people viewed this question
    old marine
    old marine
