Question about Garmin StreetPilot 2720 GPS Receiver
System missing It's a StreetPilot 2720. How does one do a hard reset?
  • VARTRS Jul 25, 2008
    Tried - doesn't do it. I also tried some of the other buttons and combinations of buttons. The only different things is turning it on while holding the SPEAK button. The display changes from SYSTEM MISSING to HOLDING. But it doesn't reset...
    Am I stuck with a piece of junk now?
    Unfortunately, I can't reliably connect to the USB port. It appears the connector inside the unit is faulty -- if one wiggles the USB cable at the unit it can hit a ppint where the computer sees it, but I can't hold it reliable in that position -- that's how the problem started. I tried two different USB cables -- same story. I may try to take it apart and see if I can fix it.
    But I was hoping one could get the old system back without the USB port...
    And thanks so much for yout help!
    Scholar:
  • 162 Answers
Well, for the 2730 which is basically the same, you turn off the unit, hold down the FIND key and turn it on. Hold for about 5 seconds and release. It should reset the unit.
Posted on Jul 25, 2008
  • 2 more comments
  • Gary Luis
    Gary Luis Jul 25, 2008
    Can you access the garmin drive from your computer via the usb port?
  • Gary Luis
    If you can, you can still save your unit. Go tohttp://www8.garmin.com/support/download_...
    to download the firmware manually. the file size is 4.75mb. Then run the file. If you can connect your garmin to the PC and the PC can see it, you have a chance.
  • Gary Luis
    Sorry, the above link is for the 2730. This is for the 2720: http://www8.garmin.com/support/collectio...
  • Gary Luis
    I'm not sure if Garmin would sell you just that piece. The usb is secured by two screws and is easily replaceable. Model number or part number is 88910 vi or 94v-06 13
Streetpilot 2720 - also no audio
Yes send a message to the support address at Garmin for help I think the fix was removed as it had some incorrect steps
Jul 30, 2009 | Bennett Marine BENNETT DVD GARMIN...
My audio stopped working on my Garmin 2720
try depleting the battery until empty. that worked for my nuvi 760.
May 23, 2009 | Bennett Marine BENNETT DVD GARMIN...
Wanting cool voices, waypoint and poi icons 4 my StreetPilot 2720
For voices for your unit:
http://www8.garmin.com/support/collection.jsp?product=010-00408-02
Icons can be obtained from various internet GPS sites. Try googling GPS icons.
Jan 01, 2009 | Garmin 010-00358-00 GPS Receiver
Hard reset
I was told that you turn off the unit, hold down the FIND key and turn it on while holding. Keep pressed for about 10sec. then release.
Jul 25, 2008 | Garmin StreetPilot 2720 GPS Receiver
System Missing
The system is on a chip that can't be erased or reprogrammed. But a HARD reset may solve your issue. What model is it?
Jul 18, 2008 | Garmin StreetPilot 2720 GPS Receiver
Unit Locked Up
When turning on the unit, hold these two keys down: MENU/MAP for about 5 sec then release. That should reset the unit.
Jul 05, 2008 | Garmin StreetPilot 2720 GPS Receiver
Unlock Code
When updating the maps, you need to be registered with Garmin. All the numbers came with the unit. If you turn over your Garmin 2720, there will be a number flanked by "*". That is your unit ID. When you register, you must provide that ID. From the site, you can update your maps and you shouldn't need the 25digit key. It's programmed into your unit.
Jul 01, 2008 | Garmin StreetPilot 2720 GPS Receiver
Updating a garmin?
Its on the back under rubber flexi pad on left as looking at the rear of unit. Plug is at the bottom, the top one is for the aerial.
Good luck, Jon...
Mar 26, 2008 | Garmin StreetPilot 2720 GPS Receiver
Streetpilot 2720
I don't think you can change the base map, you can however add maps, maybe the UK will fit in what's left. You will need the Europe DVD to do that with an unlock key.
Feb 02, 2008 | Garmin StreetPilot 2720 GPS Receiver
Garmin Streetpilot 2720
I fixed my C530 on my own. Garmin support will not give you this solution.
I attached the GPS to the computer with the usb cable. I used the file explorer in windows to view the file system on the GPS. I sorted the files by date. Then I moved the files that had a newer date than the last time the GPS worked, to an backup folder on my computer in case I need to restore the files to the GPS again. I than disconnected the GPS from the computer and restarted the GPS. The GPS works perfect now and doesn't enter the demo mode any longer.
Oct 08, 2007 | Garmin StreetPilot c530 GPS Receiver
Garmin StreetPilot 2720 GPS Receiver Logo
269 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
