Question about LG LRFC25750 Refrigerator French Door
Outside of fridge condensation; hissing boiling noise
LG French door; bottom freezer.
Extreme condensation on top of outside; NOT inside ceiling. Surrounding cabinets are soaked with water condensation.
BTW, the fridge surrounding wood cabinets are built to LG specifications regarding venting room.
Hissing boiling noise.
No problems inside.
Room temp is about 65-75 degrees farenheit
Kitchen floor damp (grout between tiles wet).
I can't really define where the noise is coming from, but it appears to be under or behind the fridge--sounds bounce and echo.
  • Anonymous Mar 19, 2014
    Condensate water is leaking from air intake between the fridge ceiling and freezer floor on the inside of the fridge.
  • 75 Answers
Under the compressor there will be rubber bushes which would have got damaged so change the rubber bush and ur problem may get solved
Posted on Jul 25, 2008
Water is intermttently running out the bottom of our french door fridge
Check the door gaskets. If they are leaky, humid air from outside gets in and the moisture condenses inside at a high rate. This could cause the condensate pan to overflow.
Jan 30, 2015 | Refrigerators
My lg fridge lrbn20514bk the thermastat is not working on the top control but for freezer is reading 567
This fridge LRBN20514BK with bottom freezer is a piece of junk. Just had the relay on compressor replaced and now the thermostat isn\'t working. Temperature on fridge reads nothing and freezer temperature reading 5,6,7. Then the freezer coils freeze up and no air blowing to the fridge. Ready to take this POS outside and blow it up. Only 7 years old and never ending issues. I will never buy LG again. EVER! LNG - Life is not good! HELP.....so what needs replacing? Thermostat? And of course I have to have repair man come in due to LG not selling parts to customers. Again I call BS
Feb 03, 2012 | LG LRFD25850 French Door Refrigerator
Water build up on inside of fridge door of ge french door fridge
humid air in the house. any time you open the fridge, house air is sucked in. when you close it, the fridge cools the air and moisture from the warm air condenses on any cold surface. also check to see if there is a gap in the seal.
Aug 26, 2009 | GE Profile Bottom-Freezer Refrigerator...
Condensation on the strip between the 2 french doors
these fridge have a heater in that black flaper to prevent condensation. It is probably not working or not even plugged...do they removed the doors when they delivered your fridge??? remove the uper left cap of the hinge, the connection is there...... the tech must check that piece if it is well plugged..
Jul 03, 2009 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
I have condensation dripping right behind where the french doors meet on the ceiling of fridge, how can i solve this problem?
Possible that your door gasket is not sealing very well and therefore condensation forms in this area?
Jul 02, 2009 | LG LFC20760ST Stainless Steel Bottom...
Thermador Freedom T361T70NNP - French Doors - Condensation
I have the same problem, and thermador stated there was a recall on the hinges. They are replacing the hinges to a newer stronger hinge that will pull the refrigerator doors in tighter. It took three different service companies to find the answer to this problem because I was told Thermador does not want anyone to know about this issue they have.
Jun 29, 2009 | Thermador FREEDOM® COLLECTION T30IR70NSP
LG French door fridge freezer not freezing
hopefully you looked out back ...rear lower panel and checked little white condenser fan running...it really needs too to keep temp stable across the condenser coils and no overheat condition to the compressor.hopefully you wont need the $300 circuit board like I just bought
Jun 26, 2009 | LG LFC20740ST Stainless Steel
HISSING SOUND FROM FRIDGE FREEZER
I poked a hole in the freezer with my knife while trying to defrost it. Now it is making a constant hissing sound. what should I do? is this dangerous?
Jan 23, 2009 | LG LRFC25750 Refrigerator French Door
Fridge not cooling
How old is your refrigerator? Is it still under warranty?
Jun 18, 2017 | LG LFD22860 Stainless Steel Bottom Freezer...
LG LRFC25750 Refrigerator French Door Logo
821 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
